250-500cc 2012 wr300 suspension set up help
Discussion in '2 Stroke' started by Bryan M, Apr 19, 2014.
  1. Bryan M Husqvarna
    2012 wr300
    10 GasGas ec300, 12 Ducati Monster
    after riding in moab for 4 days i decided i really dont care for the way way i have the suspension set up on my bike. Im ashamed to say in the ten years i have been riding i have never even adjusted the pre load on my shock on any bike i own. so this will all be foreign to me. Im 208lbs no gear. Im sure the bike is under sprung for me. In fast whoops it kicks to the side and i really dislike that felling of the back end trying to come around on me. in the sand its an absolute handful. refuses to track straight, hard to corner ect. Im sure most of these are suspension tuning issues. my main question is. for a guy who never has adjusted anything suspension releated would you just send it to zipty/racetech/LT and let them set it up and get it close for you or would you try to do it on your own. I still dont grasp the concept of clickers/rebound/compression. Im kind of lost on tuning it but i think the 1st step is correct springs. Any other advice??
    Norman Foley, Steve-oh and ray_ray like this.
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    It's probably best to send the suspension out to an expert. I always can figure out spring rate and preload, but unless you are a seasoned suspension tuner, you should let an expert revalve your suspension for the type of riding that you do the most. I like a lot of high speed float for rocky sections, so I always have my suspension revalved for that sort of terrain. Your professional tuner will also be able to give you tips on how to fine tune your suspension after they have done the work.
    Kyle Tarry likes this.
  3. Bryan M Husqvarna
    2012 wr300
    thats more or less the way i was leaning but i also did read the sticky that suggests getting the proper springs in your bike before doing a revalve. i would say i have min of 40 hours on bike so its probably time for a service anyways.
  4. bigriver Husqvarna
    Salem
    I have the racetech gold valve for the front using the stock fork springs. In the back it has a bladder installed and a revalve with a 5.8 spring. I weigh 210 with no gear. It took some tuning but works well everywhere from desert to single track with a few clicks. A friend of mine sent his to zip Ty with good results.
    gary alger likes this.
  5. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
  6. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    i'd get the right springs and do the basics before sending it out as it may be good enough.
    did you set the sag? try taking some rebound out of your shock to help with the side kicking. it's the bottom adjuster on the clevis. it's kind of a pain to get to as the linkage hides it.
  7. Bryan M Husqvarna
    2012 wr300
    I haven't set the sag yet. I'm going to do that this week to determine if a need springs. Which I'm sure I do. Only thing is I'm really unsure how to set the front sag. Ill.have to do some research.
  8. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Before you make too many adjustments, you said after 4 days of riding in Moab. So, I assume that is not your normal riding area. How does it work for you in your usual terrain? Right springs will be needed, I think .48 on the front should give you the right sag, and 6.0 on the rear should be what you're looking for in springs. I'm 195-200 without gear and that works well for me.
    I'll admit suspension is the most important thing on bike setup as far as I'm concerned, yet I don't mess with it much. I don't think I've touched my shock since about 5 hours, and on the fork I'll just go up and down on clicks depending on how rocky/smooth it is. I'd vote on using a local suspension tuner, as they will be most familiar with what you're riding and be able to get you in the best starting point for your riding -- usually they'll be more flexible if it doesn't feel quite right as well, and will change it up for you without having to do any shipping.
    Kyle Tarry and shawbagga like this.
  9. Bryan M Husqvarna
    2012 wr300
    moab is rockier then my usual spot, but overall somewhat similar (especially both north and south of town out of the slickrock). The side to side kicking off whoops or bumps bothers me at least once a ride. So...ill get some springs figured out.
  10. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    My rear end kicked a lot off whoops and I thought it was related to rebound, but I went stiffer on valving and it didn't help. Eventually I went a lot lighter on compression, and the problem is much better. I think the rear compression was too stiff for slow-speed (relatively) trail whoops and it was just banging into them instead of soaking them up.
  11. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    I had that problem in whoops on one of my bikes too, and lightened up low speed compression on the rear. When that didn't clear the problem up completely, I went a step further and lightened up rebound on the front end a click or two. Then I got my "ride level" in the whoops. Sometimes you have to look at more than just the end that seems to be the problem.:thumbsup:
