2011 TE310 Fuel pump assy. pics and P/N's
Discussion in 'EFI/carb' started by Aaron8, Jun 17, 2012.
  1. blackdiamond Husqvarna
    Simi Valley, CA
    Just to confirm. The CAcycleworks pump does fit the 2011's as well. I recently installed one and all is good. Also, they have changed the type of hose included with the pump. I believe the new hose is more compatable with submerged applications. I do wish there was replacement pump not made in China...
  2. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    Thanks for posting your info, I believe all the newer bikes will be using the standard (for Husky) 30mm diameter pump that is the CAcycleWorks offering for Husky.
    DougW likes this.
  3. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Anybody having fuel pump problems on their 2012 TE310s?
  4. OlderHuskyRider Husqvarna
    Austin, TX
    Kwaka KLE, HD FXDWG
    What are your symptoms?
  5. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    None. I'm just wondering if Husqvarna fixed the problem with the 2012's or if they are still there. Seems like an odd design regardless. Capacitor-fired unit injectors with low pressure feed make much more sense than wasting all that gas tank space with bulky, failure prone high pressure pumps and regulators.
  6. trackguy3 Husqvarna
    Georgia
    TE250
    KTM 525; Honda CRF150, XL125, CL77
    Can anyone tell me how to release the light grey retaining rings/clips on the fuel line? Thanks.
  7. trackguy3 Husqvarna
    Georgia
    TE250
    That's the two inside the tank, not the one underneath on the elbow.
  8. trackguy3 Husqvarna
    Georgia
    TE250
    DougW likes this.
  9. RailwayRog Husqvarna
    Can someone elaborate on this subject. I'm not familiar with the different fuel injection systems offered on motorcycles.
    What dirt bike manufacturers offer capacitor-fired systems?
  10. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Don't know any. Unit injection is usually found on diesels. They use a piston inside the injector itself to create fuel pressure instead of relying on a high pressure pump.
  11. Huskman Husqvarna
    Fort Bragg CA
    2012 TE310
    I wasn't exactly sure if this it the place to ask this question or not, Sorry If I am wrong. I need a Fuel Pump gasket for Husqvarna TE310 2012. I can't seem to find just the gasket and I do not what to buy the whole pump if I do not have to. They are around 600.00 for whole pump system.
    Any information would be greatly appreciated.
    Thanks
    -Huskman
  12. RailwayRog Husqvarna
  13. Huskman Husqvarna
    Fort Bragg CA
    2012 TE310
    Thank you I allready Tried them. They have the gasket for the TC 250 2012 but that fuel pump is different than the TE310 2012. Is the TC 250 and TE310 fuel pump Gaskets interchangeable?
    Thanks
    -Huskman
  14. Huskman Husqvarna
    Fort Bragg CA
    2012 TE310
    Anyone one else have any suggestions on how to find a fuel pump gasket for my 2012 TE310 bike?
  15. Aaron8 Husqvarna
  16. joedirt Husqvarna
    PA
    wr250
    I just replaced mine with an oring Ill let you know how it works.
  17. Johnny Freeman Husqvarna
    TE310
    I'm curious to know how that fuel pump from ca cycles has held up. Mine OEM pump just died and I need to order a new one. Thanks!
