1984 WR400 help
Discussion in 'Vintage/Left Kickers' started by tonyvisone, Nov 6, 2015.
  1. tonyvisone Husqvarna
    1984 WR 400
    harley, gsxr, klx110, 400ex
    Right 5 I just pulled out. Left 5 are ones I pulled out a while ago
  2. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    am I seeing things or are the springs different lengths?? something is not right madeline....
  3. tonyvisone Husqvarna
    1984 WR 400
    They looked identical in person lol
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the pushrod adjustment is easier to break free when the basket is assembled
  5. tonyvisone Husqvarna
    1984 WR 400
    A puller IS necessary correct? I'll have to grind my arms down to fit...
  6. tonyvisone Husqvarna
    1984 WR 400
    Think I figured out clutch adjustment.
    Looked something like this. Went all the way in then backed out 1/4 turn. (Going off logic)
    But the cable needed to be pretty far out, but atleast a few actual threads in... (not just in a few stripped threads like before)
    Oh and when I had the plates out many of the steels felt pretty stuck to the friction plates. Could just been oil adhesion but some felt tougher. it starts and finishes with a friction plate
  7. justintendo klotz super techniplate junkie
    need to adjust based off play at actuator arm as previously mentioned. unless you think other members time is wasted explaining things. measuring play at arm is how the manual states it is done, and this is very sensitive. too little play and it will slip, too much and it will take alot of adjustment at the lever to make up for it.
    lube the cable while its out of the lever..perfect adjustment and lube makes a big difference in feel
  8. tonyvisone Husqvarna
    1984 WR 400
    Thanks I'll get the manual printed soon
  9. tonyvisone Husqvarna
    1984 WR 400
    By the way, multiple times I have gone to left kickers and searched wr400 clutch snd only get a bunch of junk. Am I searching wrong? I'm somewhat new to forms
  10. Michel Dufayard Husqvarna
    France
    Buy the right puller on eBay for $ 20 in order to keep the flywheel in good shape.
  11. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    The correct puller pulls from the threaded hub. Do not try to pull from the holes in the flywheel as you show
  12. Michel Dufayard Husqvarna
    France
  13. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Take the stack apart (unless you did that earlier) and measure the height. It should fall between the measurements given in the manual. Make sure the plates and frictions are fitted in the right order. Yes, a new push rod maybe. Have you double checked to make sure there is nothing missing ?
  14. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
  15. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    Yes 26 x 1.5mm male right hand thread only safe way, take clutch plates out clean and check I rough the steels up in a figure eight lightly on level concrete, some have aluminium plates but would change to steel.use aft in gearbox c h ange regularly if your clutch hub is he l d in oby a circlip make sure the rough jagged edge faces outward shouldn't have any grooving in the fingers as its a steel body, 6mm free play measured at v end of actuating arm.check stator side seal.
  16. justintendo klotz super techniplate junkie
    just search "clutch" and do it under the advanced search, then you can only search titles.
    sometimes you just need to read the info thats been presented to you right here in your own thread, like i was referring to.
    please get a flywheel puller..
  17. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    Yep the correct puller is a must.
  18. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    I believe the flywheel puller is the same for both Motoplat Mini 6 and SEM. At least I do not remember using a different one as I have several in the range.
  19. tonyvisone Husqvarna
    1984 WR 400
    Thanks guys. Forgot to update last week. I bought the puller it should be here tomorrow.
    I was thinking to cut circles like below. And put a bolt through it for the exhaust.... I know it's different than stock but I would have an unlimited supply of them....
    It's super high temp silicone.
  20. grouty Auto Lover ...
    South West UK
    If you are thinking of using these to mount the exhaust ...... then NO ! Unless you want to keep welding up cracks in the expansion chamber.
    The correct mountings are not expensive, and are there for a reason.
