1979 WR 250
Discussion in 'Vintage/Left Kickers' started by Eric The Leg, Dec 26, 2016.
  1. 84scrambler Husqvarna
    mid Florida
    I may have a pipe for your bike in my shed attic I'll have to get up there and take a peak.
  2. Eric The Leg Husqvarna
    Currently Tacoma, WA
    1986 WR400, 1985 WRX400, 1979 WR250
    83 Kawasaki KZ 440
    Let me know! The current pipe is easily repairable. For the right deal, it certainly wouldn't hurt to have a spare on hand (particularly if there's a silencer in decent condition involved).
    84scrambler likes this.
  3. Houredout401 Husqvarna
    New England
    '77 CR250 '78WR250
    '76MR250 '83IT250 '84 IT490 '69CT70
    I'm sending my entire pipe assembly to the pipe shop I have used in the past - Fusion One Cromwell CT. They do pipes for $60. Whatever dents they don't get out, I will then deal with by either cutting it open or using the stud welder to put pins on to pull. The silencer looks tough to plug in a way that would allow the heat/air technique to work, but if anyone can do it, it will be a pipe shop.
  4. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    Well, I pulled the top end. Feels like I'll be splitting the case and taking my crank and top end somewhere.
    There's no diagonal cross-hatching visible in the cylinder, just horizontal and vertical lines. Vertical lines come from the usual, I'm sure. If I had to guess, someone tried to remove the vertical lines with a hone, unless someone else has a better theory. The ring looks new to me, but piston definitely isn't. The vertical lines aren't that deep, so I suspect a .5mm overbore will get it. Overall the inside doesn't look that bad to me aside from noted items.
    The head nuts/bolts were definitely not torqued to spec (light), and based on the build-up around the edge of the head, it may have been run that way (or at the very least without the head lapped between top-pops).
    I guess as long as the boys are going in the cold water on this one, I should probably pick up a new ignition while I'm at it... The lighting circuit lead is AWOL (something I noticed previously, but was willing to ignore when my thought was to try to bring it up to riding condition on the cheap)....
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    gotta love seeing the gasket sealer on air cooled husky heads...always makes them leak!
  6. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    About a third of the cylinder base gasket was missing too. Add to that that there's enough oil (smells like gear, not mix) in the well to coat the crank when rotated... I think I've heard BigBill sing this tune....
    Bigbill likes this.
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    the only tune I can hear is " New Seals newsealsnewseal new seals"
  8. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    At this point that's a given.
    I need to get the case split and check the rest of the internals before I go off and buy parts. This one might be on hold (aside from further D&D) until my annual big paycheck.
    I'll work on a couple of minor projects on my other bikes, and maybe fine-tuning forks in the meantime.
  9. Eurofreak Husqvarna
    Western NY
    1986 TE 510, 1982 CR250, 2008 WR250
    70's Triumph , Bultaco , Maico, etc
    Well, keep us posted. Sorry to hear the crappy news
  10. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    It's not that bad, and I'm probably not on hold all that long in the grand scheme of things, I haven't had much time for wrenching lately anyway.
  11. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    So, question for a peanut gallery... At work they reassigned me to a new area and gave me a new team (because who needs to have balance between the time you spend to make the money to pay the bills, and having time to spend the money that's left over after paying the bills doing something you enjoy...), and of course, I tell them a 'lil'bout me, and mention my bikes.
    Later on, one of my employees asks me, "have you ever thought about getting into classic bikes?"
    Of course, I responded to her that 'some people would consider at 1979 Husqvarna to be a classic bike.'
    Granting mine is in bits right now. But I'm curious for others' thoughts.
    At what point do you consider a Husqvarna to be classic. And how do you respond to people who seem to think that only road bikes (likely Harleys, or maybe Indians) can be considered classic?
  12. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    in oz, classic is pre 78 (I think) and post classic to pre 90. these dates may change as age wearies us.
    your friend may think "classic" is anything from england
  13. justintendo klotz super techniplate junkie
    some people just dont get dirt bikes..kind of ignorant to not consider any of them classic.
    hard to say what is considered a classic..really a matter of taste i suppose, unless you consult race classes.
  14. oldbikedude Husqvarna
    Honey Brook Pa.
    classic is in the eye of the beholder
    Eric The Leg likes this.
  15. Eurofreak Husqvarna
    Western NY
    In cars don't they use 25 years old to denote classic and I don't know what to describe vintage?
    I figure anything that's older than most of your co workers is a classic :D
  16. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    Husqvarna classic any model from 1983 to 1984.
  17. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    I was thinking t this point twin shocks pretty much draws a line with most folks casually into dirt bikes.
  18. Eurofreak Husqvarna
    Western NY
    yeah, a few people were surprised about my twin shockers. The younger guys didn't know they came that way :D
  19. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    Been slowly working on things.
    After a bit of clamping, heating, pounding, cooling, heating, clamping, prying, pounding,cooling, heating, clamping, pounding, you get the idea, the rear portion of the frame is a lot better than when I started. Also, I've probably gone from 'intriguing new neighbor with several old motorcycles filling his garage' to 'persona non grata' within the neighborhood.
    I've also noticed that one of the rear motor mount holes in the frame is a little bit out of round. I can figure that one out, but in the meantime, if anyone else has run into that and has a sufficiently elegant solution to warrant mention, let me know.
    I've also been accumulating parts, I'll probably rattle-can the frame (if I ever do full restore, the frame would need significant sectioning or outright replacement), and start focusing on mechanical after one more clamp and burn session. Any suggestions for primer or a decent color match on the frame?
    oldbikedude likes this.
  20. suprize Husqvarna
    Bendigo, Australia
    ktm 300
