1988 400WR?
Discussion in 'Vintage/Left Kickers' started by ajcmbrown, Jul 19, 2015.
  1. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    go up one on the front sprocket, that will tame it a bit and you should be able to do a genuine 100 miles an hour in top gear!
    ajcmbrown likes this.
  2. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Look what was posted on Fakebook tonight!
  3. ajcmbrown Husqvarna
    I like your logic John!
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    whats your gearing currently? the pipe is likely producing some of the effect, as the uptite is supposed to increase power.
    are you still running the mini 6 motoplat? i would imagine too much response from using the aftermarket internal rotors ive seen used
  5. darren7878 Husqvarna
    79 CR390 and 84 CR250
    81 Maico, 79 Kawasaki, 88 Honda
    Original Pipe could smooth things out also could try going 2.0 BTDC on timing to see if that helps?
  6. justintendo klotz super techniplate junkie
    more advance will give better throttle response, so that would be wrong direction for him.
  7. ajcmbrown Husqvarna
    Just from a quick look, it appears to be 13/52, what is the max size front sprocket that can be fitted? Tonight I will have a proper look with the sprocket cover off.
  8. ajcmbrown Husqvarna
    I'll try it once I get the pipe back, it's being repaired at the moment.
    Tony.
  9. justintendo klotz super techniplate junkie
    if so, then yes that would be a bit responsive. nothing insane, tho. i run 14/52 for mostly woods and medium speed stuff on my 430. a 14 will last longer and probably make your chain last longer as well..for the 430 i dislike going taller than 14/52 as its geared too tall in 1st and 2nd for woods work imo...i dislike a ton of clutching...
  10. darren7878 Husqvarna
    Oops thought it would calm it down :( my bad
  11. ajcmbrown Husqvarna
    This is quite brutal in its initial snap, then seems to sign off a bit. After the initial hit, it feels like my previous 400WR, smooth and linear.
    Just as a bit of background, I have owned many big bore two strokes and four strokes over the years, but none that had a delivery like this.
    I probably sound like I think it's unmanageable, it's not. It just isn't the enduro motor that I remember. I have not had the barrel off, so there could be some "mods" to the porting that are not ideal, I'll have a better idea once the OEM exhaust goes on. If what I'm experiencing is the effect of the Uptite pipe, then maybe I need to adapt to it, or just use the OEM pipe.
    Maybe I'm just getting old?
    Tony.
  12. ajcmbrown Husqvarna
    Mine still has the external rotor SEM ignition, so plenty of flywheel weight there.
    justintendo likes this.
  13. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    Could be the pipe or Surprize's mate could have tidy'd up the ports a little.:D
    My 400 has a linear power delivery with no Surprizes.:D
  14. justintendo klotz super techniplate junkie
    likely a combination of the 13 gear and the pipe, making it a bit abrupt. at least the swede has the super slow gunnar gasser throttle.
  15. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    I run a 14/52 or 15/52 depending on the ride obviously 15/52 in more open areas
    with all the torque you should be up a gear anyway
    to answer the question a 17 tooth will fit
  16. ajcmbrown Husqvarna
    Thank you 2premo! 17t would be Baja gearing!
  17. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    13 is too low, and will be jumpy. min 14 tooth front will tame it down a tad, and 15 if you barely use first. its a well spread gearbox and you can mix those front sprockets for a wide range of riding. that mid range hit will be a blessing with a 14 / 15 combo
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I just saw that picky of "Le Camel" at the Echuca dustbowl Vinduro last year.
    The highlight being when my esky fell out the back of the ute on the way home and ol mate picked it up. he was seriously annoyed that he didn't find the 3 stubbies that were inside it. he only saw the margarine and the cheese and snags so he left them on the side of the road...:rolleyes:
  19. ajcmbrown Husqvarna
    I had a proper look and it is 13/52 gearing, may have to get a 14 and 15 just to cover most conditions.
    I think a 15 would be great as you say, and it has the grunt to pull higher gearing.
  20. fran...k. Husqvarna
    eastern ct
    For the spline on your bike I have from 10 to 16 tooth and there may be a 17 in the book. Not sure what one could actually get at this point. This is one thing these bikes have over the modern ones though it must come at the price of having the output shaft farther from the swingarm pivot.
