TE/TC 2016 TE300 JETTING
Discussion in '2st' started by Tetley, Sep 14, 2015.
  1. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    What altitude are you at?
  2. Tetley Husqvarna
    UK
    EUREKA Just took reed valve block off, and 2 of the inner reeds are not seating properly, one has a small gap and the other is slightly twisted. It doesn't appear to be the actual carbon fibre reeds, but the block itself, I turned the reed upside down and it's still the same.
    This perfectly explains why I have the air screw 4 turns out, leanest pilot jet, leanest needle, and have very rich 1/4 throttle, due to the blow back allowing the intake air to pick up fuel several times through the carb.
    The bike is out of warranty now, so I'll have to see what hapens about a replacement.
  3. racemx904 Husqvarna
    owenton, ky
    Makes sense....
  4. Tetley Husqvarna
    UK
  5. Tetley Husqvarna
    UK
    Picture above showing light passing through bad reed petals
  6. racemx904 Husqvarna
    owenton, ky
    Thats way bad.... i've had reeds with just a small crack act up...
  7. ErnieL Husqvarna
    2015 TE300
    2003 YZ250
    Wow that is a huge gap
  8. Cameron Lemon Husqvarna
    New Brunswick, Canada
    2015 TE 300
    2007 KTM 250 XC
  9. Tetley Husqvarna
    UK
    New reed block arrives today, free of charge under warranty, despite the 1 month warranty being expired :)
    Michael Ryan and racemx904 like this.
  10. Tetley Husqvarna
    UK
    Got the new reed block, and there are gaps but not as bad as the old one-
  11. Tetley Husqvarna
    UK
    There are gaps, but a lot smaller than before, and no twisted petals. (On further inspection of the old block, the offernding petal is twisted, hence the non parallel gap)
    I then unscrewed the new block and rebuilt it so the screws hold it together tightly, but with no distortion, and the gaps closed up.
  12. Tetley Husqvarna
    UK
    So, awaiting a road test when I've decided whether to go mousses or UHD tubes.
    (got a nail in tyre last time out, with the OEM condom thickness tubes. Was 2 rides short of binning them anyway....)
  13. ajaxauto Husqvarna
    Here is what I have found to work on my 2016 TE 300 I installed the other needle that came with the bike found that the clip worked best on second grove down from the top I installed a 172 main that is about it I rode everything from King of the moto trails to wide open and it worked great I do run straight leaded race gas at about 35 to 40 to 1 with lucas 2 cycle oil I also changed from the stock 7 plug to a 8 plug
    It is working if I change I will post
    Also rode from below sea level to 4,000 feet no problem
    56on449 likes this.
  14. 56on449 Husqvarna
    Summer: Ontario, Canada / Winter: Arizona, USA
    2017 TX300
    2009 BMW R1200GS
    Thanks for sharing the info, I have been experiencing a lot of blubbering at low RPM's. I will give this a try and see if it works for me also.
  15. ajaxauto Husqvarna
    First time I installed the needle I was told to put the clip in the 3rd spot or middle When I did it would run good down low like in the rocks But when you got on it like in open higher speed section It had a flat spot miss at about half open Once I change the clip to the # 2 spot it was all gone and ran fine everywhere
  16. Michael Ryan Husqvarna
    Perth , Australia
    2016 TE 300
    2015 350exc, 89 CR 500
    So I'm still getting a slight bog off the bottom if I snap the throttle on from idle to Wide open. If I roll the throttle on it is fine, or of the revs are up its fine, but I can't seem to get on top of this issue. Running the Air screw at 2.5 turns out ( set this by listening to the engine and leaving it where the revs are the highest ) , using a suzuki triple taper NECJ on the 2nd clip from the top ( was at the 3rd ) and just intatalled the red Power valve spring. Using a 35 pilot/172 main and 85 start/idle jet. Im in oz, the temp was around 25 celcius and sea level.
    I havn't checked the float level yet….A bog off idle suggests a "lean condition" but it doesn't really clear up if the air screw is wound nearly all the way in...if I wind the air screw all the way out I can get produce a definite "lean bog" .
    Im a little confused because I don't think it is lean, I'll have a play later on and install the next size pilot for trial and error….but the air screw setting now suggests the correct pilot.
  17. Lincolnlock Husqvarna
    Mount Vernon, WA
    I also fought with this a bit. Lower your float level. After doing this I put a 175 main in. I am also running the same needle and pilot as you are. I ride from sea level to 1400 meters all the time.
  18. Michael Ryan Husqvarna
    Perth , Australia
    2016 TE 300
    Thanks for the advice, i'll check my float and report back. It came with a 175 Main but I dropped that to a 172 as a plug chop showed it was still pretty rich.
    Hopefully the float level cures it
  19. Tetley Husqvarna
    UK
    Finally after 5 weeks of not riding, I got out last night and tested the new reed valve - What a difference ! The bottom end has really cleaned up, and the bike is running really smooth now. The transition from idle burble to clean running is now nearly seamless, no snatchy on off power delivery, and it runs clean when cruising on the road.
    I recently bought a NECJ RM250 needle, so will try that soon, and report back. Happy days!!
  20. ggg Husqvarna
    TE250 14
    NONE
    necj on clip 4 second from top is very rich for a 300.
    250's generaly run larger jets than 300's but only the next size up, i am at seal level in OZ 14/ 250
    40 P, NECJ clip 3, 168 main
    if i had a 300
    38P A/S 1.5 turns out
    NECJ clip 3 or 2
    165 main
