1981 430 CR Restoration Mod. Project Bike
Discussion in 'Vintage Restoration Projects' started by highdez1981430cr, Nov 17, 2009.
  1. firecrackerkid Husqvarna
    Grand Coulee, Washington
    78 390 OR, 84 250WR, 83 175WR
    My last high speed trip down pismo was in a mitsubishi lancer rental car :) November 2003
  2. Motosportz CH Sponsor
    Lectrons have this circuit as well, works great.
  3. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    Fun looking bike especially on dunes! I'm curious....whats the thingamajig on the end of the swing arm on the left side? Its visible in the picture at the top of this page.
  4. adam6402 Husqvarna
    Tulsa, OK
    None
    My guess is a dunes flag holder?
  5. oldbikedude Husqvarna
    Honey Brook Pa.
  6. Motosportz CH Sponsor
    How is the head decomp working for you? You have to push it down every time you kick? Thanks.
  7. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    It works great!
    one of my favorite mods.
    Yes, you need to depress it each kick.
  8. Motosportz CH Sponsor
    Push down, EZ kick, when it starts if closes? Might have to do this to my 83 XC 500.
  9. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    kick through 7 times to prime carb with comp. release depressed.
    pull out comp. release and put piston at top dead center.
    depress comp. release button and boot it.
    My bike starts first or second kick cold and first kick hot.
    These things were made for big bore bikes!
    Racers machine in Escondido,Ca. did the work for me.
  10. Walt Hastings Husqvarna
    Santa Clarita, Ca
    2013 TC449, 2013 TE449, 1972 450CR
    Victory Cross Country Tour
    highdez: Im helping a friend trying to get his 1982 430XC running again, ( in storage for 15 yrs)... What oil do you recommend for the transmission, and also your recommendation for lubricating oil that is mixed with fuel,( type and mix ratio)?
    Thanks ,
    Walt
  11. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    guess i never answered this question, old bike dude gets it.
  12. highdez1981430cr Husqvarna
    Yucca Valley,Ca.
    In the crank case i run walmart 30 wt. non detergent and change it after every ride. premix i love Blendzall 20 to 1 in the dunes and 40 to 1 play riding in the high desert and with my intelijet set up i can adjust jeting with the twist of the tank mounted knob to make up for the oil ratio differance, Blenzall runs a little dirty but the flashback aromatherapy is worth it.Hey there is a company out there that even makes Blenzall candles, try that for your next candle light dinner!
    If this bike has been in storage that long i would do a leak down test to check out the integrity of the main seals as this will cause the bike to run lean and possibly seize.
    Walt Hastings likes this.
