2011 triple assembly for TXC250 on TE310?
Discussion in '4 Stroke' started by Buster714, Jul 9, 2018.
  1. Buster714 Husqvarna
    SoCal
    2011 TE310
    '04 950Adv, '10 F800GS, '06 R6 track
    I need to find that part# for the fuel pump.
    Why do you think the starter will be an issue @Trenchcoat85?
    The bottom triple clamp was bent, btw.
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    The starter will be harder to source and is relatively expensive (it seems to be an xlite-only starter motor); but the fuel pump is made by the millions (even though it's a 30mm rather than a 38mm dia pump- which is made by the tens-of-millions). Also make sure you need a fuel pump if you're going for the high-end item; or else just buy the cheapie off ebay to experiment with (here you go... $13.46 delivered: https://www.ebay.com/itm/Fuel-Pump-...-KTM-Husaberg-Motorcycle-Scooter/163257471275)
    starter: make sure your ring gear (and worm) are good- it doesn't take too much galling to stall the starter. Husky hardened the gear set for the 2013-2014 models.
    seems like someone found a new starter a couple months ago; also this firm has rebuilt starters:
    Screenshot-2018-2-15 After Market Motorsport Parts from Rick\'s Motorsport Electrics.png
    good luck & keep us posted
  3. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    oh yeah....
    the stock fuel pump part number is: 8000 H3424 and retails for:
    $484 with Motosports discount ($600+ MSRP)
    https://www.motosport.com/oem-parts/part-number/8000h3424
    but I believe it includes everything (flange-to-flange: pump, prefilter, filter, 4 internal hoses, pressure regulator). here's the exact same thing for a KTM (items 3 & 4):
    here it is on the bench:
  4. Buster714 Husqvarna
    SoCal
    2011 TE310
    Alrighty, Ricks looks like they’re unavailable for Huskys at the moment but I’ll start looking around.
    Thanks @Trenchcoat85
  5. Buster714 Husqvarna
    SoCal
    2011 TE310
