1988 WRlc 430 SM
Discussion in 'Vintage Restoration Projects' started by la_pierre, Jan 14, 2015.
  1. la_pierre Husqvarna
    Grenoble, France
    430 CR 87 & WR 88
    Vespas, 650 SV K7, Honda 250 CR 94
    I prefer slightly warmed the crankcase with an hot air gun for example, then block with a key the extremity of the threaded tool and with a big key tighten the nut, the bearing is pulled out extremely smoothly and easily.
    Tools are also adapted for removing the needles bearing from swing arm.
    I bought it on ebay for around 40$, it come from India, probably a copy but sold as LML tools, whatever, you can easely found the genuine one on US web sites Vespa's spare parts for around 60$.
    I hope it will help someone ;-)
    oldbikedude likes this.
  2. la_pierre Husqvarna
    Grenoble, France
    430 CR 87 & WR 88
    Hi all! Some news of my project.
    I purchase some parts and waiting for delivery: 3,5"x17" and 5"x17" Bihr black rims, white plastik front head ligth mask (KTM EXC 14), and from HVA 450 FS 15: White front fender and hand guard, yellow bottom fork guard.
    and received others parts: front hub (KTM 125 07), front wheel spokes (ktm ref 50309071175), rear Wheel sprocket side spacer ( ref KTM 58310417200), rear Wheel disk side spacer ( ref ktm 58410017000) and rear sprocket 40T (ref ktm 58310151040).
    Good news, premounting is very good, the sprocket side spacer put brake disk and sprocket in right position with break caliper support and front sprocket without any modification.
    Only the length of disk side spacer shall be reduced by machining of about 10mm to fit properly the rear wheel.
    :-D
    suprize and oldbikedude like this.
  3. la_pierre Husqvarna
    Grenoble, France
    430 CR 87 & WR 88
    hi guys! Good news, rims received and front Wheel done. :-)
    and now front Wheel 3,5"x17" finished :-)
    next step.... Rear Wheel with rim offset...
    adam6402 likes this.
  4. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    cant wait to see it all together...
