430 auto parts needed
Discussion in 'Vintage/Left Kickers' started by ajcmbrown, Sep 20, 2021.
  1. ajcmbrown Husqvarna
    Metung Victoria Australia
    400WR 250WR 07 WR500 430AE 360AE
    1985 500CR Ducati Multistrada 1200S
    This was a very complete bike, registration plate still fitted from many years ago.
  2. ajcmbrown Husqvarna
    A few more...
  3. ajcmbrown Husqvarna
    And more...
  4. ajcmbrown Husqvarna
    and more
  5. ajcmbrown Husqvarna
    Some interesting tools.
  6. ajcmbrown Husqvarna
    More tools
  7. husky jim Husqvarna
    USA
    14 WR300, 87 430wr, 86 430ae, Tr650
    The inside diameter of the drum is 130mm
    Let me know what elese you need!
    ajcmbrown likes this.
  8. husky jim Husqvarna
    USA
  9. husky jim Husqvarna
    USA
  10. Rowan Husqvarna
    Christchurch New Zealand
    87 430 auto
    I have finally had a chance to measure up my factory shoes - photos are here. I have no set measurements regarding wear limit so thanks Jim for your help. I now have to build these up to Jim's thickness and then off to the foundry.
  11. Rowan Husqvarna
    87 430 auto
    These are my factory shoes for my '87 model. The 2nd and 3rd gear shoes are different and I recall reading somewhere that they were changed in '87/88 to give slightly different shift points. The 500's and earlier 430's used shoes that were the same for both gears so maybe OP's bike has been upgraded. His shoes are worn out and stuffed anyway. He has a bit of time anyway because his engine needs a complete clean out and going over - cases, new bearings and rebore.
  12. Michel Dufayard Husqvarna
    France
    These are the NOS shoes I own.
    I can lend you those to give to the foundry for a neat model.
    The numbers I wrote are those written on the bags where they were found.
    Must be some mistakes on numbers.
  13. ajcmbrown Husqvarna
    You got that right Rowan, just for a laugh, I'll measure my shoes in comparison to your new shoes. Should be interesting since it was still "working" when parked.
    As an update, I have sourced a complete intermediate shaft with shoes, drum etc. locally here in Australia along with a good set of casessince the main bearings have spun in my cases.
  14. Rowan Husqvarna
    87 430 auto
    Well I finally made some progress in rebuilding my shoes up to standard specifications. I had to find some cardboard that is the right thickness - I eventually got some from a friendly printing company.
    I just used double sided sticky tape to hold it in place - it works very well.
    All my factory shoes have been modified slightly. There are two places where they have been filed/machined flat spots. There are small holes for screws to space them out a little - to compensate for wear on the shoes. The only problem with this method is that the springs will be over-stretched and brake much more easily. I know this from experience. IMG_7593.jpeg IMG_7594.jpeg
    stormer254 likes this.
  15. Michel Dufayard Husqvarna
    France
    You mean that on 1st clutch shoes ?
  16. Michel Dufayard Husqvarna
    France
    What about the idea of gluing some brake material on shoes ?
  17. Rowan Husqvarna
    87 430 auto
    Yes Michel - my clutch shoes currently have mall screws to space them out - just like your photo. Eventually the clutched will wear and end up stretching the springs even further to engage - the springs will be over-stretched and brake. This is what was happening to me several years ago - ride for half an hour and suddenly have only a 2 speed auto because most of the springs had broken and the clutches were all engaging at the same time. I would have 1st gear and 3rd gear - not a happy riding experience.
    I recall being told several years ago that brake material would not be good for the husky shoes. Clutch material is usually designed to work on a dry clutch - no fluid. I know that some farm tractors have wet clutches but you would still have to cut grooves (like standard shoes) and this would cause the material to wear quickly. Also getting such a small amount of material to stick properly would be a problem - according to a clutch shop.
    I see that the shoes in your photos are custom made - machined from solid material. Is it the same hardness as the standard shoes?
  18. Michel Dufayard Husqvarna
    France
    128527_642_nissen3.jpg 128527_671_nissen4.jpg 128527_1541_nissen5.jpg 128527_749_nissen6.jpg
    About the brake material on shoes, the pics are from Nisse Nilsson !
