Hello all. It seems like Ive done everything humanly possible and still no charging voltage. Im not going to bore you with my misfortune so here is an update: replaced the Starter Relay, cleaned all of the negative and ground wires including the two ground wires that were bolted onto the starter/engine which were quite dirty. Tested the stator one more time everything looks good. The only thing I have not tried is making a lead to test the negative wire malfunction (bad connection in the negative lead from RR to battery (-). I am not very keen on doing this but will try one more time. I am still getting that fault according to the electrosport manual.
The only other lead I have is what looks like a slightly melted yellow wire at the VR connector. It has left some copper wire exposed inside the connector. I suppose my question is, how do I remove these wires from the connector so I can check them thoroughly???
