1977 Husqvarna 250cr Project
Discussion in 'Vintage/Left Kickers' started by John Shufelt, Feb 18, 2024.
  1. Bill502 Husqvarna
    Upstate NY
    2007 WR167 1978 CR250 1938 sw maus
    1970 Triumph T100C 1973 Honda TL125
    Now we are getting somewhere. I would look for the leading axel forks. That frame has the 29 degree rake and steers great in the woods.My 76 250WR had 32 degree rake when I got my 78 250CR much better in woods.That may turn even tighter with the straight leg forks.
    Bill
  2. John Shufelt Husqvarna
    Portland, Oregon
    1977 Husqvarna 250CR
    IT200, TY350, TM250, XCW250
    Okay, I believe I have the swingarm from the 360 Auto laying around. If I swap the black CR swingarm for the WR one will I be in the clear to order the 15 inch center to center shocks? I guess I still don't really understand the difference between the two swingarms.
  3. John Shufelt Husqvarna
    Portland, Oregon
    I'd go for the fork swap but if just swapping the swingarms would work that sounds a little easer.
  4. John Shufelt Husqvarna
    Portland, Oregon
    It's probably going to be mostly used as a cross country bike so the streight leg forks and the 29 degree rake sound pretty good for that kind of racing.
  5. Bill502 Husqvarna
    Upstate NY
    Compare the two swingarms together and see what the difference is between the lower shock mount distances are from the rear and the pivot on the two of them.If I remember correctly the 77 WR used the earlier frame with the upper shock mounts pointing down.
  6. John Shufelt Husqvarna
    Portland, Oregon
    On the frame I have the upper shock mounts are pointing up.
  7. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    You certainly could use shorter shocks, like 14" or 14 1/2" but if it was my bike I would use the correct 77/78 leading axle forks and triples and the correct 15" shocks. Just my opinion.
    Marty
  8. Bill502 Husqvarna
    Upstate NY
    I agree with Marty on the 15 inch shocks. it should be ok for trail riding,but I would look for a set of leading axel forks and triples I'm not sure if the Leleu hub will fit the Leading axel forks. .If you use 15 inch shocks with straight leg forks i would use the swing arm with the shock mounts closest to the rear of the arm that in theory should lower the back end till you decide if you want to change to leading axel forks down the Road.
    Bill
  9. John Shufelt Husqvarna
    Portland, Oregon
    Well it sounds like swapping the forks to the leading axel type is the prevailing opinion. Then I just keep the current CR swingam and get the 15 inch shocks? Does anyone have some pics of the correct forks I should be looking for?
  10. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Yeah but unfortunately it may not be the cheapest. Forks and triple clamps will run $200 - $300, then you'll need to rebuild them. Finding a pair with stanchions that aren't pitted could take a while. When you do find a good pair at an affordable price be sure they haven't sat outside in the rain, internal rust can be catastrophic. And like Bill said, the hub you may have may not be what you want. May have to budget $300 - $600 for a setup ready to go.
    Post a pic of the front end for us to determine the type of triple clamps and front wheel you have.
    Bill502 likes this.
  11. John Shufelt Husqvarna
    Portland, Oregon
  12. John Shufelt Husqvarna
    Portland, Oregon
    On page 1 there is a pic of the triple clamp as well as the front hub. The are from the WR. I think there is a pic of the forks as well in the previous pages of this topic.
  13. Crashaholic Husqvarna
    I'm not sure and I wouldn't trust the description. Some vintage Husky Ebay listings these days are inaccurate. You'll need confirmation from someone with good knowledge of this era like Marty. You don't want to get forks that are to long, i.e. from a later year. although you could let the stanchions protrude above the top clamp an inch or so.
    As far as your existing triples go, they will mount a set of 35mm leading axle forks but like it was mentioned, the bike wouldn't turn as good on an MX track or on a woods trail as the stock CR triples. From what I understand about the type of riding you plan on doing, you'll need the CR triples. They're similar to the ones on the forks in the Ebay listing you attached. They don't protrude forward as much as the WR triples.
    Also, I'm pretty sure that the 77 CR had the ball bearing steering race, 78 or 79 they went to the Timken bearing setup. The attached ebay listing does appear to be ball bearing to me, but once again you'll need to have someone more experienced in this era confirm it.
  14. Bill502 Husqvarna
    Upstate NY
    Thats my exact bike.
  15. Bill502 Husqvarna
    Upstate NY
  16. Crashaholic Husqvarna
    Nice looking ride. That pic came off the cover of Cycle Worlds On Husqvarna 1977-1984
  17. Crashaholic Husqvarna
    I thought so too.
  18. motomwo Husqvarna
    Imbler Oregon
    Crash, I agree with all you stated above. And to add to it the 78 390amx frame and 78 125CR frame was basically the same as the 77 250/390cr frame and the 78 390AMX frame and 78 125CR frame still used the ball bearing type steering races.
    John those would work. They have the races for the ball bearings. $425.00 with shipping is expensive in my opinion. If you want send me a PM.
    Marty
  19. Bill502 Husqvarna
    Upstate NY
    I have that book plus the one with the earlier versions of Husqvarnas.
    Bill
  20. Bill502 Husqvarna
    Upstate NY
    As to what Crash posted Husky always updated the CRs first and then used the older stuff for WRs and Autos till the older parts were used up.
    Bill
