2011 TE449 Running well with factory EFI system - finally
Discussion in '4 Stroke' started by Dangermouse449, Mar 28, 2014.
  1. Dangermouse449 Husqvarna
    Sunshine Coast QLD Australia
    2011 TE449
    2009 CRF450R 2000 YZ125
    No worries, hope it helps your bike. Made a massive difference to mine.
  2. Dangermouse449 Husqvarna
    2011 TE449
    Lifting the plug end of the TPS upwards (clockwise) makes the voltage rise (Richer) :)
  3. Thrasher Husqvarna
    San Franciso, CA, USA
    '13 511
    To clarify, is this the direction you adjusted the TPS?
  4. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    You can move it in both directions. Just open your powercommander and look at the tps voltage and adjust it.
  5. Thrasher Husqvarna
    '13 511
  6. Dangermouse449 Husqvarna
    2011 TE449
    To increase voltage, yes.
  7. tjb45 Husqvarna
    TE511
    Thanks all. Mine was set at .72 to start with. I adjusted it to .78 for a short ride and the bike seemed to lack a little bottom end power. I'll do a bit more testing tomorrow and see how it goes..
    Its very sensitive to adjust. If you don't have the correct tools, I wouldn't attempt moving it.
  8. michael franzen Husqvarna
    te511
    I separated the generator wiring from the bundle and routed it separate to the regulator on my bike.
    underwatersimon likes this.
  9. Dangermouse449 Husqvarna
    2011 TE449
    Any difference?? Do you have some pics?
  10. michael franzen Husqvarna
    te511
    Cruises 10mph faster smoother no stalling or computer rebooting. AC wiring cannot be bundled with unshielded DC or computer wiring has to be separated.
    Mr Ford40 likes this.
  11. Dangermouse449 Husqvarna
    2011 TE449
    Interesting, good thought. :)
  12. Mr Ford40 Husqvarna
    Labertouche Victoria Australia
    2012 TE449
    YZ250F
    Michael great thought any AC OR DC voltage must have a clearance. Cable supplying data even telecommunications lines must mantain seperation.
    (NO I DONT HAVE A PHONE ON MY BIKE) the cord wasnt long enough.:)
  13. Dangermouse449 Husqvarna
    2011 TE449
    It makes sense to me, the ECU uses mostly 5v max signals, so the operating range is from about 0.5v to 4.5v.
    Wouldn't take much to upset these unshielded signals.
    I'm watching with interest :)
  14. Dangermouse449 Husqvarna
    2011 TE449
    I was talking to a good mate of mine at work about bikes (He's ridden all sorts for years) and currently he has one of those Suzuki V-Strom DS monsters.
    I mentioned the removal of the butterfly from my TE449 & his ears pricked up!
    He said the V-stroms have had the same thing & recently they have been pulling them out with great improvements in rideability.
    Suzuki originally trotted out the same crap Husky floated about 'smooth power delivery', 'increased control' & 'better torque'.
    They had the same problems as Husky too, with bikes that stumble & flat-spot.
    In a complete about-face, the latest 2015 model doesn't have the twin butterfly set-up. It makes more torque AND at lower RPM. :thumbsup:
    It appears Husky & Yamaha weren't the only ones fooled into fitting the system. :(
  15. Husky Bob Husqvarna
    Joburg, RSA
    2013 TE 449
    300 XTR
    I've decided to hold off weighting my 449's flywheel until I have done the EFI mods, it seems the mods may solve my power delivery problems at low rpm.
    My question is really about the order in which the mods should be performed: does it matter?
    I have an appointment next Friday with my dealer to have the Akro Racing map installed on my ECU - should I have that done before I remove the butterfly, or would it make no difference?
    It seems removing the butterfly also increases engine breaking, and then removing the little stopper from the throttle mechanisim further increases engine breaking? Is this an accurate summary? What is that stopper actually meant to do?
  16. Dangermouse449 Husqvarna
    2011 TE449
    I'd run with the map upgrade first & see if you like it like that. That may be just what you are after.
    If you want a little more 'snap to attention' from the throttle, pull the butterfly out.
    It doesn't make more power, just quickens the delivery of the power taking away the electronic delay they built in.
    The reduced engine braking comes from the little idle roller on the primary shaft.
    The cam on the secondary shaft acts on this roller & controls idle.
    The bikes will idle perfectly well without it & by adjusting the brass idle screw once the roller is removed. You could reverse this if needed by reattaching the roller, but on my own bike, I find hot or cold I can still idle fine.
    have a quick read through the first post on the thread & it should become a little clearer.
  17. Campbell Husqvarna
    Molyullah, Victoria, Oz
    BMWG450X
    Hey Dangermousse,
    i reckon this modification will be soon in many TE 449 and 511's.
    All we want is grunt .... forward movement and front wheels popped when we twist the throttle.
    We dont ride on Ice to ask for smooth power....
    And thanks, i never really realised that the Trip meter went to 0 after some Engine restart. The Bigger LITHIUM Battery was another huge improvement.[/quote]
    Great to hear, I never met a horse-power I didn't like!! lol.
    Yeah, with regards to the trip meter, until I fitted the new battery, I'd never had it measure a full ride before.
    I can finally now see how many km I get for a given amount of fuel. We ride fairly rough country, so an 80-100 km ride is about it for a tank.
    It is handy to know if you're going to need fuel.
    After I worked out it was a voltage drop,I opened up the speedo ages ago, but didn't pursue it.
    It looks like they were going to put in a back-up battery system, but didn't for some reason.
    Someone else can have a crack at it if they like :)
    View attachment 39364 [/quote]
    G450X has back up battery ... Husky went cheap on you guys ;)
  18. Dangermouse449 Husqvarna
    2011 TE449
    G450X has back up battery ... Husky went cheap on you guys ;)[/quote]
    Is the G450X dash the same style??
  19. Campbell Husqvarna
    BMWG450X
    Is the G450X dash the same style??[/quote]
    I havn't seen a Husky one - sorry ... do they encourage you to ride harder by flashing 'SPEED SPEED SPEED' at you like the G450X does ... shortly followed by 'FUEL FUEL FUEL' and a walk home.:D
    Mr Ford40, Dangermouse449 and Tinken like this.
  20. Dangermouse449 Husqvarna
    2011 TE449
    Ours just say 'Fail'......but keep running.:thinking:
    Either it failed or it didn't ha ha.
    I know there's limited lcd space/icons etc to tell about logged codes, but 'Fail' seems a bit dramatic. :D
