2010 510smr Daily Rider
Discussion in '4 Stroke' started by Tech 3, Jun 22, 2011.
  1. Mr_X Husqvarna
    Singapore
    I have around 14000km milage on my 2009 SMR510.
    -I just changed the clutch plates recently.
    -Did valve clearance every 5000km, oil change and oil screen cleaning every 2500km (manual recommended every 5000km)
    - Installed the hi-flow water pump and using Arrow factory titaniums with ECU.
    - STM slipper clutch
    - silicone radiator hoses by Emotion racing.
    Mik-3 likes this.
  2. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Mr. X you have a great set up on that bike
    How are you liking that Exhaust and ECU
  3. Mr_X Husqvarna
    Singapore
    Thanks man. The exhaust is a good buy. My mechanic just adjusted the TPS and everything seems to be plug and play. Bike doesnt overheat at all while riding. Now i have a little problem, hydraulic oil seems to be leaking throught my lever joint at my clutch pump after i installed slipper clutch.
  4. Tech 3 Husqvarna
    Ohio
    2010 SMR510
  5. J.R. Husqvarna
    Northern Utah
    450 Supermoto! and a BUNCH 'O parts
    This happens sometimes when an aftermarket clutch is installed. If the clutch assembly is slightly thinner over all, the clutch push rod has to return back a little further than before to compensate. And that excess fluis has to go somewhere and the easiest place for it to escape is on the pump. Follow? Did you notice any difference in play of the lever with the slipper installed? Sometimes if the new clutch assembly is fairly different in overall height, it can change where the push rod is in its range of motion and effect the overall motion of it. Like it may not engage or disengage fully..
    Hope that helps!
  6. Mr_X Husqvarna
    Singapore
    hey thanks man. after some hard riding the hydraulic oil stopped oozig out already and clutch play is back to normal after some adjustments. time to learn how back it in!
  7. Mr_X Husqvarna
    Singapore
    Anyone here replaced their timing chain and slider yet?
  8. J.R. Husqvarna
    Northern Utah
    How many hours/miles on this one? Have you checked where the tensioner is in its range of motion?
  9. Mr_X Husqvarna
    Singapore
    I have around 15000km on mine. I havent checked that yet though
  10. J.R. Husqvarna
    Northern Utah
    probably about time for a rebuild. Have you kept an eye on your maintenence schedule? I dont remember the intervals for rebuild off the top of my head..
  11. Mr_X Husqvarna
    Singapore
    I do valve clearance every 5000km and check the onternals while at it. Everything seems fine but im gonna change all the bearings soon to play safe.
    And my clutch piston rubber ring worn out on me. Just got it change.
  12. Mr_X Husqvarna
    Singapore
    Damn. Stock fuel pump went down on me while riding. Replacing it with a part from ebay. And the stock magura clutch is beyond repair. The leak was caused by the scratches in the inside wall of the pump, causing fluid to leak bit by bit. Replaced it with the newer magura clutch
  13. hunkiedave Husqvarna
    ebay fuel pump? I know stock fuel pump casues some problems ... gas out always on the engine and stalled.
  14. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Time to test and tune again
    I really could not get the CO1,2,3 dialed in to my likening
    last summer so this year I went with the JD tuner and the
    LC-1 wide band A/F gauge and so far so good.
  15. Kilikia Husqvarna
    '08 SMR510
    Love your guys bikes!! I have an '08 SMR510... haven't got to put many hours on with these NE winters, but I can't wait for it to warm up!
    Seems like you guys put quite a few miles on your bikes, and they're lasting. Do y'all use them to commute?
  16. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    My bike is my summer time full time transportation
    I ride it every day.
  17. Kilikia Husqvarna
    '08 SMR510
    Any freeway riding?
  18. Kilikia Husqvarna
    '08 SMR510
    My commute to school has about 7 miles on the freeway, but I'm afraid to wind her out that long going full-throttle....
  19. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    I don't do the freeway
    I think the strain on the engine would shorten it's life
    my bike lives in town and the back roads
  20. RattyWheat Husqvarna
    NY
    2009 smr 510
    kilikia, where you from im also in the north east
