2014 FE 511 Project Pics
Discussion in 'General (Main)' started by WLDracing_3G, Mar 10, 2014.
  1. bigmo Husqvarna
    TE449
    #3 sort of not right (close). The maps loaded or flashed si a "set" of maps. Your switch will toggle between the "set" of toggled maps.
    Also, don't forget the JD Tuner - that is similar (in some ways to the PCV) but breaks the "digital jetting" back into something that we are more familiar with ie pilot, needle and main. I know several folks that run the JD on Keihin EFI bikes and really like it. With some fine tunign they are very happy.
    That being said, all I did is have Map Set 3 loaded by my local dealer (they referred to it as "BMW Race Set #3" - not sure if that is the proper verbiage) and cannot imagine running anything else. The bike is flawless. I guess fuel consumption could be an issue if you were trying to squeeze > 80 miles out of a tank - then another map would be nice.
  2. WLDracing_3G Husqvarna
    Perris, Ca
    2014 Husqvarna TE 511
    2013 Raptor 700 SE, 2011 YZ450F
    I wanted to show you earlier what I did with that black canister (Black Coffee maker on the left side of engine)
    Black Canister
    3 hoses
    The bottom hose is routed by the engine guard and is a overflow. Remove this hose.
    Top front hose is routed around to the fuel tank. Remove this hose from the canister and route to the back and thru to the bottom of the engine. This is an overflow for the fuel tank
    Top rear hose goes to the left side of the Cylinder head. Remove this hose put all removed parts in a box, and save it for a rainy day. Cap the nipple with a vacuum cap and wire. (purchase at Autozone for $2.) See Pic P1360865.JPG
    12NengPSG likes this.
  3. WLDracing_3G Husqvarna
    Perris, Ca
    An item I always used when racing motocross was the fork air bleeders. Your forks through compression and rebound will build up air pressure and will affect how your forks works. These are not air forks so you don't want air in them.
    Solution
    Fork Air Bleeders. Just put your bike on a stand where there is no weight on your fork (if you weight the fork oil will come out,,,you do not want that), press the button and this will release the air. $20
  4. WLDracing_3G Husqvarna
    Perris, Ca
    Thanks for clearing up the map issue. Heck I am just learning myself. And thanks for your knowledge.
  5. WLDracing_3G Husqvarna
    Perris, Ca
    I added the ZipTy's Husqvarna Billet Gas Cap . (caution: do not over tighten, backpressure will make this a bear to remove)$59.99 P1360860.JPG
    Tinken likes this.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    The JD tuner is obsolete for 449/511s which will accept map #3. The pcv is the best because of the precise fuel tuning, plus the ignition map. Additional maps may be installed and switched on the fly making this an ultimate solution.
    WLDracing_3G likes this.
  7. WLDracing_3G Husqvarna
    Perris, Ca
    Thanks Tinken
    Tinken likes this.
  8. WLDracing_3G Husqvarna
    Perris, Ca
    I found a great solution for keeping it somewhat street legal with a full adjustable mirror. This is the Double Take Mirror. The great thing is it integrates with the existing mirror perch, and when you hit the trails you can completely fold it away or quickly remove with no tools.
    View: http://youtu.be/P-6fLlW54Y8
  9. WLDracing_3G Husqvarna
    Perris, Ca
    Project is almost complete.
    I will be adding ZipTy's Oil Circulation application as soon as it is available.
    After my first oil change, I changed to a PC Racing Stainless Steel Oil Filter model PC167 and the Magnet
    See this write up from Tinken: http://www.cafehusky.com/threads/oil-filters-for-the-449-511s.29284/
    I will be adding ZipTy's XF + Waterless Racing Coolant as soon as it is available.
    That is about it for now. I will be testing some Kenda Parker DT's soon and will submit my thoughts on the performance of these tires.
    Oh I forgot one of the most important things is the suspension. I will be having my suspension done this week by Shock Therapy (714-724-9005). I have been with Shock Therapy as a sponsored rider since 2009. Steve Piattoni is the Owner, Racer, Tester and has a crew of MXVets that race, test, ride and just shred. I have had a few companies (Not ZipTy) that just did not give the track side support needed when tuning your suspension. Shock Therapy assisted me at the track during practice and racing to dial in my YZ450F. They helped me in finishing 3rd overall for 2012 with Over the Hill Gang VET MX Racing Club.
    I am not trying to take away from ZIP Ty Suspension Service, just offering my experiences and Suspension options.
    P1360875.JPG .
    Bomber1b, TomGlander and ST Rich like this.
  10. bigmo Husqvarna
    TE449
    Geeezzzz...you guys make me sick. Look at that bike! Look at that garage!
    I feel as if I should be tried for bike abuse...
  11. TomGlander Husqvarna
    Orange County, CA
    2014 TE 511
    I like that bike stand. A lot. Very cool. Oh, and the garage is ok, too. The bike? Yea, it's great, too. :applause:
  12. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    You can remove that brass fitting and replace it with a 8mm bolt (not sure on size exactly). Eventually that rubber cap will crack and lean you out.
    Also if you haven't taken a look already, check out our brake pedal tip. You will want to add a brake snake as well, these brakes tend to bend outward on slide outs.
    Flip your capacitor over, this will allow it to cool better and save you some headaches down the road. Remove the spark coil ground wire from the cylinder head and place it on the frame above. Add an additional ground from your battery to your subframe.
    After you get your suspension re-valved, push your forks all the way down in the triple clamps and set your race sag to 100mm for general riding. If you plan to ride in the sand here in SoCal/Lucerne/palmsprings, etc., plan on sag settings as low as 120mm and possible -4mm shortening of the rear shock.
  13. WLDracing_3G Husqvarna
    Perris, Ca
    Wow, that was going to be my next question "How much Race Sag on this 511"....Thanks very Much Tinken ....I will do these mods. And thanks for getting me that Shifter Tip so fast.
    ZIPTY is the Greatest !!! :applause:
  14. WLDracing_3G Husqvarna
    Perris, Ca
    Hey guys looking for a wider shifter TIP and or a whole shifter lever assembly for a TE 511. I have searched and found no aftermarket levers...
    Any help would be appreciated.
  15. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  16. WLDracing_3G Husqvarna
    Perris, Ca
    Tinken likes this.
  17. WLDracing_3G Husqvarna
    Perris, Ca
    Capacitor Flip
    Another tip if you are going to race or ride hard is flipping your capacitor . The capacitor as it is installed is very close to the motor and does not get that much ventilation therefore will overheat and the affect will be pour engine performace (Round rubber coated cylinder mounted on the back of the engine just in front of the rear shock.
    Solution:
    See this for move tips : http://www.cafehusky.com/threads/449-511-ignition-ground.28115/#post-253500
    This task was a bit of a pain and involved rerouting wires.
    The Best approach in doing this I found, was when you flip the capacitor you will find the capacitor wires will be on the right side of the bike and wires will be tangled, I found to do this with no tangles you should reroute (ground wire, capacitor wire, brake sensor wire.) Read below:
    1. Remove the rear Shock ( I had to anyway to get my suspension done)
    2. Loosen (not remove) the capacitor bracket
    3. Remove the capacitor from rubber mount, will easily slide out of rubber mount
    Note: The wires may be intertwined so removing the wires from the plugs will help in rerouting for a clean race to its destination.
    4. Cut the two zipty that hold the ground, brake sensor, and capacitor wire.
    5. Remove the screw for the ground and reroute to the right side of the frame, then reattach screw to engine.
    6. Unplug both brake sensor, and capacitor plugs and reroute wires to the right side of frame, plug wires back into plug.
    7. You will see that the wires fit nicely on the right side of frame.
    8. Tighten capacitor mount.
    9. Zip Ty the wires to the frame
    10. Reinstall the shock.
    Grounding to the engine alone is not a good practice because of the affects of vibration to connections. I reroute the ground from the spark plug to the frame.
    I also ran another ground from the battery (negative) to the subframe.
    Tinken likes this.
  18. Motosportz CH Sponsor
    As you know I have map3 and still run the JD tuner. I feel it actually works better with the JD. With the JD set to do nothing it is still a tad lean on my bike but bump the JD up slightly and no stalling at all and more roll on power. I like using both. For a $40 remap the map3 is awesome. The JD was already on my bike and makes map3 awesomer. This setup with the MME clutch lever transformed my bike for single track work.
  19. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Yes, but you already had the JD tuner. I wouldn't buy a JD just to tune map3, I would buy a pcv and really make big changes to both the fuel and the ignition timing.
  20. Teambowles Husqvarna
    NorCal
    19 FE501
    19 ktm 6 days excf 450 n excf 500
    Once you put that pipe on bro you won't ever go back, wakes it up big time...I ran mine for a bit with jumper and pipe only then did map 3. Whole new bike with pipe map 3 and jumper. It will run a little lean with just pipe, map 3 gave it it's top end back after pipe....then flame outs began, tps reset adjusted screw and alls good again. I'm like you I didn't want to do any tuners, mine runs great without one. I'm loving the Mobil 1 0w40, just put it in my zx10 too, it's going in my jeep next oil change also.
    TomGlander and WLDracing_3G like this.
