1985 250 XC
Discussion in 'Vintage Restoration Projects' started by Houseofmoto, Apr 26, 2017.
  1. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    you are correct, the 4 strokes were always a year behind
    85 they were still twin shock
  2. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    So a floating disk won't flutter and knock the piston back in a fixed caliper ?
    Is that what you are saying ?
  3. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    It does a little, takes a extra pull to get firm. The other reason why i changed them.
    Its normal for a piston to retrack a little, thats what the square sealing O rings do on the piston to reduce drag.
    They early set up rattles and moves around alot, the caliper with slides dont move easy so never get lose in the pads.
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the above is true..i mainly dislike the single piston brembo because it lacks stopping power...its weaker than a properly set up dls drum.
    2premo likes this.
  5. wrx Husqvarna
    845 newyork
    1973 to 1986 husky's various models
    RM -250 / Buell / Penton 400 mc5
    Justin is dead nuts on point with the 85/86 ft brembo disc set up. DLS smokes it in stopping power. 87 twin piston way better also.
    2premo likes this.
  6. Houseofmoto Husqvarna
    1985 Husqvarna 250 XC
    2006 KTM 200 XC, 2003 BMW F650CS,
    I'd been pretty sick with bronchitis, but I did get the rear shock serviced. Buddy who used to wrench for the old Dirt Works Husqvarna-KTM shop that was once in North Jackson, OH took care of it.
    Found the radiators are bent, and many of the rubber mounts are shot. Missing the front brake pad pin too and I'm having a heck of a time sourcing one.
    I'll try to get some progress pics up soon. Appreciate the input and suggestions thus far.
