2011 TE449 Running well with factory EFI system - finally
Discussion in '4 Stroke' started by Dangermouse449, Mar 28, 2014.
  1. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    9880sts likes this.
  2. huskyboy410 Husqvarna
    1999 TE410 -2011 TE511-2012 SMR511
  3. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    i am out tomorrow with 2 friends on there 449 and 511. 3 bikes with the Kymco and all did the mod's..... cant wait
    Dangermouse449 likes this.
  4. Motosportz CH Sponsor
    Ride report. I did 74 miles in the high dez yeareday. Bike ran noticeably better, has a good bit more bottom and it is a rocket. As I said before my bike is well sorted, ran very good before and was very happy with it. Now it is simply flawless. I mean it runs absolutely PERFECT. It really is unbelievable. When I say flawless I mean it. Idles perfect, is very snappy, not one hiccup, dead throttle or popping, bogging nothing. Just instant and perfect modulation every single time you hit it. I would have to say this is now the best running bike of any kind I have ever tossed my leg over. Simply flawless how it runs, has huge power, is EZ to control. My buddy with a very good running KTM 350 rode it. His remark on the motor was "beautiful" which is a funny word to describe it but he is right. The kicker for me was he rode it about a mile, said he wanted his bike back and I figured it was to big or there was something he did not like about it. I said "don't like it?" he said... "If I ride this bike any more I'm going to hate my bike". Said the motor was flawless and crazy fast and the ZipTy suspension was out of this world. We nicknamed it the starship enterprise as it just blasted everything. I explained what I had done on the way there and hoped everything was OK for the ride. He said he knew immediately everything was OK as I was exploding every corner exit and was disappearing into the horizon at an alarming speed. The more I rode the bike the more I realized how good it was and how I had been compensating to some extent to ride around it's small flaws. This compensation became less and less as I realized this simple mod eliminated anything I was compensating for. The now absolutely perfect motor, super smooth MWEE clutch lever and amazing ZipTy suspension put me in that zone we all love to find and I could do no wrong. I was hauling ass and it was very EZ. As you can tell I am elated at all this.
    Let me back up a little.
    As I said my bike ran very good before. I was servicing the air filter and thought to myself, it would not take a lot more digging to get that butterfly out and gave it a go. So I did. When I first started it afterwards I was a little spooked it would be fine. Started right up and ran nice. Rode it around the block and it did feel better but on pavement everything feels faster (hook up) and smoother. My house is at about 75 feet elevation. When we got to the dez staging area which is about 3500 feet and was about 25 degrees colder and I tried to start it it turned over about 5 rotations and nothing. I was like "oops, glad I brought the butterfly with me". Touched the button again and it fired right off and idled nice. Not sure what that was about but was not a big deal and my bike has done this cold before. OK, go for a ride and immediately notice, just like other described, it has more snap and pull right off idle and into the first 1/4 turn of the throttle. Was thinking to myself "is this real or am I imagining it because i read that"? The more I rode the more it was very obvious it is running a good bit better and pulls really hard in that first 1/4 throttle. Then I start to notice it seems to not like huge throttle openings in the mid range where before it did not seem to mind that. I was thinking to myself, this is where the butterfly does its magic. It was EZ to reprogram my wrist to not do that and I was rewarded with a great running bike. Then I thought I would play with my JD tuner some. I left the bottom (green) alone as the bottom end was freaking PERFECT. I leaned out the mid (yellow) 2 clicks and richened the top 2 clicks as it seemed like it ran out of breath slightly. Bingo. Mid range was now 100% back and better than ever, top end gained some pull. I did not touch a thing after that because it literally runs perfect. Not perfect for EFI or carb or whatever but simply flawless and perfect everywhere. So feeling all frisky and gaining more and more confidence with every corner I exploded and rock garden I blasted through I started trying to make it stumble or fart. I was going up loose technical foot deep shale hills that can be the bain of a lean or finicky EFI system and purposely going a gear or two high and letting the RPMs drop dangerously low, holding on for the cough and spit me over the bars. The bike simply chugged up it flawlessly and I felt there was almost no way to stall it. It has an old school carbureted big flywheel unstallable feel to it down low now. I did everything i could to induce a stall or, fart or pop or something and it just kept running flawlessly. I'm seriously in shock. I wheelied up on pretty nasty hill and sat at the top while my buddy on the KTM 350 struggled and crashed.
    As you can tell I am giddy about all this. My bike runs absolutely flawless. Has that super forgiving carburator like feel on the bottom but with more snap and simply pulls hard everywhere. Even though all I did to mine was remove the butterfly it seems to come back to idle a lot smoother and perfectly. Again, flawless. It has gained a very noticeable amount of snap and pull in the first 1/4 throttle, has more in the middle and after my JD tweak more on top. I'd say a 15% gain bottom, 10% mid and 10% top. Honestly I was not expecting a lot from this, figured if there were gains it would be small and maybe hard to detect. I have to say I am blown away. Put me in a groove where i could do no wrong. This is semi open dez but has a lot of variety. It had rained some and so we had power robbing deep wet silt. My bike would rip huge 4th and 5th gear 50 mph wheelies though deep whoop fields like nothing. Comes out of loamy deep corners blowing up berms and the front wheel reaching skyward and then jump and wheelie long rows of deep whoops like I knew what I was doing. I felt faster than ever and Travis who I ride with alot said I was absolutely flying. He said he could stay with me for about three corners and then i just faded away into the horizon like I was on a missile. As you can see I couldn't be more happy with this simple mod.
    Disclaimer. I'm not saying you will see the same results but for me on my bike it was transformational which is odd because the bike seemed pretty freaking good before. I am not recommending it as it will for sure void any and all warranties and you are messing with a factory EFI system with components you could ruin costing money. What I am saying though is if you don't care about any of that and are the type of person that likes to try stuff and work on things this mod, at least for me, is the real deal. My bike no longer feels like a good runing 450 but now feels like a real 511 firebreathing beast. It has lost none of its user friendly nature and did not become a handful KXF450 like monster just a absolutly flawless running missile.
    Thanks Dangermouse for the effort and coming here and letting us all know. :cheers:
    9880sts, HusqRacr, 511SF and 5 others like this.
  5. Whittaker Husqvarna
    Flanders, NJ
    12' TE449
    13' KTM 500 EXC
    Damn you Motorsportz! Now I am going to have to remove the butterfly again after this writeup :D. I tried it briefly but put it back on out of fear of losing reliability... oh well. Are you considering the removal of the post by the idle cam for engine braking?
  6. Motosportz CH Sponsor
    I'm not touching a thing. When I say my bike runs flawlessly I mean it. On or off throttle it runs absolutely freaking PERFECT.
    9880sts and Dangermouse449 like this.
  7. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Just to be clear, Motosportz is starting with the Akro/Open Pipe/BMW#3 maps on his ECU
  8. Motosportz CH Sponsor
    - and JD tuner
    Yes, all my bike info is in this thread here... http://www.cafehusky.com/threads/20...y-efi-system-finally.41069/page-9#post-405401
    2011 TE511
    5600 ish miles
    Has always been a pretty good running bike and better with each upgrade.
    JD tuner
    Free flow muffler
    ZipTy remapped to map 3
    Jumper plug in.
    Clean air filter.
    Earth-x battery installed / TPS reset
  9. Motosportz CH Sponsor
    That said I have a strange feeling if you just put a free flowing muffler, did the Zipty map3 and removed the butterfly your bike might just run great.
  10. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    Just so im clear...remove passenger side plastics, pull lower half of airbox and filter, pull off boot/round rubber velocity stack to access front butterfly, remove 2 screws and butterfly, insall boot/rubber velocity stack and lower half of airbox and passenger side plastics, adjust brass tps screw to 2 1/2 turns out (mine is 5 1/4 out now) maybe tps reset, start bike and theres a huge difference?? 2013 te511...fmf, map 3, jumper in and smog junk removed.
    Ive been pretty disappointed with my 13 te 511, i also have 13 te 449 with exactly same mods and the 449 out pulls the 511 so i tend to ride 449 more.
  11. Motosportz CH Sponsor
    Pretty much.
    Again, my bike ran real good before, now it is like :eek:
  12. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    I rode mine a bit today up and down the street...
    The autotune is still working itself out, I did get a ALMOSt stall, I got the cough and backfire through the intake at a near stall situation u-turning, and it KEPT RUNNING! it coughed but kept going!!! Interesting.
    Bike is starting to come alive now powerwise. I was 15/51 stock wheels, now im 15/44 on heavy arse warp 9 supermoto wheels and its taking some use to get a feel for the loss in acceleration, but with the mods, it feels like its getting to be about a wash which is a good thing!
  13. Dangermouse449 Husqvarna
    2011 TE449
  14. Dangermouse449 Husqvarna
    2011 TE449
    Stay calm Moto, take deep breaths! ;)
    Glad it has helped even on a known 'good' bike. Thanks for trying the mod.
  15. nonferrous Husqvarna
    Auckland, New Zealand
    SMR511
    RMZ450
    cheers for the report Motosportz - 10% more power is a phenomenal increase
  16. Dangermouse449 Husqvarna
    2011 TE449
    I have added some edits to the original post, it will make things easier & clearer if anyone is going to do any parts of the mods.
    Thanks for the feedback on the bikes guys, makes the time I spent messing with mine worth it. :thumbsup:
  17. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Kelly would you mind posting your post-butterfly removal JD settings numbers [again] for reference? I just put one on my bike and would like a known good starting point for when I do the butterfly mod.
  18. jasonmt Husqvarna
    Alberta, Canada
    11' TXC 449, 11' TE 630, 11' TE 449
    Ninja 1000, ZX7R, 300 XC-W Christini
    Kelly / Motorsportz's review is going to push me over the edge to give the FBW plate removal a go, I bought a NOS 2011 TE449 for a screaming deal last fall so with only a hour or so of run time on it (and adding a PCV and Autotune) I want to get things sorted out in order and not make multiple changes at once so I will most likely wait until I have a good base map before I try the FBW plate removal.
    It would be nice if the guys with PCV's could post up their maps once they are happy with them.
    danny318 likes this.
  19. Motosportz CH Sponsor
    I could and will next time I check them but every bike and rider is different. Not sure it would super relevant. It ran fine as was but slightly leaner mid and richer top seemed to make it perfect.
  20. Motosportz CH Sponsor
    Obviously thats a wild ass guess but it is very noticeable. Made buddy Travs 350 feel like a 250F with a clogged muffler, not even in the same playing field.
