1983 XC500
Discussion in 'Vintage Restoration Projects' started by DeathFromAbove, Oct 15, 2017.
  1. oldbikedude Husqvarna
    Honey Brook Pa.
    Bet It'll look great.
  2. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    It will look awesome!
  3. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    The thing will not run if you do not remove the PC off the front mounts on the frame and the contact points on the front mount plates.
    DeathFromAbove likes this.
  4. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Yeah, those made it past the QC, ME! I'm going thru Andys site and will be getting the titanium replacements. Then I can eat an extra nacho! Thanks Chris
  5. jimspac Husqvarna
    Connecticut
    I was surprised no one else pointed it out. Easy to overlook though until you get stung
  6. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    I got the swing arm bearings in, using the HVA tool. And will ad the replacement chain tensioner mount tomorrow. Still waiting for the zinc plating place to call . Hopefully by Friday. They have parts for the 500 and the 360 auto so if I get them there will be some real progress on both bikes.
    arbortodd2 and oldbikedude like this.
  7. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Who's got the best Plastics for this year bike? Closest to original. Decals also.Chris
  8. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Maybe that's a loaded question. How about, If you've bought plastics for these bikes how do you like them.:thinking:
  9. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    DC plastics. you can purchase a whole kit from them for that exact bike. around $240.00 total. evomx.com for decals not sure on their price.
  10. wrx Husqvarna
    845 newyork
    sorry $185.00 complete kit for that bike. $240.00 is WR pricing
    oldbikedude likes this.
  11. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Thanks wrx. I was looking around and saw that dcplastics, HVA factory and Husqvarna-parts.com all sell them but Husqvarna-parts.com says...
    NOS AND NEW 100% CORRECT REPRODUCTION PLASTIC
    OUR PLASTIC IS PRODUCED BY A 30 YEAR OLD U.S.A COMPANY THAT SPECIALIZES IN MOTORCYCLE PLASTIC.
    WE OWN OUR MOLDS AND OUR PLASTIC IS ONLY AVAILABLE FROM US.
    WE DO NOT SELL ANY "DC PLASTICS".
    Has anyone used both vendors plastics? Are they really that different? From the sounds of it they are night and day different. Just asking.
    Also I got the new clutch cover painted and went to change the kick mech over and found this! IMG_20181225_120814.jpg1.jpg The spring holder looks worn out on the front cam section and the front screw is almost bent in half! If anyone has a newer one to compare please attach a pic. Otherwise I'll probably weld that section and reform it. Thanks Chris
    Merry Christmas!
  12. arbortodd2 Husqvarna
    83 xc250
    I bought one of those swingarm bearing tools. Great investment, as it saved me a lot of time and effort persuading the bearings.
  13. arbortodd2 Husqvarna
    83 xc250
    I bought a set of the side panels from Phil at Husqvarna Parts. The look Oem and fit perfectly. image.jpeg
    Decals came from Evo-MX.
  14. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Yeah, when I got the bearing driver I was like that is huge! :eek: Hahaha! It didn't look that big in the pic. It worked Perfect! I'll probably go with the ones from Phil at Husqvarna Parts. Hopefully shipping isn't as bad as from England! Although I still see some things I want from HVA. Are the decals from Evo-MX the right color? I've seen some post about the color being off on decals from somewhere. And Todd, Nice Bike!:cheers:
  15. arbortodd2 Husqvarna
    83 xc250
  16. arbortodd2 Husqvarna
    83 xc250
    I can't be certain about the correct color, but they are the only yellow item on the bike, so hard to compare.I have the tank decals, also from Evo-MX across the pond but need to send the tank off for painting first. Appreciate the compliment.
  17. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Got the ignition in and timed. And installed the new clutch drum and mocked the clutch cover to check the kick stroke. It engages pretty late, even after I welded the spring holder. I think I'll weld the holder some more to bring the engagement point a little higher.
  18. ct cr430 Husqvarna
    Connecticut , litchfield county
    1981 cr 430
    2007 honda crf450
    Can you show a picture of how you are trying to change the Kickstarter engagement ?
  19. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    you sneaky dog! when did you acquire the four stroke cover? good work, its the way to go!
  20. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    Picked it up on ebay, same with the clutch cover. I like them both, you can see the pin go into the shift return spring. Much better than a welded, dented cover.
    It wasn't too awful bad to make happen. In the first pic is my first attempt to move the stop. when I test fit it I found the lever was about 2oclock not enough to get onto the next forward spline. The closer to the first cam lobe the more it brings the engagement forward. But you have to watch how the lever stops. It has to stop before hitting the cover. Thru trial and error(3 tries) I got it to the second picture, the chalk points at the starting point. The third pic shows the new engagement point. A much better engagement point I believe. But I HAVE NOT TRYED TO START THIS 500XC MOTOR WITH THIS SETUP!! The fourth pic shows the clearance at the cover for the lever and pivot. I do not have an bumper stop yet but will show it when I get it. For now I think it is pretty good. If it works out for me I'll probably have a few made. The factory made that piece that way for a reason, and I'm just a field hack! My problem might be the combination of a newer lever and an even newer cover I do not know. I will probably use the upgrade to use that spare hole on top of the cover too. If this looks like a problem please let me know BEFORE I try to start the motor. Thanks Chris
