2010 510smr Daily Rider
Discussion in '4 Stroke' started by Tech 3, Jun 22, 2011.
  1. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    The Arrows are sweet How do you like the set up
    did they come with a ecu
  2. Mr_X Husqvarna
    Singapore
    it's not mine. another rider from supermotojunkie. he said it reduce the heat alot and its way lighter and sounds better than the stocks. not forgetting it comes with race ecu
  3. Mr_X Husqvarna
    Singapore
    Hey friends, what are the signs and symptoms that the bike need to undergo valve clearance immediately?
  4. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    If the valves clearance is too loose they will make noise
    if they are too tight and not closing all the way you will
    have hard to start issues
  5. Mik-3 Husqvarna
    Finland
    Husvarna SM510R 2010
    Valve clearance (with engine cold)
    Intake .................................................. ........0.004 ÷ 0,006 in. ( 0,10 ÷ 0,15 mm)
    Exhaust........................................... .............0.006 ÷ 0,008 in. ( 0,15 ÷ 0,20 mm)
    Maybe these help
  6. Mr_X Husqvarna
    Singapore
    Thanks, that helps. So far i dont have any problems starting.
    What kind of noises actually? coming from the engine area or the exhaust sound sounding different?
  7. Mik-3 Husqvarna
    Finland
  8. Mr_X Husqvarna
    Singapore
    Thanks, if that's your bike then I say it's super sweet :)
  9. Mik-3 Husqvarna
    Finland
    Yes that is my bike, i have new ideas in this winter...
  10. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Up date: new fuel pump
    The new fuel pump from CA-Cyclewerks died,had to put the old pump
    back in, I will see if there is any warranty on this pump or not
  11. Mr_X Husqvarna
    Singapore
    Oh my, is it resulting to overheating?
  12. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    No just a failure
    But i contacted CA Cyclewerks and they were right on it
    Sent me out a new pump the same day no charge
    and the owner Chris talked to me on the phone for a while
    to find out what exactly went wrong They are working on perfecting this pump
    This is good news for husky owners, They already upgraded the pump from
    original now they are going through another upgrade, The company is trying to make the pump
    the best it can be, I definitely will do business with this company again
    If you need to replace your fuel pump go to CA Cyclewerks They will do you right.
    B_M_F likes this.
  13. Mr_X Husqvarna
    Singapore
    Thanks for the info. I shall be making my order of the fuel pump next month even though my stock one is doing fine. Just in case...
  14. Mr_X Husqvarna
    Singapore
    Done my valve clearance. definitely better throttle response and smoother engine braking. Now to solve the problem of my super hot midpipe!
  15. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Sunday project : Cut three inches off stock cans
    Mik-3 likes this.
  16. Mik-3 Husqvarna
    Finland
    Nice overall view
  17. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Thank you
    Mike-3 throw up some shots of your SMR so we can check it out.
  18. Mik-3 Husqvarna
    Finland
    Tech 3 likes this.
  19. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Thats a great looking bike
  20. Mik-3 Husqvarna
    Finland
    Thanks Maybe I buy still another front and rear wheels (3.50-17/5.00-17) and the rear fork paint black, the back of the white and also a little more tuning engine
