1988 WR250 revival 2016
Discussion in 'Vintage/Left Kickers' started by ajcmbrown, Sep 26, 2016.
  1. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    yeah, bikes have sat for years over something like that!
    oldbikedude and Eric The Leg like this.
  2. Eric The Leg Husqvarna
    Currently Tacoma, WA
    1986 WR400, 1985 WRX400, 1979 WR250
    83 Kawasaki KZ 440
    Glad to hear you got it figured. To echo Justintendo's comment, bikes have sat for years over things MUCH simpler than that.
    I ran my 400 WRX around the block a couple of times today (had just sorted a couple minor things, also keeping it fresh and moving the oil around a bit before changing, and building relationships with my neighbors). It's an awesome feeling, especially on a bike that you bought from someone who thought it would never run again!
    oldbikedude likes this.
  3. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    A couple of update photos, it's not quite finished but I have an event coming up next weekend and the following weekend so this will have to do for now.
    Many thanks to Jon Hicks for the pipes, I should be able to build one nice pipe from mine and a donor pipe, that's a job I'll get to after these events.
  4. oldbikedude Husqvarna
    Honey Brook Pa.
    The bike looks great! A nice set with the 400. A pipe would finish it nicely.
    ajcmbrown likes this.
  5. ajcmbrown Husqvarna
    Thanks OBD, it will look better with its new seat cover and decals.
  6. 86 400 XC Husqvarna
    Calgary
    75,82,83,2x84,85,3x86,87,88 and 89
    more Huskys
    I put my 250 back in today.
    Took the 400 out
    Clean pipe is the 250, the 2 are so close.
  7. ajcmbrown Husqvarna
    Is the 250 pipe an 87/88? I'm trying to work out how to identify the different single shock 250 pipes.
  8. 86 400 XC Husqvarna
    Calgary
    more Huskys
    Yes 88
  9. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the most obvious difference is the rear mount
    87-88 is longitudanal
    85-86 is latitudinal
    the 85-86 has a different stroke so different pipe dimensions for tuning
    not acceptable for performance
    ajcmbrown and justintendo like this.
  10. ajcmbrown Husqvarna
    This bike has become my go to for most of the events I enter, it just makes everything easier!
    Cookardinia Vinduro October 2018
  11. ajcmbrown Husqvarna
    Eugowra Vinduro July 2019
  12. ajcmbrown Husqvarna
    Braidwood Vinduro May 2019
  13. ajcmbrown Husqvarna
    VoodooHusky and 86 400 XC like this.
  14. 86 400 XC Husqvarna
    Calgary
    more Huskys
    Great pics of you, sure looks fun.
  15. ajcmbrown Husqvarna
    Hahaha, I was just demonstrating how much use this bike gets, I normally take two or more bikes but this one always makes an appearance and is always ridden the most.
    Our Vinduro tracks are tight single track, not ideally suited to big bores, but this bike works great in those conditions.
  16. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    that the 240? or the 400??
  17. ajcmbrown Husqvarna
    1988 250WR long stroke John, it's just a great bike!
  18. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    i thought so...just thought to clarify...:thumbsup:
  19. Down Under XC Husqvarna
    Melbourne, Australia
    XC250 83', WR250 87','XC150 10
    WR165 10, 83 KDX 250,
    Hi Guys,
    I have been busy doing other stuff but I eventually received the 1988 WR 250 from ""Greg Premo"on this site and it is a great bike....... Just in the process of doing a restore as well.
    Out of interest, clutch actuator lever movement on case how much slack should they have.
    What gearing mine are you running ? mine is 12 - 48.
    Great sounding bike.
    Issues though with replacement pistons and rings.
    just sorting springs at the moment.
  20. ajcmbrown Husqvarna
    Regarding clutch adjustment, I tighten the adjuster on the pressure plate until there is zero clearance, then back it off one turn, just guessing but I would estimate 3-5mm at the arm.
    Gearing on my 88 is 13-53 and works great.
    Wossner do a piston that only requires a very small mod, not expensive either. It is a standard 240 piston that I have listed on here previously. This one is 1.00mm oversize.
