2010 510smr Daily Rider
Discussion in '4 Stroke' started by Tech 3, Jun 22, 2011.
  1. RattyWheat Husqvarna
    NY
    2009 smr 510
    hey man just took delivery of my bike on monday thing is borderline scary, seeing how it was getting cold up here i had them dial this thing right in. i told him to tune it like it was his bike. just wanted to get some seat time in before snow hits, so incredibly stoked cant be happier. i am not werthy:notworthy: !
  2. RattyWheat Husqvarna
    NY
    2009 smr 510
    sside note. is the rear brake disk supposed to have play in it where it mounts to the hub dosnt seem right. and drips 2 drops of oil on the shop floor after every ride.
  3. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Dude I am stoked for ya
    1. The rear rotor is a floater it is supposed to do that
    2. When mine was new it leaked a little oil you will have to check
    the engine case bolts they will loosen up you will need a inch pound torque wrench to do this right,
    change that oil and filter at 100 miles and check your torque on the case bolts and the motor mount
    bolts, after about 4 oil changes mine stopped leaking and dry as a bone now 3000 miles and the bolts
    don't get loose any more.
    3. Did they do the power up for ya does it still have the O2 sensor in it and when you take off the seat
    can you see the air filter, green Twin Air if so they did the power up.
    4. After it gets broken in it is more than borderline scary it is flat out scary
    Good Luck my brother any thing I can do just let me know.
  4. Mr_X Husqvarna
    Singapore
    Some updates for my SMR510:
    -My meter malfunctioned after bike being exposed to rain recently but it came back to life after some riding, guessed its just water messing up the connections.
    - Changed my front rotor to EBC since the stock warped badly.
    - My full Arrow titanium factory exhausts with ECU has arrived :)
    -Plug and play, will tune it up with iBeats tomorrow.
    -11300km mileage in still running strong!
  5. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Mr. X thats great let us know
    how the arrow's and the new ECU work out
    that ECU should be dialed in perfect from the get go.
  6. RattyWheat Husqvarna
    NY
    2009 smr 510
    hear she is..... horrible pic but did from i phone while at work ill get more later.....they did the full power up kit, what do they recommend for break in as far as rpm and stuff. smr.JPG
  7. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    As far as break in, no full throttle for the first 300 miles
    change the oil and filter at 100,300 and 500 miles
    check your valves at 500 miles
    after that just change the oil every 500 miles and I would check the valves
    at 1000 mile intervals
    One other thing get rid of the check valve in the fuel cap vent hose it is the
    little green and gray plastic thing in your fuel cap vent hose, mine was the
    source for trashing 2 fuel pumps other than that you might want 2 remove the
    cats and restrictive plate in the mufflers you will see what I mean the cans get real hot
    and don't breath as well with them in. the bike runs a lot better with the cans opened up
    It looks just like mine when I first got it
    Did you get it from heinen's
  8. RattyWheat Husqvarna
    NY
    2009 smr 510
    had them ship it out, where did you get the stopper that is on your fuel vent cap, i cut my check valve off as soon as i got it i read that i a couple threds. how do i order parts from the special parts catalog?
  9. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    To order parts from special parts catalog get the part number of the part you want
    and call any husky dealer they will be able to get them for ya then ship them to ya
    My dealer is motohio phone 614-759-6686 parts guys are Kurt or Roberto
    they are very fast and ship out the same day they come in.
    you can look them up www.motohio.com
    my check valve is off my rm125 it is a aftermarket
  10. RattyWheat Husqvarna
    NY
    2009 smr 510
    thanks, will they have a price list for the catalog.
  11. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Yes they can give you the price over the phone
    Another heads up: The hose coming from your valve cover
    and going to your air boot you want to disconnect it plug the hole in the air boot
    and get a small line filter for the hose then route the filter next to the top
    of your rear shock
    you don't want to re burn those crank case gases, they will contaminate the fresh air fuel load
    and it will make for a less of a bang, and I would also recommend that you run 94 octane fuel
    also check the vacuum port right above the cam chain tensioner and mack sure that
    they caped it off or plugged it when they removed the charcoal canister for the power up
    process or you will have a vacuum leak which can cause a lean condition
    you can get this check valve from Pro Cycle also
  12. Magiksc Husqvarna
    Hemet, Ca.
    2008 SMR 450
    2010 YZ 450F
    What size rear wheel is that? 18" or 19"?
  13. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    That is the stock super moto 4.25/17 rear rim with a 150/70/17 Karroo
  14. Magiksc Husqvarna
    Hemet, Ca.
    2008 SMR 450
    2010 YZ 450F
    How does the wide rim handle in the dirt? I have an extra set of 17s for my 08 Sm but the rear is so wide my dirt tire looks square. I think I will swap the front 17 hoop onto the rear and get a 19" for the front.. What size front are you running?
    Thanks!
  15. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    It handles real well, you want a 150 size dirt tire for the rear
    the front is a 90/90/21
    the bike is real tall with the 21 front and 17 rear
    I cant imagine the height with a 18 or 19 rear and 21 front
    I would have trouble getting on and off
  16. RattyWheat Husqvarna
    NY
    2009 smr 510
    what is this pro cycle website, also they have plugged the evap canister hole in the head. i need to get those mods going we just got a freak snowstorm and it dumped 14 inches
  17. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    14 inches of snow man
    google pro cycle then go to the suzuki dr650 section the filter and the check valve is in there
    let me know how you do
  18. Mr_X Husqvarna
    Singapore
    Looks like my meter gone haywire after heavy rain. Anyone knows how much a new stock meter cost? or should I just install Vapor instead?
    And a look of how the titanium exhausts midpipe blings up after some riding.
    No heaty legs, cans are way cooler and lighter, a significant change in acceleration smoother throttling.
  19. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Mr_X
    I think the speedo is around $300.00 but you might want to check
    The pipes look great
  20. RattyWheat Husqvarna
    NY
    2009 smr 510
    and yes 14 inches of snow bummer!! and what kind of pipe is that looks serious, also tech 3 what did you do to your tail light section i slimmed mine down some but yours looks compact. where dose the evap canister pipe into the ead so i can make sure they capped it.
