1980 390CR Rebuild by Moody390
Discussion in 'Vintage Restoration Projects' started by Moody390, Jun 11, 2009.
  1. Moody390 Husqvarna
    Western Australia
    The Old lines are a 1/8" BSPT thread. The new ones were NPT, so I reverted back to the originals.
    Brakes are all sorted. Last thing I'm struggling with is the tuning side of things, Its all jetted up and fires 1st kick every time now, THO only when the plug is dry. After I kill it and check the plug, it's saturated. It also struggles a bit to idle.
    Any Suggestions? Ive dropped the needle to the bottom position and wound out the Air screw to lean it out. I'm guessing a smaller pilot? maybe down to 17.5 from 20?
  2. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Are you using the 38mm round slide Mikuni that you show in the pic earlier in this thread? If so, something is 'seriously wrong somewhere' if you are running a 20 pilot and the motor is saturating the plug. Could be ignition, could be wrong jets, could be right jets that are worn out... As a start, can you please post ALL your jets? That would be pilot, slide number, needle jet, needle, clip position, main. Everything. And where did you set the timing?
  3. Moody390 Husqvarna
    Western Australia
    I was using the UFO Carb piece from Thunder products, It creates a greater venturi effect in the carby and helps with the low end response. To use this, because of the greater suction of fuel, it requires halving the size of your pilot, hence the reason it was so small.
    I found the problem with the over fueling, the UFO wasn't seating in the bottom of the carb, leaving about 8mm of gap between the bottom of the slide and the carb. I pulled it out and went back to a 50 pilot, no more saturated plug.
    Now my spark has disappeared, it was intermittent in periods, but now its gone all together. Ill try a new plug cap first then ill toss the motosplat.
    Carb specs are:
    Mikuni 38mm Round slide Venturi
    480 Main Jet
    50 Pilot Jet
    3.0 Slide
    6F15 Needle
    Q8 Needle Jet
    Needle clip is 2nd from the top
    All the jets and associated parts are brand new.
    B8EGV Plug aswel
  4. Picklito Husqvarna
    Washington
    So that jetting looks much better. Should be "on the map" so the bike will run and you can fine tune it from there.
    Motoplat is a good ignition, but it does require a good frame ground. You might have to go through the entire path and clean the paint from the motor mounts, from where the coil mounts, and where the stator mounts to the engine cases. And snip a half inch off the plug wire when you put the new cap on so that it screws into clean fresh copper wire. Gap .024" and RUN IT!!
  5. Moody390 Husqvarna
    Western Australia
    Good Point about the earths. Makes sense why the spark was intermittent. Cases are internally bare so that should be a good earth. I'll pull the engine mounts and check the coil mounts. I did clean the earth mount for the kill switch, but not the motor.
    Thanks Mate!
  6. Moody390 Husqvarna
    Western Australia
    Thank You Very Very Very Very much Picklito hahaha.
    I pulled the coil, noticing I had it mounted on the left side of the bracket, and it was showing rub marks from the tank pressing against it. I was only earthing it through the bolts and bolt holes which I had removed the powder coat. I grabbed a file and cleaned the bracket on the right side (the correct side) to bare metal. Gave it a crank, and spark! I fitted the tank, seat, and gave it fuel. Kick, Kick and Fire! Ran it for a bit. I killed it, checked the plug, ran it again. First kick fire, twice more the same outcome.
    Really happy now. Thanks mate. Without a doubt, It doesn't start like any Husky I've experienced.
  7. Picklito Husqvarna
    Washington
    Well, then... I guess your next post will be the ride report??? With pics! Awesome.
  8. Moody390 Husqvarna
    Western Australia
    Will do. I have to fly out to work in a couple of days so will be hitting the bush when im back in about 3 weeks! pics to follow.
  9. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Moody390,
    Make sure you check the length of bolt on your rear brake pivot arm mounts to the frame (rear brake pedal pivot too). Looks
    from your picture like it will hit the chain. Test fit your chain before you go ripping around & break something. On my 82 430,
    the chain "c" clip would pop off sometimes when i'd roll it off the truck, couldn't figure out what was going on until i saw my
    bolt/nut would some times contact the chain. I reverse my bolt so the nut is on the brake pedal side & used a low profile
    socket head bolt on inside of the swingarm, problem solved :thumbsup:
    Husky John
  10. Moody390 Husqvarna
    Western Australia
    Those pictures are from assembly when everything was getting mounted, all the bolts were cut to the correct length when it was completed. Thanks for the heads up tho.
  11. Moody390 Husqvarna
    Western Australia
    All finished now. Some Husky Products foot pegs on the way. Heading out for a weekend of riding coming. will see how the shocks go. Got a feeling ill be replacing them for a set setup for me.
    dartyppyt likes this.
  12. Moody390 Husqvarna
    Western Australia
    Well the bike went well. Ended up with a Vintage Iron Pipe. Thanks to Rick for a 5 day make time and having it on my doorstep a week after. installed a folding tip shifter, new front plate, new air filter, husky produgs foot pegs and all the last bits. It goes a hell of alot better than i remember. And crazy loud. Even with only 80psi in the shocks, they actually went well.
    Tuning is pretty close, a clip up on the needle should do it.
    Next up is hunting down a set of upside downs, front disc and tripple to tie into it. Drums just don't do such a nice bike justice. Will keep updated.
  13. HuskyT Moderator
    Corona, California
    Sweet Good Job Moody
    T
  14. Moody390 Husqvarna
    Western Australia
    I've been bush a couple of times now. bike is just about spot on with the tuning now. Here's a shot with my mate 85 Yz250. 03 brakes and rims, dg pipe etc.
    I've got a couple of short vids on my face book. When i figure out to to upload them here i will.
    huskybear likes this.
  15. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    great story and details. book a two week trip to the harrow enduro nxt year!!
  16. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Noooooo ..... not upside downers ! That'll spoil a superb rebuild (IMO).
    Husky forks can work well. Mine are stock and are superb. The faster you go, the better they work. My front drum is excellent. I find using a set of EBC grooved shoes, and a bit of time arcing them works very well. It will lock the front on tarmac easily.
    Superb job on the resto. What's your next project ?
  17. Moody390 Husqvarna
    Western Australia
  18. Moody390 Husqvarna
    Western Australia
    I'll dig this old thread out instead of posting new ones.
    The yellow oval side panel decals to suit the 81 side panels. Anyone have a source? the home cut ones are a bit average. If there are none out there, i'll head to a sign makers shop and get some hopefully made.
    Also, Bike now runs black fenders and have a billet works style brake pedal on its way from husqvarna parts.... my number 1 stop shop haha.
    Not much else has changed yet except the hours on it.
    Thx
  19. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    harrow is on the last weekend of july, book early to avoid disappointment.....
  20. Bigbill Husqvarna
    '83 250wr
    0 right now
    I fit the UFO to the sleeve then conture the arc for better flow. They work great. My pilot size was 35. Yours may vary. It's worth it using the UFO.
