449/511 Breather hose mod
Discussion in '4 Stroke' started by Croc, May 12, 2012.
Thread Status:
Not open for further replies.
  1. ascribner Husqvarna
    Keller, TX
    2012 SMR511
    2011 Daytona 675, 2009 KTM 200SX
    I am mainly interested in running an oil cooler. What do I need to set up that?
  2. Caiman Senior Vice Procrastinator
    Australia
    SWM SM500R
    Is it possible to put a 1-way valve the thing on the return line?
    EDIT: Like what swatdoc did with his graves tank on his yammy 450;
    Rearwheelin likes this.
  3. Rearwheelin Husqvarna
    Bakersfield , OffroadAfornia
    2013 XCW 300
    My problem with the Graves on our bikes is how small the oil return line is and how close the check valve is to the box. When oil loads in the box there isn't much drop on the return line to build enough head pressure to overcome crankcase pressure, it probably drains after the engine is off. On our bikes that box would not handle the blow-by during warm up , that is if you want to run 1400+cc oil . During my tests i was able to back flow into my funnel at a fairly high rate and the engine would obsorbe it back fast , that was with 2000cc. With 1600 cc I was able to see a steady flow out the breather then it stopped, possibly the oil wasn't warm enough or there was high oil around the torque converter and was shooting right at the breather, possibly steep hill climbs and decent could trigger this blow by too.
  4. Rearwheelin Husqvarna
    2013 XCW 300
  5. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I know how to solve this whole mess. Just watch an episode of American Moonshiners and learn from them boys. All we need is a 5' length of stainless tubing wrapped into a 4-6” diameter coil instead of a bottle.
    Just like fine corn squeezins, that coil will cool and condense the oil fog and allow it to return to the case either with a modified filler cap, or the bung and fitting.
    Disclaimer...if you think I'm making fun of my southern brothers, well I ain't. Hell I'm from Kentucky.
    2nd disclaimer....this will not turn your TE into a still for making fine liquor and it is not recommended you fill the crankcase with sweet mash.
    SDPUTTER, Rearwheelin and fasteer like this.
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  7. Rearwheelin Husqvarna
    2013 XCW 300
    Yes the coil ! Ha ha those are easy , just fill the tubing with sand before wraping to get the mandrel bends , if you go with brass coils heat the tubing with a torch then dip into a cold bucket of water, you will be able to wrap into a knot :)
  8. Rearwheelin Husqvarna
    2013 XCW 300
    Still need a box though, lol
  9. Rearwheelin Husqvarna
    2013 XCW 300
  10. Rearwheelin Husqvarna
    2013 XCW 300
    Black box and red hose will look good ha !
  11. Rearwheelin Husqvarna
    2013 XCW 300
  12. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Wow, how often does a smart ass turn into a cool design.
  13. Rearwheelin Husqvarna
    2013 XCW 300
  14. ascribner Husqvarna
    Keller, TX
    2012 SMR511
  15. Rearwheelin Husqvarna
    2013 XCW 300
    It's probably better we don't , two SM riders = trouble :)
    ascribner likes this.
  16. K5PL5 Husqvarna
    Palmyra, PA
    2012 WR300
    I hear that! Very true!
  17. Desertyucca Husqvarna
    Yucca Valley, CA
    TE 511 & TE 310
    DR650, IT490 a few others.
    Simple solution, Maybe I will spray my engine with this stuff below and let the oil roll off :lol: Cool stuff.
    Kidding, Keep up the great work!
  18. Rearwheelin Husqvarna
    2013 XCW 300
    If the torque converter won't handle the heat of blow-by gasses then I didn't see a test that tellz me that's the shit ! Ha ha
    Desertyucca likes this.
  19. Rearwheelin Husqvarna
    2013 XCW 300
    Where is okley, fox , malcom smith ect ect that would put tear-off out of buiz
  20. Rearwheelin Husqvarna
    2013 XCW 300
    Bet that crap is like 500$ a gallon
Thread Status:
