1985 CR500 Project Bike by Husky 37
Discussion in 'Vintage Restoration Projects' started by HuskyT, Oct 28, 2009.
  1. Husky37 Husqvarna
    UK
    84 CR500, 85 CR500, 89 TE 610
    Just found this other pic from the day....
  2. 1Tuff500XC Husqvarna
    Real clean look there. Still can't believe how nice and period correct the gear looks.
    Is the gear all stuff you've had from back in the day, or more recently acquired?
  3. Husky37 Husqvarna
    UK
    Helmet, Gloves, jeans (including boot covers), Face Mask are all original.
    I had the jersey made with all the old logos. Still got some old jerseys but they look a bit tatty. Still got my original Oakleys but the elastic has gone on both pairs. My AXO boots, although leather OK the plastic has suffered so I got a pair of White Sidi...
    Just tried to be authentic as possible.... looked nice for a while :)
    paddy boy likes this.
  4. paddy boy Husqvarna
    wiltshire,england
    hi mate like what u doin.i am just about 2 do resto on my 86 cr 500.clutch case a bit damaged.would another year fit eg-85 or 87. thanks dude good luck with rebuild,long live the beast.
  5. Husky37 Husqvarna
    UK
    Hi Paddy boy,
    Any of the 2-Stroke water cooled clutch cases will fit 85-88 I believe but not the 4-strokes as they do not have a breather tube
    Stu
  6. hall21498 Husqvarna
    85 cr500
    I have 85 CR 500 just rebuilt motor board 20 over Can someone halp me when I try to start my bike when you hold a little bit of throttle it back followers
  7. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    Riding uses the back strap muscles big time and they support your discs, get a little sedentry and bugger me , my backs gone.... get the pushbike out and do a 15 - 20 ride each day and you will be good as gold.
  8. hall21498 Husqvarna
    85 cr500
    Still having some problems the bike runs great almost has too much power can kickstart it every now and again but it's still backfiring don't know if the timing is off have a little bit more plastic work on it it's not cheap can not understand why it is backfiring could it be getting too much feel any information is appreciated
  9. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    timing sounds like yr problem advance a small amount. try a new spark plug, check electrical connectionsand tbe earth.
  10. Ron Husqvarna
    Azusa, CA
    Advancing the timing will cause it to backfire more. Retard the timing (firing closer to top dead center) will decrease backfiring.
  11. hall21498 Husqvarna
    85 cr500
    thanks for the hp
  12. cwwillmon Husqvarna
    1985 CR500
    Awesome, just started rebuilding a 85 CR500. Good job Stu!
  13. RUF Husqvarna
    SACRAMENTO
    510 air, 400WR 85, 430WR 87
    BMW R80GS, GILERA 175RC 1972........
    Husky37
    I had same problem several times....
    Put two pieces of wood at the top and bottom and push in the middle very gently...
    it is aluminum and its very easy to fix in that way.
    Dont push too much, anyway.
