1981 430 CR Restoration Mod. Project Bike
Discussion in 'Vintage Restoration Projects' started by highdez1981430cr, Nov 17, 2009.
  1. HuskyT Moderator
    Corona, California
    They look good !
    HighDez.. did you get my post about the photobucket acct... check your pm?
    Putting a compressed zip folder in here is overkill. Let me know if you still need help or if you got the pm linking to the photobucket imaging instructions.
    T
  2. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    more nickel plated bling for the swingarm
  3. schimmelaw Husqvarna
    Rowlett, Texas
    Highdez,
    Corrosion resistance w/ a shine. Better than stock ever was. Looks good. Nice progress.
    Rick
  4. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    I did it just for you Rick,
    I know how you love the shiny stuff.
    More nickel plated goodies to come as soon as i fiqure out Photobucket.
  5. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    more nickel stuff for miss Husky
    The kickstarter was what started the whole nickel plate thing.
    I was looking to tighten up the clearance to reduce slop.
    It is now perfect:thumbsup:
  6. schimmelaw Husqvarna
    Rowlett, Texas
    Hidez,
    I like shiney. That stuff looks shiney. I like those parts.
  7. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    fresh from the painter
    This is almost to nice to mount up:thumbsup::applause:
  8. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    BRP raise and offset perches with titanium hardware
    The ultimate in light weight and roominess (430 grams, how appropriate for my 430) SWEET!
  9. HuskyT Moderator
    Corona, California
    Very nice! Who/whom is your painter?
    Can you post information on the black paint ( specifics ) that I can add to the Tech Ref Forum. Please post up details.
    T
  10. HuskyT Moderator
    Corona, California
    Are these BRP Mounts with the bolt heads machined for weight savings? Drilled washers?
    Titanium Bolts?
    T
  11. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    Really enjoying your build-up, Mr. Dez. Keep it coming...
  12. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Contact John Kovalick,
    6526 west yellow blvd.
    Phx, AZ. 85085
    I have no idea what he shot it with but it looks nice!
  13. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Yes, BRP perches.
    I drilled a hole at the same offset just under the minor dia. of the 12mm thd. for lightening purposes.
    Washers and screws are titanium from Racebolts.com and they are drilled and machined for maximum lightness.
    I will check the weight the stock perches and hardware just to see what kind of weight saving i got.
  14. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Thanks Pick,
    Just recieved my new ignition yesterday so i pulled the stk. Motoplat.
    Having trouble removing the crank seal retaining plate though,Any suggestions?
    Got it sprayed down with penetrating oil and was tapping on it with a 1/2" alum. rod with no movement.
  15. Up-tite Husqvarna
    Putty knife. George
  16. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    Good call George,
    I need to send you my kickstarter case to look at.
    Can you do anything to get the pawl to engage sooner?
  17. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    J.D. Jetting 38 mm Keihin PWK air striker carb upgrade
    Inlet spigot is 3mm larger than than stock 38mm VM Mikuni but fits nicely, just make sure the rubber is fresh and warm.
    overall lenght of the PWK Keihin carb is about 6.5mm shorter than the Mikuni so iam fabricating a 1/4" phenolic spacer to put it in perfect position for full air filter boot engagement.
    Added benefit to the phenolic spacer is thermal insulation for the reed block and carb and a longer intake producing a little more torque.
    Contact J.D. jetting at:
    jdjetting.com
    complete carb with J.D. jetting kit is only $239!
    Bangin deal :thumbsup:
  18. Husq.fleet Husqvarna
    Pendleton Oregon
    Kick it through hard a couple of times-worked for me!!! Scott
  19. Picklito Husqvarna
    Washington
    Does he do the required metal straightening to the tank? Or did you have to have it straightened somewhere else first?
  20. schimmelaw Husqvarna
    Rowlett, Texas
    Dang Dez,
    Looking great. Nice work!
