2010 510smr Daily Rider
Discussion in '4 Stroke' started by Tech 3, Jun 22, 2011.
  1. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    An extra hot exhaust *CAN* be a sign of lean fuel mixture settings.
  2. tuplavee Husqvarna
    I'm running on rich side according to AFR. Still burning my pants to midpipe... Valve clearances are on the loose side, just in specs. Stock exhaust cans with 50mm perforated tube.
    Engine/water is not too hot(if ibeat can be trusted), fan rarely spins. Only if I idle for 5-10min or so
  3. Mr_X Husqvarna
    Singapore
    im waiting for my race water pump and silicone radiator hoses. cant stand the heat too.
  4. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    New
    SMR up date: 2010 510 with power up and modified stock exhaust
    I did a service on the 510 yesterday 69 hours on the clock 2500 miles on the OD and the bikes runs better with age, The oil gets changed every 500 miles with a new filter and I clean the metal screens, all the engine bolts get checked for the correct torque,the bike gets hooked up to i beat and TPS
    and CO gets checked for proper settings,the valves have yet
    to need any adjustment,and they get checked every other oil change,when i change the oil it comes out fairly clean now,
    no metal in the screens or the filter.The engine stays dry no oil leaks.
    This is my first husky and i am very impressed with this motor, very strong I use this bike as a Daily Rider it does not get raced nor do i flog it at all
    The only problems I've have had has been the fuel pump, went out due to the check valve in the gas cap malfunctioned causing the pump to get hot, all that was a easy fix, I would recommend this bike for any one who would want a hi powered light weight putter for in town use or putten out in the country,I have never had this bike out on the inner state hi ways too many crazy,s around here, but for what i use it for it is well worth the maintenance for what i get in return,it boils down for me to every ten gallons of gas burned it gets a oil change and service,
    I get 51 to 53 MPG and the fun you can have on this bike is priceless.
    At this rate this motors life span could be quite long ( we will see.)
  5. Planepower Husqvarna
    Edmonton, Alberta
    2007 TC 250/ 450 6spd, 2007 SMR 530
    Ducat 1198S, SV1000, CBR125, DRZ125
    Mine is race only and lives it's life 7500-10000rpm, has about 20 hrs and still powers on!
    A street ridden motor should easily go on for a LONG time.
  6. Mr_X Husqvarna
    Singapore
    Im loving my SMR too :) have 8900km milage on it now and zero engine problems.
    Still on Motorex Cross Power engine oil and K&N oil filter changed every 1000km.
    Now my front rotor is bent due to unknown reason and now it makes my front braking jerky.
    Will update more when i change to EBC front rotor, race water pump and silicone hoses, and full titanium exhausts
  7. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Next project:
    I am going to put a TXC exhaust can with a te mid pipe
    and try the single exhaust set up and see how it works out,
    I got the can, waiting on the mid pipe will post up some shots.
    should save about 6 pounds we will see.
  8. little squirt Husqvarna
    Honolulu, HI
    Did mine a month or so back. its a great bolt up and go system!!
    Tech 3 likes this.
  9. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Nice set up did you notice any performance gains or losses
    I see you have the FMF can
    I bought a used txc can from a CH member
    Thanks for posting up the shots
    Is that a te mid pipe.
  10. little squirt Husqvarna
    Honolulu, HI
    Yea TE mid pipe, super weight savings compared to the stockers i pulled off. seat of the pants says yea more power than stock, or its just beacuse its louder and revs up faster now.......
  11. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Single exhaust mod on 2010 510smr
    Used a 2010 TE mid pipe and a 2010 TXC can Direct bolt up
    I cut the can down 4 inches stock system weight 16 lb. new system 5 lb. shaved off 11 lb.
    Mik-3 likes this.
  12. Mr_X Husqvarna
    Singapore
    im digging the black swingarms!
    Just installed the Emotion silicone rad hoses and hi flow waterpump, painted the cover in red
  13. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Nice job Mr.X looks great
    Let us know hou the new punp works out.
  14. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    New prototype rack for the husky
  15. little squirt Husqvarna
    Honolulu, HI
    Just went to the dark side....................
    Mik-3 and Tech 3 like this.
  16. Mr_X Husqvarna
    Singapore
    Definitely a noticable change in temperature, but will be better after changing to titanium exhausts i hope
  17. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Dark Side
    Man that is like totally Darth Vader Dude
    I think it looks great thanks for the shots
    Where did you get the plastic
  18. little squirt Husqvarna
    Honolulu, HI
    was just an extra set i scored and had them painted.....looking into some simple graphics for it now.
  19. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Man that thing looks great just black
    Keep us poster on the new graphics
  20. RattyWheat Husqvarna
    NY
    2009 smr 510
    dose the bike have to be tuned at all to run with the single can?
