250-500cc 2010 Wr 300
Discussion in '2 Stroke' started by Chisler, Feb 3, 2020.
  1. ct cr430 Husqvarna
    Connecticut , litchfield county
    1981 cr 430
    2007 honda crf450
    Spectro sells a 10w30 clutch saver oil
    Chisler likes this.
  2. Chisler Husqvarna
    British Columbia, Chilliwack River Valley
    2010 WR 300 Husqvarna
    Found this ..... I’ll have to check around to see if anyone has it
  3. Chisler Husqvarna
    Dirtdame likes this.
  4. Chisler Husqvarna
    Well fun morning looking fer oil ... Lol .. couldn’t find any Clutch saver oil ... but I found this and low and behold ... so far
    the clutch drag has diminished to almost nothing .... a quick test ride brought good results .... I’ll have to ride it a bit more and post up the results .... Rekluse
  5. Chisler Husqvarna
  6. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I'd be willing to give that a try, if it really gets rid of the drag. That's the biggest complaint I have with my 300. In really slow going, the bike will manage to stall with the clutch pulled in, often leaving me in a really awkward position and unable to get a foot to the ground, or kickstart the bike without moving it first.
    Chisler likes this.
  7. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    oil thread......not saying anything just that I use Maxima MTL 75w (extra lite) its a little like water, so I just change it often. And of course have that clutch baselined and in perfect blue printed order ie: all discs flat and in good order, basket in good order, along with arm, bearings and pusher shaft.
    Chisler likes this.
  8. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    my lubricants are buried or I would get what I used posted
    but this is what I had in mind,, a high quality synthetic lube that supports clutch use
    I slide mine in really technical stuff and have no issues with creep or slip
    glad to see it worked, it only gets better when all the plates surfaces are bathed in it for a full oil change cycle, as to clean out contaminants
    Chisler likes this.
  9. Chisler Husqvarna
    Well I had two seats and took one to play around with ... the local upholstery place was able to shave it and retain the original cover ... I’ll give it a try ... here’s some pics with the stocker ... then the shaved 6772A513-CA2B-4D4A-A39C-B09F997F622F.png
  10. Chisler Husqvarna
  11. Chisler Husqvarna
    Oops shaved ... then the stocker
  12. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
  13. Chisler Husqvarna
    One thing I’ve found is that it’s fairly easy to loose your breather tube and fitting on the top of engine case .... the part number for the fitting is ... HQ800019620 its a plastic 90 degree fitting with barbs and can go missing ... like what happened to me .... so when I replaced this take an extra tie wrap .. zap strap or whatever you call them and strap it to one of the breather hoses off the carb ... so ya don’t loose it if the fitting/hose ever decides to vacate your bike ... : ) 4CA78D65-4716-4FF6-BF5E-87EDACD70F48.png
    Goose719 and Huskynoobee like this.
  14. Chisler Husqvarna
    : ) 32B4701F-EC76-4F73-85A6-7D4AC11B50BC.jpeg
    Huskynoobee likes this.
  15. Chisler Husqvarna
  16. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    So.....have you had a chance to put any more riding time on your bike to see how that transmission oil works?
  17. Chisler Husqvarna
    No .... I’m gonna take it out this coming weekend ... I’ll be sure to let you know how things work out .... I’m remaining fairly optimistic that things are going to work good ... she’s ready to ride .... : )
    Huskynoobee and Dirtdame like this.
  18. Chisler Husqvarna
    Well lots of riding this weekend and the bike still has some clutch drag ... but not as bad ... shifts are smooth ... so I’m gonna look into something else ... the bike does idle in gear now ... never did before , I’ll do a few more rides and see if things loosen up ... good turn out up the Chilliwack River Valley .... couldn’t think of a better thing to do with this social distancing thing .... young and old were out .... it was a good time ... my buddy did mention a few things to try with the clutch plates ( drilling holes ) to allow the oil to disperse away from the plates ... when I get time maybe I’ll give this try ... but all in all I like this Rekluse oil .... but not the price .... Lol
  19. Chisler Husqvarna
    Forgot to mention ... the larger rear disc works awesome ... I highly recommend that upgrade
  20. Chisler Husqvarna
    Project today .... packin the Silencer ... : ) DDA71F1C-DDAB-479C-9C71-B1801E0A9DD6.jpeg
