125-200cc 2012 125
Discussion in '2 Stroke' started by earl61, Nov 29, 2011.
  1. demi Husqvarna
    Cheyenne, WYO
    12 WR 300
    '14 SH 500, 81 Gilera 125 C1, 17 KTM
    17.6-19.6 Nm/13.0-14.5 ft,lbs
  2. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Well, unless you forgot to put oil in it, but that should look worse. Any chance the timing is too far advanced? Air leak?
  3. CelticDude Historically Fast!
    x
    Running Maxima Castor at 32:1 and pump premium gas. It isn't running hot at all.
  4. TROFFER88 Husqvarna
    Camas Wa
    You will be very happy with the Rb Tmxx , no need for a Pwk.
  5. CelticDude Historically Fast!
    x
    That's what I hear. I was going to run the PWK off of my YZ250 since my Mikuni is off to RB but it has the TPS and solenoid enrichener circuit.
  6. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    I know I am prolly starting something but I never liked that oil... But it the plug is the color of a paper sack that is good but that should still equate to more carbon on piston than that...
    Is it possible The carb wasn't in the boot right? Crack in the intake boot? Pipe bent or not seated right? Or even ignition timing off?
  7. montgob1 Husqvarna
    You can still run the yz carb, the solenoid fails closed.
  8. wallybean Mini-Sponsor
    Montana
    The 125 power valves will not work in the 144 as they are too long. Better see if Dan can get you the correct power valve. Let me know if you are able to get one.
  9. Troy F Collins Husqvarna
    alberta canada
    wr125
    GGEC 250 Honda RC51 CBR 1000rr CR125
    Maxima Castor is very high film strength....its old school for sure but least likely to cause a scuff like that....they use it in 125 Carts where they rev the tits off those things...
    It not a good oil at cold temps though...as it tends to separate....and it gets a bad rap cause of that
    NOTE curious if thats the actual color of the top of the slug or did CELTIC clean it off......looks like 15 min run time to me:excuseme:
  10. CelticDude Historically Fast!
    x
    That's all the carbon it had for probably 14 hours running time including a cross country. The power valves from the 125 matched the two they sent me for the 144 kit. Guess I'll have to get in touch with Dan. :eek:
  11. racemx904 Husqvarna
    owenton, ky
    WOW...way way to clean for that much run time...my guess is...air leak somewhere
  12. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Fyi, if you run 3 ounces of Maxima Octane booster per gal with Maxima 927. It won't seperate at low temps.
  13. racemx904 Husqvarna
    owenton, ky
    My bro rac 927 @ 40:1 and he thought he seazed his YZ144...he didnt the 927 had gummed the ring soo bad it stuck it in and gave it really low compression...and his p/v was gummed up bad...
    but whatever oil you are running that piston is way too clean for a 125
  14. Troy F Collins Husqvarna
    alberta canada
    wr125
    Good to know !!!
    that stuff smells incredibly good :)
  15. CelticDude Historically Fast!
    x
    Thanks for the info on the Maxima octane booster. I'll have to order some. Never had a gumming problem with Maxima 927 ever and you can see how clean this one runs. I'm in good hands now, Wally is coming by tomorrow night to take a look at my bike! :cheers:
  16. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    You are in good hands! Get that bike going so you can enjoy it!
  17. john01 Husqvarna
    Powhatan VA
    Give Walt a big pat on the back for me...he's the man. Very cool!!!
  18. CelticDude Historically Fast!
    x
    Right now the biggest problem is the power valves. Also my carb is at RB Designs. Dan brought over a very tired older TM-125 today and we stripped the PWk carb off of it. It may work if Walt can get my Husky running. I spent most of the afternoon working on my YZ250 getting her ready to ride with Dan and Walt on Tuesday in case the Husky has to sit at home.
  19. john01 Husqvarna
    Powhatan VA
    CelticDude don't worry; Walt eats power valves for breakfast lol. Good luck to you and I hope it all goes well.
    typeone likes this.
  20. Troy F Collins Husqvarna
    alberta canada
    wr125
    X2
