1987 430 barn find. Need some help.
Discussion in 'Vintage Restoration Projects' started by huskyJames, Dec 25, 2016.
  1. grouty Auto Lover ...
    South West UK
    78 390WR, 78 390 AMX, 500 Humph
    works 73 CCM 520, another 73 CCM520
    I use the V Force reed set up from HVA on my air cooled 390. They are a brilliant addition. I had the motor on the bench when I fitted them. I did a leak down test and found slight air leaks. Easily cured with a little silicone. My set up is probably a little different to yours, but try a leak down with the reeds and inlet manifold on.
  2. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    I got a free set to try from Huskydoggg. Well after a few years they leak, i see some fuel wetness/leakage at the bottom of my air box on my 88.
  3. huskyJames Husqvarna
    Elverta Ca
    85 XC500, 87 WR430
    85 ATC 200x, 88 rm 125,
    Were were your leaks. I am going to retry. I will do the leak down to, thanks for the info. my 430 would not start at all with them. This was an inital start after a complete rebuild though.
  4. grouty Auto Lover ...
    South West UK
    My reeds has two blocks that fitted in a plastic housing (from memory). The leaks were around the edges where the plastic joined. Yours may be a different set up though. It is really worth doing a leak down check.
    There are some pictures on here from the build I did of the second 390 Auto motor.
  5. GaryM Husqvarna
    Austin, Tx
    1981 430cr second 430 CR 500cr
    1981 490 Maico
    Please look for PM
