1988 WR250 revival 2016
Discussion in 'Vintage/Left Kickers' started by ajcmbrown, Sep 26, 2016.
  1. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    Inspiration!
    DaveM, oldbikedude and NCSteve like this.
  2. ajcmbrown Husqvarna
    I was wondering when someone would notice them.
  3. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    he is singing that old song..."ten green bottles..hic...hanging on the floor...thatsh notch rite..hic.."
    jack topper and ajcmbrown like this.
  4. ajcmbrown Husqvarna
    Lucky the other empties are out of shot!
  5. oldbikedude Husqvarna
    Honey Brook Pa.
    Oh they were noticed....:cheers:
    ajcmbrown likes this.
  6. ajcmbrown Husqvarna
    And yet no one noticed the lack of a bump stop on the rear shock!
  7. Eurofreak Husqvarna
    Western NY
    1986 TE 510, 1982 CR250, 2008 WR250
    70's Triumph , Bultaco , Maico, etc
    I found the a crack in the same place on my swingarm- luckily I have a good welder.
  8. ajcmbrown Husqvarna
    Hopefully so do I.
  9. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    bottled liquid mechanics assistant
    NCSteve and ajcmbrown like this.
  10. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I need one...or maybe 6... of those :cheers:
    2premo and ajcmbrown like this.
  11. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    in Oz, everything is measured by the blma... a drive to somewhere is a two blma trip, replacing a tyre is a 3 blma job...etc
    2premo likes this.
  12. ajcmbrown Husqvarna
    Mowing my oval is a 3blma job.
  13. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I thought it was big???
  14. ajcmbrown Husqvarna
    Longnecks JC!
  15. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    rrriiiiggghhtt;)
  16. ajcmbrown Husqvarna
    Another small setback, I bought some cases from 2premo, great to deal with, sent some excellent photos, packaged very well, absolutely as described and recommend highly, however my mistake was assuming that '86 250 cases were the same as '87-88 with the exception of the seal flange at the sprocket.
    I was wrong. The cavity in the crankcase where the crank wheel fits on the '88 is 115mm across and the crank cheeks are 113.5mm across, the '86 cases are 112.5 across to suit the short stroke crank, I mistakenly assumed that they would be interchangeable.
    I'll see if a machine shop can machine the thicker web on the 86 cases to fit the '88 crank. Of course I discovered this after fitting the bearings and crank seal, I hadn't yet assembled the transmission/clutch though!
    Tony.
    justintendo likes this.
  17. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    wow, sorry to hear that...but i guess thats a good find. i did not know that and i would have assumed the same as you..
  18. 2premo Husqvarna
    Northern NV
    had no idea of that, very sorry
    i feel very bad on that
  19. 2premo Husqvarna
    Northern NV
    less than 3mm but HUGE on fitment
  20. Bigbill Husqvarna
    '83 250wr
    0 right now
    I built and assembled a 250 five speed tranny into a 83 250cr bike. The five speed was from a later 80's bike. I can't remember the crank I used. But it worked. Your info is something to think about when swapping parts to make things work.
    That's half a mm on a side obstruction. I wonder if it can be machined out using a die grinder with a carbide bit on the case. Or set up the case on a milling machine and bore it out 1/2 mm?
