1984 WR400
Discussion in 'Vintage Restoration Projects' started by darren7878, Mar 2, 2015.
  1. darren7878 Husqvarna
    79 CR390 and 84 CR250
    81 Maico, 79 Kawasaki, 88 Honda
    New handlebars n controls
  2. darren7878 Husqvarna
    Starting to look like a bike now....
    86 400 XC likes this.
  3. darren7878 Husqvarna
    Right hand shroud giving me loads of grief. Seems intent on fouling the tank. I can see previous owner has already filed rad mounts to try and lower it and I had it all on n off about 5 times but still the rad shroud won't Sit under the tank.
    Soon it will get 'trimmed'. Mr angry at moment. A job for another day I think....
  4. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Genuine shrouds or after market Darren?
    darren7878 likes this.
  5. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    20 wt oil? that's a bit harsh....
  6. ajcmbrown Husqvarna
    What weight oil are they meant to run JC?
  7. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    if memory serves the manual calls for anywhere between 5w thru 20w. many here have good luck using atf in their forks, i do as well usually about 500-525 cc each leg for me. 20w may be a bit thick, as usually it seems the husks like lighter oil and heavier springs. atf falls around 8-10w as far as fork fluid goes.
    i ride very little mx. just lots of trails at varying speeds. some open and faster and some slower technical woods stuff.
  8. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    Just for reference, I run 15wt fork oil in my 83 500CR which also has heavier springs. 20wt would probably be too much as noted by the guys above.
    Build is looking really nice.
  9. darren7878 Husqvarna
    Look like DC to me. Only way it looks likely to work at moment is to modify bottom bracket so radiator can be moved forward at the bottom to gain clearance at the top. :(
  10. darren7878 Husqvarna
    I'm running .5 litre in each leg 20w. I'm mx only and have been running this in the 250s too. I tested 10 then 15 and settled on the 20w. The 15w was ok too but I just wanted a bit more..... Personally I find the uprated springs front n back 'bring the 84 chassis' to life. Feels very safe n predictable
  11. ajcmbrown Husqvarna
    I thought that may be the case, I don't hear many positive things about DC, it seems some of their products are ok and others are well below par, shame there aren't some competitors!
  12. darren7878 Husqvarna
    Need Maier to get involved believe they make all the nightmare kx and elsinore cr glossy panels now. But then fit can still be an issue :(
  13. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    if your happy with 20 that's fine, you will be the best judge. I like em plush.
  14. ajcmbrown Husqvarna
    My limited exposure to Maier has been positive so far, do they suffer the same fit issues?
  15. slosh Husqvarna
    82 wr 430, 84 wr 500, 86 cr 500
    93 Husqvarna wr250, 99 Suzuki rmx250
    That is a very white tank you have there. Is it new or restored?
  16. darren7878 Husqvarna
    I only meant that Maier is still a mould off a piece of plastic so sometimes they are not perfect. But I have used them on a CR and KX restore and would rate them above DC. Obviously DC does not do a 'GLOSS' finish and I find they get 'brittle' very quickly too. But then we have to be grateful as they are the only ones who seem to make the 84 Sidepanels!!!
    Slosh- This tank is painted. Am going to see how it goes. I have another tank i'm going to sand and polish time permitting.
  17. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    Darren, I had a similar issue with the DC side panels on my old KLX250. I warmed them with a hot air gun to soften them and re-shape. Yours look a little beyond that though.
    In defence of DC though, the last couple of sets of ML frame front and rear guards have been super shiney, and have lasted well. The oldest front guard is now 12 years old and showing no signs of breaking when I throw the bike on the floor !
    I guess a great deal of the "fit" issue is down to the original that the pattern was taken from and the amount of time taken in preparing the moulds.
  18. ajcmbrown Husqvarna
    Oh ok, I get it.
    I was just reading a page about restoring plastic tanks and panels, it is motoplasticlean and he seems to get good results but it is time consuming.
  19. darren7878 Husqvarna
    Been trial fitting the plastics and lots of little jobs. Still lots to do but.....:cheers:
    Graphics and seat cover on order plus a few other parts ive discovered are worn out or broken :rolleyes:
    oldbikedude, wrx and 86 400 XC like this.
  20. ajcmbrown Husqvarna
    Did you manage to get the shrouds to fit properly Darren?
