1983 Husky 430WR Resto NETRA Hare Scrambles
Discussion in 'Vintage Restoration Projects' started by MikeDi, Sep 30, 2016.
  1. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I don't have my tensioner fitted, I have a very worn rear chain guide with the top and bottom roller all sloppy and ive never had any chain dramas. ive set the tension just right, made sure its aligned straight and its good for 80mph in the desert, mx, log hopping and gnarly off road. an old husky man told me years ago to junk the tensioner as they wear out on a muddy ride and then cock your chain at a funny angle, risking a derail. as for the top roller on a milk truck...never had one and never had a chain derail.
    justintendo likes this.
  2. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    Stuck in the 80's vintage
    one more question, is the top roller the same as the bottom roller on the tensioner? It seems to look that way on the diagram.
  3. disonny Husqvarna
    upstate ny
    73 360 wr/rt, 75 wr250 78 cr250,
    83 wr250, 84 wr400
    I just looked thru the parts list. That upper roller is only listed for the 125. My 400 frame looked like nothing was ever on there.
  4. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    correct. not required on the bigger bikes
  5. Bigbill Husqvarna
    '83 250wr
    0 right now
    Then why did I see some bikes that have it?
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    im sure some people add them
  7. Bigbill Husqvarna
    '83 250wr
    0 right now
  8. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    That's about all you can get out of that suspension. :D
  9. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    It can't hurt
  10. justintendo klotz super techniplate junkie
  11. Bigbill Husqvarna
    '83 250wr
    0 right now
    I'm thinking the gas hose would be close to the diameter of the orginal nylon. Plus to test it and see if the chain actually rubs against it.
  12. Bigbill Husqvarna
    '83 250wr
    0 right now
    Mike the '83/430wr is a great woods bike for the northeast. My son was pretty quick on his. It's controllable power band and tractor like power.
    I purchased one 83/430 form a guy who had it apart and said it needed a clutch because it was slipping. I couldn't find any wear on the clutch. I adjusted the center release rod to the proper setting, reassembled the clutch and off she went. The used clutch was perfect.
    MikeDi likes this.
  13. Mogly406 Husqvarna
    Rhode Island
    '84 250WR '87 250WR
    '14 Husaberg TE250
    MikeDi likes this.
  14. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    Easy to take the shocks off on a twin and check the tension of the chain through its full movement i used a rm 125 chain guide to rear sprocket, a roller as the upper stop? And added a extra roller on a arm attached to the brake pedal bolt, works fine easier option than original and seems bullet proof, chain rollers take up the slack and guide feeds direct onto rear sprocket.broken spring on original tensioners could equal massive destruction from chain.probably neve r happen but everything happens e ventualky.
    Ps :I hate my touch scrreen.
    MikeDi likes this.
  15. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
  16. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    disonny and oldbikedude like this.
  17. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    I just got mine from DC thursday. Mine took a bit to get them fitted good.
  18. MikeDi Husqvarna
    U.S.A. New England
    1983 WR 430
    Yeah. I need to bend mine a bit.
  19. disonny Husqvarna
    upstate ny
    83 wr250, 84 wr400
    I had to trim both side panels and also my radiator shrouds.
  20. Joe Chod Husqvarna
    upstate NY
    Do not know if this was said but that upper roller was only used on 125/175. Period. Mount location is there as they ALL used same frame. Period. Had them in 83 and have them now so do know "how they came".
    MikeDi and disonny like this.
