2014 FE 511 Project Pics
Discussion in 'General (Main)' started by WLDracing_3G, Mar 10, 2014.
  1. WLDracing_3G Husqvarna
    Perris, Ca
    2014 Husqvarna TE 511
    2013 Raptor 700 SE, 2011 YZ450F
    Stock suspension, it held up in the slow stuff but definitely needs spring upgrade and revalve, however the suspension surprisingly worked okay. I could tell that the way the valving was setup it was setup to have a progressive feel. I did not ever feel it blowing through the stroke and bottoming. Rather compressing and becoming stiff at max compression, rebound was great, kept the wheels on the ground and no pogoing. Stock setting 10 compression 10 rebound, I didn't change anything. I look forward to how the suspension will feel and the bike react with new springs and a revalve.
  2. WLDracing_3G Husqvarna
    Perris, Ca
    If you have upgraded to LED flashers:
    Another added item from Sicass is a flasher module (item# 22-300 $23.98) , again it plugs right into the stock flasher plug. You can find this behind the headlight. Stops the flasher from blinking super fast.
    I also added a stainless steal oil filter filter from PC Racing part PC167 $19.99 got it at powersport superstore.com.
    See Tinkens writeup about oil filters:
    http://www.cafehusky.com/threads/oil-filters-for-the-449-511s.29284/#post-263422
  3. huskylove Husqvarna
    norcal
    1999 cr125 in progress
    Looks like fun and we got our bikes at the same place :)
    I keep joking it was so cheap I should get another one!
    Looks like fun :)
    Be sure to grease the swinger/shock bearings, when I pulled mine apart yesterday with 570 miles one of the bearings was quite dry and not in good shape. The others could use some lube.
    michiganguy and WLDracing_3G like this.
  4. Muchmore Husqvarna
    2012 TE511
    BMW K1600GTL
    Every time I catch up on this thread you cost me money!! :mad:
    michiganguy, WLDracing_3G and Tinken like this.
  5. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    So there's an FMF pipe available for the 14 TE511? I called FMF and they said they don't have one yet. That was yesterday. What pipe did you use, and where did you get it, WLDracing? I'd like to get this sorted as soon as possible so I can get some performance out of this thing.
    WLDracing_3G likes this.
  6. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    Awesome stuff. I've already ordered the ignition switch you mentioned above. And now I have a lot more cool stuff to add to my list. Thanks for posting all this great information and location for the parts. I have the identical bike to yours, got mine from Bert's as well. Once I get things done, I'll have to post my mods as well, which are very similar to yours. Again, great stuff here, really helps me a lot. Thanks again.
  7. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    WLDracing, can you tell us where you purchased the Voyager? And is it specifically for the Husky, or is there a universal application? Thank you.
  8. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    13 and 14 bikes should be the same for fmf pipe.....
  9. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    I would think so, too. But the FMF rep said "no." Which doesn't make any sense to me, as I see these pipes on new machines. So people are obviously ignoring FMF and putting the mufflers on anyway. Can anyone tell me exactly what they did, where they ordered theirs from, and how much it cost roughly? Just trying to sort this out. Thanks.
  10. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    They're idiots.
    2011-2014 are the same. And they have pipes for the Austrian bikes too.
    bigmo, Te_Dug and TomGlander like this.
  11. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    Very good. Now that I know, I'm empowered. Also been studying the article you posted about oil. So much voodoo out there. I've always been of the mind to make my own decisions based on a certain amount of research, not too much, not too little. Thanks for the excellent information.
  12. Teambowles Husqvarna
    NorCal
    19 FE501
    Check with the sponsors on here first Ziptyracing, bills, etc...I bought mine from Rocky Mountain mc before I was a CH member. Paid about $350 ish, they're made for our bikes and both mine fit great. With all the help the members and sponsors provide here I'm a firm believer in supporting them.
    ripnriding and WLDracing_3G like this.
  13. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    Will do what I can to support. Thanks.
  14. bigmo Husqvarna
    TE449
    I would be surprised if ANYONE in FMF actually knows what a Husqvarna actually is - let alone a TE. I was asking some simple questions about the potential for a Q for the TE (since they make a setup for the TC) and I was informed they "are as different as apples and cucumbers" and there is no way they would ever get a Q to fit a TE...I gave up there.
    After about half a dozen calls and -gasp- half a dozen different answers (oh they dont do email FYI) I wound up with the PowerCore 4 with the quietest insert available (part no 040671). This is a 1.125" opening (looks sort of puny) and it REALLY quiets the bike back down. Not OEM quiet, but it is very good. It sounds like the KTM RFS out of the crate - in fact as soon as I fired it up, it is the first thing that popped in my mind.
  15. WLDracing_3G Husqvarna
    Perris, Ca
    Yeah, thanks for mentioning that.... I stripped down the bike from wheels to swing arm and all pivot points and greased them. However I was surprised how well they where greased.
  16. WLDracing_3G Husqvarna
    Perris, Ca
    FMF Powercore 4 item# wps 790-3052, I got mine from Langston Motorsports ask for Breena
  17. WLDracing_3G Husqvarna
    Perris, Ca
    Thanks Tom ...Lots of cool stuff for the our bikes and believe me when you get the performance stuff dialed in your bike will run like a champ
  18. WLDracing_3G Husqvarna
    Perris, Ca
    Hey Tom,
    The Voyager is made specifically for the Husky application part # 56-4955, you will have to purchase the protector separately. Just call Trail Tech, they are really great and helpful in the application for our bikes.
    360) 687-4530
    http://www.trailtech.net/
  19. WLDracing_3G Husqvarna
    Perris, Ca
    Yes the FMF pipe is the same for 11-14
  20. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    Thanks guys for the pipe info. I just ordered one. Going to try it without doing any mapping, but if needed, I can always put the stock can back on until I get a JD PowerSurge device. I don't want to go the Power Commander route, as I don't have that kind of cash laying about. I hear the JD unit works great. So the pipe is actually an FMF for a 2012. If it doesn't fit, I'll just send it back. But I have a strong feeling it's going to work just fine.
    The voyager looks like a nice unit. I'm not sure I'd use the GPS, however, so maybe something less expensive that gives more information. I'll lose the fuel level info, but it's so tiny on the OEM unit that I didn't even see it, and ran out. So a lot of good that did, huh.
