gotcha. So how do I tell a wr rod from a CR? The 40mm forks I have are of unknown origin. But they are only a few inches longer then my 35mm forks. So perhaps these are already wr forks?I think you will find the damper rods from the 35mm forks will be too small in the diameter. I am sure it's the 40mm WR rods you need.
If it turns out I don't like the new geometry, I was thinking I could use a spacer in the bottom fork slider and be able to slide the forks up more in the tube so that I could match the 35MM ride height. Just a simple spacer slid into the bottom leg that would limit the travel of the chrome tube. What do the gurus think of that approach?
