2010 TXC 250 Valve Adjustment
Discussion in '4 Stroke' started by ioneater, Mar 13, 2011.
  1. ray_ray Mini-Sponsor
    The Philippines
    If my memory is correct, the previous version Husky engines used a larger size shim ... sucks , now I gotta buy more shims ...
  2. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    Yeah, the older huskies use 9.48. I just bought a shim kit for my 250 since it seems to need constant attention. Fortunately, the valves haven't moved on the 450.
  3. R_Little Husqvarna
    NJ
    No loctite....45 in lb max and you should be good.
    It may seem kind of loose but my cap bolt are fine at that torque.
    Funny, my x-light factory manual had torque values for every bolt in the motor but said "xxxx" for the cap bolts....like they did not know how tight to make them.
    wonder if the new 2012 manual has values listed?
  4. kevin holden Husqvarna
    UK
    TE 450
    Does anyone know where i can get a workshop manual for the 2010 TE 450 please just bought this bike with 750 miles on the clock need to check when the oil needs changing valves need adjusting etc.
  5. redneck47441 Husqvarna
    Husqvarna txc250
    WR450
    45inch pounds of torque on the big bolts what about the little ones?
