1984 WR400
Discussion in 'Vintage Restoration Projects' started by darren7878, Mar 2, 2015.
  1. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    100%!- busted
  2. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    i have 2 400 motors, one has vibes and the other doesnt. the vibration was traced to the crank, and when the crank was swapped between engines the vibration swapped as well. we took both cranks to our local machine shop and found one was out of balance and slightly out of true. might be worth checking this as the one 400 that didnt vibrate is the nicest husky engine i have, so smooth and very willing to rev if needed. i also find the vibes are a tad better with phils ss engine mount plates, they certainly hold up better and the bolts stay tight.
    I'd agree 100%, my 86 vibrated like a paint shaker, but the 84 was so smooth.. I was testing the 84 out on a short blast up my street when I 1st got it & wacked the throttle on, I thought the clutch has slipped, til I realized I smoked the back tire :D.. That's one
    bike I have on my short list to get another of.
    Husky John
    Aviyaytor likes this.
  3. darren7878 Husqvarna
    79 CR390 and 84 CR250
    81 Maico, 79 Kawasaki, 88 Honda
    Hi John yes I do have 84 CR250s as well but yes my question was aimed at this WR400 :) lol
    I love my 250s but want to build the 400. I like the 84 chassis and want to try it with the bigger engine!!
  4. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    its a great engine and check out my rebuild thread on here for any info. I tweaked mine a tad and its like a 125 on steroids but still pulls nicely off the bottom. great engine. you will need to re do the damping stack as they are soft as for a plush enduro ride. a bigger rear sprocket will see you holeshotting in 2nd gear ok. great engine ...if you didn't pick up on that.... it will probably be an 85 as most of them were badged 85 for some reason tho everyone thinks they are 84's
    darren7878 likes this.
  5. darren7878 Husqvarna
    Hi what rear sprocket are you running ?? I was thinking of running a 54?
  6. darren7878 Husqvarna
    Had the angle grinder out today!!
    Removing the 'rock bar' , grab rail and all the extra brackets on the swing arm that I do not require! image.jpg image.jpg image.jpg
  7. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i have a pile of cr frames i would have traded you a few of to get a good frame with that stuff attached..swingers too..its so much harder to weld that crap on, they dont make these anymore..:(
  8. darren7878 Husqvarna
    Bit of bad news the swing arm bearings were pretty seized and it has elongated the frame holes.
    The swing arm bolt is knackered too. Big grooves where it's grinding in the frame.
    Will fabricate some 'washers' and get the welded on and get a longer swing arm bolt made to compensate image.jpg
  9. justintendo klotz super techniplate junkie
    how good of a welder are you? plug welding it is an option long as you can get the hole where its supposed to be again. clamp some alum or better yet brass to the back and fill, then redrill. then no messing another hardened pivot shaft, a cardboard template is handy for finding your hole again. this worked well for fixing some of my frames. we plug weld at work quite a bit.
    i know you mean about the gouges on the inside, filling with weld and grinding smooth is the only good way to fix it.
  10. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    i think HVA has a kit to fix that
  11. darren7878 Husqvarna
    Sorry I realise I'm 'butchering' a 30 year old bike but I need all the rad fittings and geometry that the 84 WR frame has.
    I am going to atleast be bringing her back to life!!
    But I understand your perspective
    Motosportz likes this.
  12. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    54 will be good as im running a 52 and its bit of a jump from1st to 2nd.
  13. darren7878 Husqvarna
    The bottom end is split now and new bearings and seals going in.
    barrel is off being rebored for its new piston.
    Today got a package from the USA of the uprated rear springs and preload kit. Feeling lucky as these springs seem to have suddenly gone on 'back order' now. Hope Ohlins are willing to make some more!!
    Slow progress ....
    justintendo likes this.
  14. justintendo klotz super techniplate junkie
    looks like a package from arizona! nice stuff!
  15. darren7878 Husqvarna
    Well the barrel took a double bore to bring it back into tolerance. So kindly HVA exchanged my piston and supplied me with a CR430 head gasket. Not sure if we are still a 400! 405? The new piston won't work with the 400 gasket.
    Got a few other little bits too.
    Water pump rebuild kit and sprocket plate
    oldbikedude likes this.
  16. Bigbill Husqvarna
    '83 250wr
    0 right now
    Note for others,
    Anytime these sit for who knows how long with gas in the crankcase change the cylinder base gasket. The gas softens the base gasket.
    My '86 400 was awesome very smooth. It had low use on it.
  17. Michel Dufayard Husqvarna
    France
    V = 3.14 x( R x R) x H
    V = 3.14 x (42.25 x 42.25) x 74 = 414.98 cm3
  18. Bigbill Husqvarna
    '83 250wr
    0 right now
    P= 3.1416 I got it.
    The 390/400 is the best running engines I had so far.
    Port those transfer ports.
  19. Bigbill Husqvarna
    '83 250wr
    0 right now
    Put a piece of brass with a clamp on the rear side of the elongated swing arm hole and weld some of the elongation up. Then remove the brass. The dremel or file it round again..
  20. Bigbill Husqvarna
    '83 250wr
    0 right now
    You have the wrong base gasket if it doesn't fit. It's from a earlier 360/390?
