2013 TXC310 - Strange Issue when trickle charging
Discussion in '4 Stroke' started by mmuthart, Dec 2, 2013.
  1. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    niice one tinken. hope you are continuing to log all this data into some form of file, you guys being the info google resource for all things Italian/German and now Austrian Husky.
    TXC310 file, TXC310R file, TE511, WR300 files etc etc etc
  2. AEM76 Husqvarna
    2014 TXC310R
    2000 XR280R
    just pull the right side panel and unplug the fuel pump relay if you want to leave the charger on the battery
  3. AndrewRex Husqvarna
    2014 TXC 310R
    2004 KTM 200 SX
    I have a 2014 TXC 310R and it does the clicking thing too. I would unplug the charger and then plug it right back in and the clicking would stop and not resume but, I stopped charging the battery on the bike because I was afraid the relay would start cycling when I was not around and burn up.
    I replaced the Yausa battery with a Shorai LFX14L2-BS12 because it's 3 lbs. lighter but, found the Shorai would not turn the bike over from a cold start. After it warmed up it did fine, but I don't like kicking this bike, so I put the Yausa back in. I bought the Shorai because it was $40 cheaper than the Earth X. Is the Earth X worth the extra money?
  4. R_Little Husqvarna
    NJ
    Do yourself a favor and use the kickstart whenever possible. The E-starts on the x-lite are kinda fragile and I only use mine for re-starts on the trail the few times it stalls.
    I got 3 yrs on my E-Start but my sprag just froze to the flywheel.
  5. AndrewRex Husqvarna
    2014 TXC 310R
    2004 KTM 200 SX
    Thanks for the advice but that doesn't answer my question and it's not my first rodeo.
  6. AndrewRex Husqvarna
    2014 TXC 310R
    2004 KTM 200 SX
    What WPS battery number did you replace the Yuasa with. The cross reference table has numbers like 490-2501 but, the vendors all have numbers like BTZR25-YZ3 (just made that up).
  7. LAHuskyrider Husqvarna
    Mobile, AL
    2014 CR144
    1983 Maico 490, 2013 KTM 300 XC-W
    Mine is the 490-2501 just like you saw. Has worked well for me so far. I got the battery in July/2013 The WPS do not have the BMS system like an EarthX so I would price the EarthX from ZipTy with the CH 10% discount vs. the cost of the WPS battery and decide. With the BMS you can plug up a regular battery charger. Since I can't put a tender on my 310(due to the damn relay clicking), it gave me reason enough to go ahead and pull the trigger on the lithium b/c they can sit for weeks and not lose a charge.
  8. AndrewRex Husqvarna
    2014 TXC 310R
    2004 KTM 200 SX
    I may do just that but, even with the discount I'm coming in around $150 before shipping. Although, I tried to save money the first time and was disappointed so maybe I should just bit-the-bullet and get the Earth-X. The funny thing about the batteries I've tried is the one that starts it better cold doesn't work quite as well when it's hot and the one that will barely turn it over when cold seems to work better when hot. Go figure.
    Thanks, Rex
  9. AndrewRex Husqvarna
    2014 TXC 310R
    2004 KTM 200 SX
    Sorry, don't mean to be a smart ass I know you're trying to help. That darn Husky kick starter is either to long or to short. If you use the ball of your foot (heel down, toe up like I do with my KTM) method my toe hits dead into the foot peg. If you use the arch of your foot (toe down, heel up) method I slam my arch into the peg, ouch! I like to trail ride wearing trials boots for feel and they just don't have the protection of my MX boots. I'm just being picky.
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    If you choose to buy a Shorai, you must buy their $80 charger to get any real life out of their battery. When you price your next Shorai, be sure to add the $80 to it. The WPS cannot be load balanced by any means. Typical life of a non managed lithium battery is one year, where as the earthx will go 3 to 8 years.
    We have dissolved the Zipty discount on earthx batteries because a CH member decided to circumvent us and demand our discount from Earthx directly. Our discount is still active for our other products.
  11. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    That sucks:banghead:
    Tinken likes this.
