250-500cc 1992 Husqvrna Wxe 250
Discussion in '2 Stroke' started by Ryan529, May 7, 2024.
  1. Ryan529 Husqvarna
    1992 Husqvarna WXE 250
    1991 Ktm 250 EXC 2001 KTM 520SX
    I also tested the motoplat coil and it was good. I have 3 CDI boxes for the bike but it is missing the killswitch. Could i be not getting spark because the killswitch and headlight switch are missing and i dont know where they originally hooked up in the wiring harness. The wiring diagram for a 2002 model does not seem to match for the 1992 bike. IMG_2256.jpeg IMG_2256.jpeg
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    get the mag off and look behind, if it's old school type behind use the Motoplat testing procedure
  3. Ryan529 Husqvarna
    I got the mag off and the stator is motoplat but its not encased in red plastic or epoxy is that normal? It is a 12v 110w i performed all of the tests on the stator and it tested good. When taking the stator off the bike i noticed a splice in the wiring behind the exhaust where someone did a really bad splicing job. Im hoping that was my issue. I got a new kill switch i need to wire in and got a used ignition cover for $30, i was very excited. Ill post some pictures later on of the stator. Mag says motoplat mini 4.
    2premo likes this.
  4. Ryan529 Husqvarna
    Is this the normal stator for husqvarnas?
  5. rancher1 Husqvarna
    WA
    Yes for 1992
    Ryan529 likes this.
  6. Ryan529 Husqvarna
    Does anyone know what size and thread is the nut to hold the mag to the crank? The nut was missing when i got the bike. Or of anyone has one for sale id love to buy it.
  7. Ryan529 Husqvarna
    Update i have a small spark now
    mysery1 likes this.
  8. 2premo Husqvarna
    Northern NV
    8000 57887 is the part number if you want to search some dealers, preferably older dealers
    Ryan529 likes this.
  9. 2premo Husqvarna
    Northern NV
  10. Ryan529 Husqvarna
    Ive called halls and several other places looking for the mag nut with no luck anywhere. Does anyone here know if a 1995 wr250 stator nut would fit a 1992? Im hesitant to buy it as im US and its being sold from AU so its $30 shipping for a $15 nut but if it fits ill buy it.
  11. 2premo Husqvarna
    Northern NV
    look at the parts fiche to see if it't the same number
  12. Ryan529 Husqvarna
    What oils have you guys had the best luck running in these bikes for both the gearbox and for mixing?
