125-200cc 1995 WXC/WXE 125 Rebuild
Discussion in '2 Stroke' started by utopia, Dec 4, 2012.
  1. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    Not a problem Utopia.
    I am not home ATM back out at work but I will be home next week end.
    Try the hot/cold method for the crank install it worked for me.
    I suppose it depends on how tight the crank to bearing tolerance is on yours the original crank fell in and the newer one wasn't that tight.
    Don't press it in or you can ruin the crank alignment. You need to puull it in to the bearing via the shaft.
  2. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Thanks AUSKY. Just got the crank back today and a bunch of parts - seals, bearings, gaskets, cables...It's like Christmas in July!
  3. AUSKY Husqvarna
    Hi Utopia
    I found these specs in the manual mate.
    1- PULGS: CR - NGKB10EGV / WR NGKB95EGV - 0.5MM GAP or CHAMPION C57
    2 - FORK OIL: SAE 10 @ 125MM WITH SPRING OUT, TO TOP OF TUBE
    3 - JETTING TM35: 5000 FT - PJ 45 MJ 280 @10 DEG C. 0 FT PJ 50 MJ 320 @20 DEG C slide 3, 2 turns out on the air screw, 6AEL4-60 needle in 4th slot
    4 - TIMING: CR 0.8 MM ATDC, WR 1.6MM ATDC. Timing marks are at the 2 O'clock position for the CR(under the RHS screw) & 12 O'clock for the WR and you will also need special tool 800079831 for it. Or have an educated guess and fine tune by feel.
    Cant wait to see some build pics!!
    Hope this helps.
    Damo.
  4. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Thanks AUSKY. Here are some photos. I took very few photos this winter when I was disassembling and cleaning everything, but I took a few more as I have been rebuilding it.
    Disassembly - The amount of time spent cleaning the 18 years of hardened grease and grime off of everything was really incredible. The goal here was not to make it brand new again, but to make everything clean and 100% mechanically sound and reliable enough to take it on long rides in the mountains.
    Main bearings in and cases ready for assembly.
    I put the crank in the freezer and heated the inner bearing race and it slipper right in.
    Engine together.
    shrubitup and 454x like this.
  5. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    I had to get a steering stop welded on the frame and cut off the welded-on stabilizer post that was being used for a steering stop, so I ended up painting the frame, footpegs, and kickstand. Chassis here is back together and ready for the engine. 170.JPG
    Engine back in
    I also painted the outer clutch cover, impeller cover, and flywheel cover. (I had some paint leftover from a bicycle frame repair that was a pretty good match)
    Left side.
    I installed the stator in the same position that it was in when I took it apart since I didn't see any marks on it (I marked it before I took it apart and made sure I didn't remove the marks when cleaning. I actually got it running last week. It started on the second kick and seemed to run pretty well. I think the 45 pilot that is in is too lean, but I only ran it in the driveway up to temp and shut it off. This weekend I got everything else back together except for the hanguards. I'll get some final photos soon.
    shrubitup likes this.
  6. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    Utopia, Your rebuild looks like the work of a Master. The bike looks as modern as my 11 model and very clean. I hope that My results will somewhat compare. The kick stand has me wondering if it would fit an 11. I'm always leary about alloys and your stand looks bullet proof.
  7. AUSKY Husqvarna
    Yes ditto on what Sabortooth said looks fantastic great job !
    What forks do you have there Utopia? They don't look like the original Marzocci Magnums?
    look like USD showas.
    if you find the original foot pegs too small they are interchangeable with the later models as well. Well done man! That white frame had me reminiscingu
  8. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Thanks sabertooth. It really was a lot of work, but pretty cool when it all comes together. I think the only things I didn't disassemble and clean were the spokes out of the wheels and the shock. It ran so poorly when I got it, I figured I'd get it running first before changing the shock fluid. I can measure the stand if you want, but I'm not sure if it will fit. The newer ones are curved to miss the side plate. This one is straight and touches the side plate when it's up.
  9. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    The forks are 43 mm USD Showas. Stock on the 95. Yeah, the footpegs are small and high. I noticed that the ones from my 09 250 would fit and be in a better position. I'll give these a try first.
  10. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    It doesn't look so great with the old bodywork, but it is original. You don't see many or these around anymore. Here are some completed photos:
    I'm gonna have to take care of this left-side pipe. Probably hard to come by.
    Too bad I injured myself last weekend. I probably won't be able to ride it for awhile.
  11. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    I figured I should take alot of photos since it will never be this clean again. A couple more:
    shrubitup, sabortooth and 454x like this.
  12. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    Nothing wrong with that ride whatsoever.
  13. Cuso1956 Husqvarna
    95 husky WC X 125
    98 Honda superhawck 996
    Hi, let me join the club of fortunate or unfortunate husky owners. I own one of this babies. I love this bike wich I enjoyed for 2. Years in Washington state. Then I went overseas with military. 16 years later (bike in storage) still looks fairly new. Rode a few times a year. Its running strong and looks good. Rebuild shock and forks with Race tech parts. My dilemma should I ride until death. What I get from this forum there is no parts in the planet.. my concerns are cone and piston. Appreciate your feedback.
  14. utopia Husqvarna
    Jackson, WY
    WR250, WXC125
    Pistons are available from Vertex. Same as 1995 WR/CR125 that were available in countries other than the US. The only part I had trouble finding was a rod kit which I found in Europe. I don't know what you mean by "cone".
  15. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    in this thread they stated everything but a few parts is available online..
    resto looks great, i have the same bike in 360 flavor...they are different looking thats for sure, but if you can get a big H back on the shrouds itll look great...i recognized that front number plate with the ocean splash graphics...my shrouds have it too still in decent shape
  16. veee2222 Husqvarna
    WRE 1995
    na
    Hi,
    This is an old topic but would anyone give the dimensions of the crankshaft to HUSQVARNA 125 1995 (WR/WRE 125 1995)?
    I mean this measure from the crankshaft (distance of crank webs).
