1984 WR400 help
Discussion in 'Vintage/Left Kickers' started by tonyvisone, Nov 6, 2015.
  1. tonyvisone Husqvarna
    1984 WR 400
    harley, gsxr, klx110, 400ex
    i made a halls order today. they looked up some rubber exhaust dampers for me and found one similar to the larger rear one. i bought 3 just in case i can make them fit the front, but if not then i have 2 spares for the rear.
    so this means that everything aside from the front 2 exhaust dampers is purchased. clutch cable arrives tomorrow (1/8/16). i brought my original cable home so i can compare them without waiting to go to the bike.
  2. tonyvisone Husqvarna
    1984 WR 400
    And these goods ready to go.
    This was the only lapping compound local shop had. Any objections on this oil let me know please!! Thanks
  3. tonyvisone Husqvarna
    1984 WR 400
  4. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    Looks good.
    I personally use the Briggs n Stratton SAE30 but it's probably exactly the same.
  5. oldbikedude Husqvarna
    Honey Brook Pa.
    That lapping compound is fine.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    good choice on the paste..is the oil jaso-ma rated or specifically recommeded by someone here to work??
    if not you run the risk of making the clutch slip, and it can be difficult to eliminate.
    plenty of oils that work have been listed here, or its been recommended plenty to find jaso-ma rated oil
  7. tonyvisone Husqvarna
    1984 WR 400
    I was looking for Briggs but could only find this. I'll look for Briggs again
  8. tonyvisone Husqvarna
    1984 WR 400
    The new cable came in, it's about 1/8 inch shorter than the original. Not much but it can't hurt!
  9. oldbikedude Husqvarna
    Honey Brook Pa.
    I run a home made flanged brass shim to tighten the fit at the case end. helps make it feel a little more "positive". clutch cable shim.JPG
    everfree and justintendo like this.
  10. justintendo klotz super techniplate junkie
    lil better transfer of force for sure
  11. tonyvisone Husqvarna
    1984 WR 400
    if only i had a lathe!! i might be able to get access to one if its thought that a bigger shim is acceptable.. ill see how much i would need in the coming week when i get to the bike
  12. Aviyaytor Husqvarna
    Argyle, Texas
    1984 WR 400 L/C
    '73 Kaw G5 100 '07 Kaw KLR 650
    That is awesome, Tony!
    The person who owned the bike before me also an 84 wr 400 cut off the kickstand bracket! I have been looking for a kickstand and spring and will fabricate a bracket when I find one. I can use this pic as a template of sorts.
  13. tonyvisone Husqvarna
    1984 WR 400
    glad i could help, thats why i try to post so many pics. words are boring. if you want dimensions let me know
  14. tonyvisone Husqvarna
    1984 WR 400
  15. justintendo klotz super techniplate junkie
    just get some jaso-ma or motorcycle oil...why so obsessed with lawn mower oil?...bizarre
  16. tonyvisone Husqvarna
    1984 WR 400
    Haha idk because everyone said that Briggs and Staton is the way to go. Will find some jaso-ma
  17. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    Phil and Andy make and sell that bracket planning on buying one of Phil's for my 87
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    the oil is no biggie, stationary engine oil generally has no modifiers and is a fixed viscosity and a ok for husky clutches.
    ATF - type F is also good and relatively cheap
  19. dukkman Husqvarna
    Factory recommended SAE 20.
    SAE 20 is no longer available so the nearest available is SAE 30 and guess who makes a supply that's readily available world wide ?
    Briggs n Stratton.
    Bizarre.
  20. tonyvisone Husqvarna
    1984 WR 400
    thanks u da man!
