1983 Husky 430WR Resto NETRA Hare Scrambles
Discussion in 'Vintage Restoration Projects' started by MikeDi, Sep 30, 2016.
  1. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    Stuck in the 80's vintage
    :doh: Back to business. got a load in from HVA this weekend. sprockets, chain tensioner, guide, plug cap, cables, an assortment of other goodies. Piston is in, new bore, 1st over. can't wait to start some building. everything is cleaned and ready to be put back together.
    oldbikedude likes this.
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    packages from andy are the best! the cast magneto covers are excellent.
    MikeDi likes this.
  3. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
  4. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
  5. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    the chain guard is upside down isn't it
  6. justintendo klotz super techniplate junkie
    doesnt look right
    did you pick up a liquid cooled clutch arm? nice easy upgrade for the straight arm. i have some extra if you cant find one.
  7. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    I did get a clutch arm from HVA. It's a little longer than the stock one., thanks for offering.
  8. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    the chain guard is upside down isn't it yes :)
  9. Bigbill Husqvarna
    '83 250wr
    0 right now
    Your using all the chain guides and tensioner. That's a good thing. Without the chain tensioner when the chain whips off the sprocket she can crack the case where the clutch lever vertical shaft is. I seen it happen. Most of the used bikes I seen were missing these chain parts. Don't forget the up stop roller in the frame too. It's a 3/8" piece of nylon on a 6mm bolt. I've seen these replaced with a wheel.(roller). That tube welded on the frame is where it goes.
    MikeDi likes this.
  10. Bigbill Husqvarna
    '83 250wr
    0 right now
    I n
    I never got to ride the berg in the trails before the case cracked. It did feel good around the yard when I rode it. Different response power wise. They called it a 3 stroke. That little button we push to start it was awesome. Now decades later the e start is catching on in the 2T. The berg was a good bike till the dealer sabataged it.
  11. Joe Chod Husqvarna
    upstate NY
    Bill
    What do you mean by "Don't forget the up stop roller in the frame too. It's a 3/8" piece of nylon on a 6mm bolt. I've seen these replaced with a wheel.(roller). That tube welded on the frame is where it goes." What is the up stop roller?
  12. Bigbill Husqvarna
    '83 250wr
    0 right now
    I call it a up stop roller because it eliminates / stops the chain from up traveling or slapping when we down shift. That little welded piece of tubing on the frame is often overlooked and vacant from having anything in it. With some pics if we look closely the 6mm bolt and the piece of nylon is there or it's a chain roller. In Other pics it's missing.
  13. Bigbill Husqvarna
    '83 250wr
    0 right now
    L
    Look at the pic. It's between the swing arm bolt and the output shaft. It's above in the middle on the frame.
  14. Bigbill Husqvarna
    '83 250wr
    0 right now
    http://www.cafehusky.com/attachments/84-husky-250wr-mine-1-jpg.54805/
    Here's a bike with the white roller. It's above the chain. Originally it's a nylon sleeve about 1/2" round. I believe this up stop limiter comes into play when the suspension is fully compressed. I think it keeps the chain at a proper angle so it feeds into the drive sprocket correctly. I purchased the nylon sleeve and bolt on eBay used.
  15. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    up stop? never ever seen this on a milk truck bill..we went thru this in a previous thread. only the single shockers have it. it isn't in the parts manual
  16. Bigbill Husqvarna
    '83 250wr
    0 right now
    It's on every milk truck bike. It's missing on most of the bikes. It's a bearingless piece of nylon held on by a bolt. We talked about this before in a thread I got the pic from.
  17. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    Thanks, I need to rig up top roller for sure.
  18. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    the chain tensioner was missing as well as the top roller. I figured I'd get all new anyway and not mess around. I don't have the countershaft sprocket cover either.
  19. Bigbill Husqvarna
    '83 250wr
    0 right now
    The chain cover protects the chain if it should come whipping off and cracking the case too. We must have all the chain guides and tensioner in place. Always make sure the chain is tensioned properly. The tentioner is very important on every bike.
  20. justintendo klotz super techniplate junkie
    the countershaft cover is a waste of time, and just packs with mud and stones. most guys who ride these bikes leave them off as we wear motorcycle boots riding them.
    the reason they are always missing, is husky themselves put them on so few bikes.
