125-200cc 2012 125
Discussion in '2 Stroke' started by earl61, Nov 29, 2011.
  1. CelticDude Historically Fast!
    x
    Not great photos but should give you an idea. :confused:
  2. Troy F Collins Husqvarna
    alberta canada
    wr125
    GGEC 250 Honda RC51 CBR 1000rr CR125
    Thanks for the pics..... by crikey !!
    more like scoring from an improperly chamfered port.....or something got in there :thinking:
    I was expecting to see the ring adhered to the ring groove with a siezure (as you pointed out)....looks like the ring is still pretty free
    just by luck you had it apart....just in time
  3. CelticDude Historically Fast!
    x
    Another thing indicating that Husqvarna Quality Control may not be quite what it is supposed to be is that the 150 kit contained new powervalves. Not really necessary since the 125 has the same ones but they were both for the right side! Ha ha! :doh:
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Oh boy! That has to be frustrating!
  5. Norman Foley Husqvarna
    The further adventures of "Enzo and Vito"..... These mythical guys are the ones who add or don't, the little bits in the crate before they close it up. "Enzo, did you mix up the parts for those two 144 kits?" asked Vito. "Not me," Enzo answered back. "I dropped the boxes and the parts spilled out, but I put all the parts back!"
    On the seizure.... Husky had to put out a bulletin to change jetting specs on '11 WR250's with Ducati ingnitions, as the spec used with the Koukasan WR analog ignition was causing seizures. Are '12 WR125 jetting specs different from previous WR125/150 specs with analog ignition?
    Another thought, was the spigot of the pipe tight in the cylinder?
  6. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    That's about right, Norm.
    Another thought, what does the tips of powervalves look like? From the. Picture looks like the eges closest to exhaust bridge are shiny?
    Troy might be correct. Look at the lack of chamfering around the exhaust port corners, closest to exhaust bridge.
  7. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I have , like a 2hr cylinder/fairly new 125 piston. You could borrow it till you get back up and running. You would have to use your powervalves.
    CelticDude likes this.
  8. water racer Husqvarna
    http://www.knoxenduro.com Knoxville, Tennessee
    2013 Beta 250RR
    2009 Husqvarna WR125 1997 Fantic
    I think this wr stuff has been blown a bit out of proportion, do admit they take special tuning and I am very happy with mine. That being said, I have not ridden a cr but sounds like they could be fun and I bet I will eventually get to try one. Still believe a properly tuned wr is better for where I ride.
    GP
  9. Norman Foley Husqvarna
    +1
  10. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    I agree, my WR before CR ignition was tuned great. Those Ducati ignitions with less flywheel mass should spool up a little better.
  11. CelticDude Historically Fast!
    x
    Thanks, but I should have the 150 kit up and running today. I will check the chamfering in the exhaust port.
  12. Troy F Collins Husqvarna
    alberta canada
    wr125
    I suspect that if the seizures were from pinging ie jetting/ ignition related it would be from detonation and the top of the piston would be cratered :thinking:....perhaps some impact material leaving the scene created those score marks......maybe CETIC can let us see the top of the slug ?
    I remember Scotty saying something about a seizure on a new 09 125 he saw once....where the guy went WFO on a cold motor on a fireroad....
    Brings us to another subject.....I always do the ritual to let the bike tick over(say while you putting your gear on) till the bottom of the rads are very warm before your ready for take off.....or perhaps thats just the mindset of a seasoned canuck eh
    ie in a cold engine the piston will always expand way faster than the cylinder around it unless its warmed in a no load condition
    I'm not suggesting thats the case here BTW
  13. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    To me it looks like you had an air leak from the pipe...or too lean somewhere....I would say too lean somewhere...worst cooling part of the motor is right there where you dont have as much cooling....IMHO
  14. CelticDude Historically Fast!
    x
    Here's the top of the piston. Plug color looks good as well. I always warm the motor up properly before I ride.
  15. CelticDude Historically Fast!
    x
    Anyone know the proper head bolt torque value? The owners manual is useless and I searched here also. :confused:
  16. MotoXotica Husqvarna
    Vacaville
    i saw in a older 125 service manual 14 ft lbs.
  17. racemx904 Husqvarna
    owenton, ky
    little too clean for me on a 125...I always liked a little on top
  18. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    You were trying to have a full blown lean seizure.
  19. CelticDude Historically Fast!
    x
    Running stock jetting?
  20. racemx904 Husqvarna
    owenton, ky
    what mixture?
