1987 430 barn find. Need some help.
Discussion in 'Vintage Restoration Projects' started by huskyJames, Dec 25, 2016.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
    Polish the exhaust port too wake up the sleeping giant. We can always throttle back on the twistie if we don't need the power. But it's nice to have the extra power when needed.
  2. jimspac Husqvarna
    Connecticut
    86 400WR, 82 Montesa Cota 349
    The report on the 430 Auto porting I saw here a few years ago would be great as the Auto requires more midrange to shift. That porting really woke up the Auto so image what it could do for the WR
    ajcmbrown, 2premo and justintendo like this.
  3. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Do you have a link to that article jimspac?
  4. jimspac Husqvarna
    Connecticut
    Search the Wildebeast build in Restorations. Porting was by Paul Rooney as I recall
    Eurofreak likes this.
  5. ajcmbrown Husqvarna
    Thanks jimspac.
  6. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    85 ATC 200x, 88 rm 125,
    I started to put back on my new clutch cover. I had a hell of a time with it today. It would not line up were the pin comes out of the cover just below were the shiffter shaft fits in. Is there some trick to this? I thought maybe it was the case not fitting right but the old one has the same problem to. the shifting mechanism looks like it sits just under the pin, is there a special alignment I need to do before popping on the cover. I cant figure this one out.
  7. Eric The Leg Husqvarna
    Currently Tacoma, WA
    1986 WR400, 1985 WRX400, 1979 WR250
    83 Kawasaki KZ 440
    Last time I just wigled it around a lot and rotated the shifter and impeller until they engaged.
  8. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    It seems the pin coming off the cover sits right in the middle of the spring for the shifting mechanism. or on one side of it. I just cant get the case to sit flush. IDK what the hell is up.
  9. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    pin goes to the middle for shifter return both ways
  10. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    messed around with it some more. I watched some of huskydogg's videos. I found if the kick starter shaft is not in the case goes on ok. On closer examination of my kick shaft it is not straight. I am ordering a new one. I did install a steel bushing in th inner case also for the shaft to ride in. If i need i can hone that a bit to. I found out that some of the hva cases can be off on their machining. I am hoping the new shaft and a clean up of my new bushing will be the fix. If not ill be hunting a new cover, hopefully hva will take this one back if it is off to much.
  11. SteveJ Husqvarna
    New Mexico
    1970 400 Cross, 1983 500 CR
    84 Honda CR500R, 81 Honda CBX,
    Did you have to bore out the case before you installed the new sleeve you fabricated for the idler gear (starter) shaft? If so, the previous wear may have caused it to come out slightly off of the true center of the original machined hole. Then the idler gear (starter) shaft being slightly off center might cause the cover alignment dowel to not drop into the recessed hole.
  12. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    Yes I did. it was badly chewed up on tear down. That is a fear I am having. Since I know my shaft is bent. I am ordering A new one and take it from there. If its still tight, Ill hone my sleeve a bit. After that if I cant make it work its a whole tear down and new half case. I just did not want to tear this bike down untill my 500 is done.
  13. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    Is it really common that the hva cases have fitment problems? huskydogg had a few youtube videos showing this problem. Not sure that is my problem, I just ordered a new kick start shaft. I going to narrow it down and find out. However im just wondering how common of a problem this is? Also if anyone knows of anyone with a decent case for a 87 430wr just in case it is my case.....
  14. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    the fitment problem would be unusual for original husky parts. ive swapped alot of mixed year parts and they fit fine.
  15. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I have numerous 87 430 engines in parts, if you need to try fitment you are more than welcome to take advantage of this
  16. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    Thanks 2premo, I will let you know as soon as I narrow down my problem. Waiting on my kick starter shaft is all now.
  17. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    Damn, had the cover off of my '86 today, was having same trouble getting it back on and shifted the spring to the side to get it past the pin. I wonder if I can find enough garage time to fix it tomorrow...
  18. 2premo Husqvarna
    Northern NV
    feel your pain on the cover
    here is my thoughts on this
    when an assembly won't work go back to basics
    pull the shifter and kicker
    make sure the cover fits all by itself, if not fix this if so go to step 2
    step 2; put the kicker in the main case, make sure everything aligns, check clearances, should be snug but not bind
    put the kicker in the clutch cover, set the spring preload, place cover see if all fits, if not work on this, if it does go to step 3
    step 3; see if shifter engages and spring goes over pin, check for binding
  19. ct cr430 Husqvarna
    Connecticut , litchfield county
    1981 cr 430
    2007 honda crf450
    Yes , I know mine is an 81 430 but want to share this anyway . Last couple of clutch cover gaskets I bought had an additional tab with a hole that lines up with the pin for the shift return . I found that if I used that tab to line up the inside of the shifter return spring , no problems .
  20. Eric The Leg Husqvarna
    83 Kawasaki KZ 440
    I have the same gasket, that's what showed me my spring was in the way, and preventing that corner of the case from going flush. Still not sure what idiocy caused me to push it to the side rather than straddle. While that was dumb, at-least I didn't resort to 'hammer therapy' (rarely do on these old bikes).
    Adding to 2-premo's comment. This is obvious, and I just admitted to idiocy, so I'm sure you're already there, when you put the cover on minus the kicker shaft, that's also a good point to find something reasonably matching the diameter of the kicker shaft to test the alignment on your bushing setup.
