TE/TC 2015 te300 jetting recommendations
Discussion in '2st' started by Scott Peterson, Jan 22, 2015.
  1. KddF1 Husqvarna
    Arlinghton Heights, IL
    2015 TE 300
    Thanks Scott. Holy crap that's a lot leaner.
  2. KddF1 Husqvarna
    2015 TE 300
    So finally got to ride for the first time this weekend. A buddy had a Red JD Needle, so i ended up with that plus 35 PJ and 165 main. It seems really good!
  3. Scott Peterson Husqvarna
    2015 te300
    Rode the vantage poker run on Sunday. Elevation is approx 1000 ft. Bike ran excellent over 40 miles of sand and whoops. Had to turn air screw out 1/2 turn more to 2 out. Bike lugged through sand and up hill climbs with zero bog. Very happy with jetting. Took just under 2 gallons of fuel. Pretty good considering bike was under load all day.
    robertaccio likes this.
  4. KddF1 Husqvarna
    2015 TE 300
    Yep - i was out 2 on the air screw as well. did plenty of slow technical stuff and some open fields - no issues. Thanks again for the tip!
  5. Mack McDonald Husqvarna
    Hood River Oregon
    300te and 2 250tc
    3 2015 Huskies
    My te300 wouldn't accept the magic N3ch needle with stock jets.I finally lowered the stock needle to 2nd position with 35 PJ and 168 Main,which improved performance overall,but it still doesn't rip.Evidently porting and or timing has been altered from the factory.
  6. Mack McDonald Husqvarna
    Hood River Oregon
    300te and 2 250tc
    3 2015 Huskies
    I've checked with my dealers wrench on what the heck to do,they were slightly baffled as well.So after may attempts I'm at 35 pilot N3CH needle 2nd position 168 main,and stock yellow power valve spring in from the casing 4 turns,that is the best I've found for 2015 TE300.Since Keihin doesn't make a smaller pilot than stock 35,there is no other way to lean out the idle bog.What about changing out the slide?Anyone have any experience? And Airbox vents,next thing I'm going to try.
  7. mrkartoom Husqvarna
    western Mass
    08 TE610, 15 TE300
    03 Beta Rev
    I've ordered a 6.5 slide and a couple needles based on some setup info I was given. Still waiting on that to show up. My bike is brand new and I've only had a chance to start it up a couple times. It's way too rich stock and won't clean out. I'm at about 300 feet above sea level.
  8. Willlyons Husqvarna
    Hood River, OR
    17 FE501
    85 Yamaha TY350, 06 Montessa 4RT
    I ride between 900-1500' elevation, and just changed back to my summer jetting, which seems to work pretty well. I'm at 35P, 168M, Suzuki NECJ needle in the middle clip (3) a 1.5 turns out on the air screw. Seems to work pretty well around here, may drop the needle one clip because I think it's still a touch rich.
  9. Scott Peterson Husqvarna
    2015 te300
    Just rode the desert 100 poker run. Elevation approx 1000 ft. Jetting I listed earlier was great! Cleaned out good. Very pleased with stock suspension but new springs for my weight. Love this bike!!
    ray_ray likes this.
  10. Willlyons Husqvarna
    Hood River, OR
    17 FE501
    Hey Scott, I met a guy on an airplane from Wrangell, AK to Seattle the other day and he was talking about the Desert 100. He said a buddy of his just bought a new TE300. Wonder what the chances are that's you? Never caught his name but he was telling me about doing a couple Baja 1000's and I think he was up in Wrangell working on swimming pools.
  11. Scott Peterson Husqvarna
    2015 te300
    Wasn't me. Saw a couple over there. Great time and I'd recommend everyone try it once.
  12. Mack McDonald Husqvarna
    Hood River Oregon
    300te and 2 250tc
    3 2015 Huskies
    I have two new 2015 TC 250's, and they both are jetted so rich they are fouling every ride.Anyone have a good jet solution for them?
    fletchman45 likes this.
  13. fletchman45 Husqvarna
    park rapids
    On a different note remember the 92 husqvarnas two strokes were super fast (different cylinder?) Exhaust bridge??? Stock jetting plowed corn field early morning enduro if my mind serves me correctly three new huskys with stock jetting seized!! Every one seems t have different theory's on jetting. I like to be a tish fat on the main jet just so if I'm in deep sand or a long fireroad I Jave no worries. On this 15 tc 250 I havnt touched nothing not even the air screw and it seems to run fairly well although the warmest its been is 60 degrees or so....
  14. fletchman45 Husqvarna
    park rapids
    Ride it like a two stroke should be. On the gas! Elevation??? Mine is stock strong and have had a lot less problems then say a 12 gas gas....
  15. Cameron Lemon Husqvarna
    New Brunswick, Canada
    2015 TE 300
    2007 KTM 250 XC
    My 2015 TE300 was very rich. Long story short, I am running the N3CH needle (3rd), 35PJ, 168MJ, AS 1.5 turns out and its pretty good now. I'm still not happy with it though, but getting closer. Still have a slew of needles to try yet. I'm at sea level (0-1000), days are probably averaging 14C. I may do a few test runs with the airbox cover removed as this new airbox seems to be restrictive. Down low, the power is good, but mid-top is not great yet. I run the blue PV spring flush.
  16. Willlyons Husqvarna
    Hood River, OR
    17 FE501
    I've changed mine to 172 main, NECJ needle on second clip down, 38 pilot, 1.5 turns on air screw. Rode in Kentucky, 800-1500' elevation around 80-90F.
  17. Scott Peterson Husqvarna
    2015 te300
    I still swear by my jetting I listed in the original post. Rode from sea level to 2500ft so far and runs great! Very small it of spooge from exhaust and plug is on rich side. My riding style is more of a Luger. It cleans out great when opened up though.
    Geoffrey Stenta likes this.
  18. Geoffrey Stenta Husqvarna
    2015 TE300
    None
    Hi all.
    Just picked up a 2015 TE300, and I noticed it was way too rich from the factory.
    Picked up the bike from the dealership (Edelman Sales) and rode one time last weekend with it. The bike ran fine.
    I bought Golden Spectro to mix at about 44:1. I added about a 1/3 of a tank and rode around a little. Went to start the bike the other day, and it wouldn't start. Cranked for a bit and checked the plug and it was definitely fouled.
    Also noticed oil residue dripping from the tailpipe onto the swing arm. The manual lists the recommended ratio as 60:1.
    Between my rich premix and the rich jetting, the motor appears to be flooding with fuel and won't start.
    I will most likely be ordering the JD Jet kit since that seems to be the concensus.
    Thanks!
  19. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    y'all check your float heights.....just rode this weekend with another KTM300 (same engine and config as TE/TC Huskys) guy who has been getting stupid low fuel mileage, like mine first was.
    tipped his bike maybe 5-10 degrees to the side and fuel straight poured out of the overflow (I know that's unscientific but its s quick way to physically see how high the bowl fuel level is. on mine I can now go almost 45deg with no overflow and mine is at slightly above the minimum height. Im sure KTM does not even go inside these carbs, they are Keihin sourced and probably assembled in cheap labor factory in the Far east......rather than chasing jetting by trusting the base settings get inside and at least verify the float height. My suggestion.
    lankydoug likes this.
  20. hawaii-rider Husqvarna
    Graham Washington, Fort Moose
    2018 TC250, 2015 TE300
    04 CRF-270x, 95 CR500, 93 CR250 etc
    I have my Main jet # at the house but I went to the NECJ (RM250 Needle)
    did I think.... ONE up from stock (not positive maybe two) on the main and that needle and DONE - perfect.
    Pilot no change
    AS = 1.5
    Western Washington - Sea Level and UP UP UP!
    HR
