1981 430XC Street Legal Motard Conversion Project - Schimmelaw
Discussion in 'Vintage Restoration Projects' started by schimmelaw, Nov 3, 2009.
  1. HuskyT Moderator
    Corona, California
    ok more questions:
    1) black ano rear sprocket? hardcoat or standard ano?
    2) Plastidipped airbox mounting strips? more detail please. Are these the black plastic ones from Phillip? I like.
    3) Rubber stick on tabs...where from? size/diameter/thickness?
    4) does the twin air have an internal cage... if so .. picture please!
    5) what keeps the new cover from flopping open? or forward if you will?
    Very nice!
    T
  2. schimmelaw Husqvarna
    Rowlett, Texas
    HuskyT,
    1 Anod - future post.
    2 Photo 1and 2: I dipped each clamp one time in the plasti dip product. As I remember, the airbox cover mounting clamps were loose and w/ the continuous vibration would wear the paint down on the frame where they attached. Didn't want to go through that w/ this bike so each got "dipped" to coat and take up a little of the looseness. W/ one dip the clamps are protected and snug. (Air box cover still rotates opens easily - but it doesn't just flop open) Yes, the ones I used were from Phllip. Replacements can be purchased at any home improvement center. 3/4" cable clamp.
    3 Rubber bumpers are just some I had. About 3/8" round and about 1/8" thick. Home Depot has something similar. Think cabinet door bumper.
    4 Photo: Air filter cage as requested. Black powder.
    5 Cover has a lip that fit under upper frame tube. Cover will also sandwich btwn the rear number plate. Plastic coated clamps help, too.
  3. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I like how you plumbed the crankcase vent hose into the airbox. Can we get a pic of the fitting you put in the airbox please? Thanks, man.
    And GREAT idea to plastic dip those airbox lid straps. They DO flop around and they DO wear right down to the metal. This sounds like a very effective fix. Nice detail!! (and I just happened to choose the exact same straps. Home Depot I think).
  4. schimmelaw Husqvarna
    Rowlett, Texas
    Pick,
    Thanks.
    Just a gromet from local hardware store (Home Depot? - i think). Took the hose w/ me to the store and found a grommet that fit real tight. Took everything home, drilled box to fit grommet, slid hose through w/ some slack in the box, mounted up a UNI breather, done.
    I was going to try a wrap some clear number plate background strips around the frame where the clamps go to aliviate the wear. W/ a little more thought I realized that would eventually lead to a big sticky mess and I would have created a problem rather than solving one. Had the plasti dip for some other parts and thought .....why not give it a try..... Only one dip is needed for the air box cover side. (Two dips takes out ALL the built in tolerance and you can't open the cover b/c the clamps won't rotate on the frame - ask me how I know). Two dips, maybe, for the left handside number plate b/c its stationary.
    Rick
  5. schimmelaw Husqvarna
    Rowlett, Texas
    Chain Tensioner (prior post) mounted up.
    Photo 1: Stock wheel cleaned up and reused w/ new bearings from local bearing shop. Aluminum arm was replaced by steel. I punched the holes for fun. Concho for fun too.
    Photo 2: View from top. Nickled and sleeved tension spring. NOS aluminum bushing w/ some new o-rings resides under all that.
    Photo 3: Back side view. Sleeved spring to proctect the swingarm finish. Ssteel and anod aluminum mounting hardware finish up the resto.
    Done.
    Photo 4: Why I had to redo to begin w/. Arm garred up, mount holes wallowed out, and overall disrepair. Chain tension bushing was completely seized in the mounting tube and was FUBAR in its removal. Bushing required an air hammer to remove it.
  6. Leftcoast leftkicker Husqvarna
    encinitas ca
    Schim- you're killin' me!
  7. schimmelaw Husqvarna
    Rowlett, Texas
    LCLK,
    Is that a good thing or a bad thing?
    Kickstand mounted up. Lame update i know but that is all I have done this week. Rebuild (bent and mounting tab) is a prior post.
    Photo 1: Went w/ black for the contrast and this stand may have to be cut down once tires are mounted up. Won't know for awhile. If it does have to be cut and rewelded, I can just paint the lower end black and no one will know.
    Photo 2: Backside view. Nickled and sleeved spring.
    Photo 3: Front side mounting hardware. Ssteel bolt w/ flange nut and anod conical washer
    Photo 4: My spring pullers. Bethca can guess which once I used for that bada-s kickstand spring. Spare stand that got the resto treatment too. This one is frame silver for future (waaaaaaaaaay waaaaaaaaay off in the future) project
  8. Picklito Husqvarna
    Washington
    Did we ever discuss what color you used for the frame? It looks pretty darn close to that bizarr-o silver the factory used (which I love).
  9. HuskyT Moderator
    Corona, California
    Creative use of FUBAR. I love it. Concho. Pancho Villa would be proud. John Wayne would be prouder. Style points for you brother.
    T
  10. HEMITKN Husqvarna
    York, PA
    WOW what a build I've seen works bike not as tricked out. Well, would put a period correct works Husky to shame. Beautiful work.:thumbsup::applause::notworthy:
  11. schimmelaw Husqvarna
    Rowlett, Texas
    Pic,
    The frame had been rattle can painted when I got it and I really didnt have a clean good base color to work off of. Powder is based off of the wife's Yamaha XT225 silver. I just went w/ something I liked. Didn't really try to match up to the stock Husky silver.
    Hemitkn,
    Thanks. Its been alot of fun.
    Photo 1, 2 and 3: Business side of the rear guide and backing plate. Both are prior post .
    Photo 4: Front side.
    Photo 5: My "Made in Sweden" sticker proudly displayed. Thanks, HWY.
  12. Husky37 Husqvarna
    UK
    84 CR500, 85 CR500, 89 TE 610
    It's gunna be one 'ell of a bike when you're done..... :notworthy:
    Did you make the new rollers for the chain guide or are they available off the shelf?
    Stu
  13. Hwy Mini-Sponsor
    SF Bay Area
    '86 510TX / '90 250WXE / '87 510TE
    '04 KTM 525MXC / '91 KTM 300DXC
    Great looking. I like your attention to detail.
    What kind of material are you using on the chain guide? That looks like a pvc of some type.
    I have some UHMW Polyethylene that I's like to try for the same thing. Thanks for the idea.
  14. schimmelaw Husqvarna
    Rowlett, Texas
    Husky37 and HWY,
    The whole rebuild is here in Vintage. The search is "chain guide before".
    The key part of the guide is the expanded upper aluminum mount. (Photo 3) The original bushings were lengthened to accomodate the larger rollers and the nylon wear pads then tacked to the aluminum mount. It then got anod as one part versus three.
    Its expansion has lead to a clearance issue between the lower roller attachment hardware and the sm rim. Its going to be close. Thats why the lower roller anod conical washer is on the inside - need the clearance right there. Don't know if there would be any issues w/ a dirt oriented setup.
  15. schimmelaw Husqvarna
    Rowlett, Texas
    Fork'n A
    The heart and kinda soul of the conversion. Current USDs which support an EBC sm rotor.
    Photo 5: Bushing which made it all possible
  16. rajobigguy Administrator
    So.Cal.
    I'm really loving this thread. This is one of those projects that I always wanted to do but the logistics of living in Ca, prevented.:thumbsup:
  17. Husky37 Husqvarna
    UK
    The fork conversion is sweet and very clean.... hat off to you.
    I've come across the same problem with the Husky head stock being short compared to say late KTMs... other than shortening the stem or pressing in a Husky stem there is no other alternative but to put a spacer at the bottom.
    BTW. Thanks for the pointer on the Chain Guide.
  18. NYWR430 Husqvarna
    NY
    Schimmelaw,
    Do you think hydrogen embrittlement is a concern with the springs that you are nickel plating? Are you performing a post-plate baking or is it not an issue? I'll be performing some similar plating operations on my project and was wondering if I'll need to bake the items afterwards.
  19. schimmelaw Husqvarna
    Rowlett, Texas
    Rajo and Stu,
    Thanks guys - have had a blast! and killed alot of time.
    NYWR430,
    I don't have any concerns w/ the parts/springs I have been plating. Anything I might do/or have done to the parts on this bike is an improvement over what I started out with. Most all parts have been abused, neglected or just plain-o wore out. I figure you can't really hurt something that messed up already - sooooooooooo - why not.
    I have no idea how the nickle plating process works. I just sand blasted everything, drop my parts off at a buddy's shop (w/ a bottle of whiskey - Canadian Club to be exact) and pick them up when he calls. I will say that the nickle plating process is the way to go for our old parts. A little prep work, drop off and then pick up some brand new looking components.
    Rick
  20. HuskyT Moderator
    Corona, California
    Hydrogen embrittlement post bake is necessary on the aircraft seat belt buckles that we make in our shop .... basically relieves stress....
    Answers the question of " does the seatbelt buckle shear or brake before the web of the seatbelt cuts through a body moving at xxx speed on impact..."
    Not exactly a requirement that we need to worry about on some old Moto parts...
    T
