1986 430 Hubs
Discussion in 'Vintage/Left Kickers' started by D12, Nov 4, 2015.
  1. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    so I see the argument for these on an auto
    i understand putting the brake on the bars, but my clutch is there
    has anyone done this to a standard model?
    I have a 92 rear wheel, I was looking at milling the swingarm for the slightly larger axle and the stumbling block I see is the fluid reservoir
    where would you mount that and be able to have visual access for pre ride checks
  2. Submit Husqvarna
    Bradford, Ontario
    2012 CR125, 86 430 AUTO
    I have done exactly what you are asking. It was actually really simple too do and works perfectly..... I do have to fix mine though (got a little carried away with the grinder)
  3. D12 Husqvarna
    1986 Husqvarna 430 AE
    1994 Triumph Daytona 1200
    I believe the hub for the 2001 WR426F is supposed to fit in the frame. I haven't purchased them yet, but that's what I am told. Does anyone have the measurements for the gap on between the forks and the gap on the swing arm? If so I saw the dimensions on the hubs for the Yammie somewhere.
