449/511 G450 Torque Limiter replacement
Discussion in '4 Stroke' started by 9880sts, Sep 30, 2014.
  1. Motosportz CH Sponsor
    Tinken, is that the stock crank bearing that says Germany on it. BTW great info, thanks.
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Yes, these engine parts were manufactured overseas, then fully assembled by BMW. Husqvarna add on parts manufactured in Italy.
    Motosportz likes this.
  3. Husky Bob Husqvarna
    Joburg, RSA
    2013 TE 449
    300 XTR
    Hi Tinken, could you explain where the hose from the breather returns to if not the drain plug. I'm struggling to follow.
  4. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    That's a mod I do to the inside of 449 engines. It requires a complete disassembly and machining which is well beyond the scope of most owners.
  5. Husky Bob Husqvarna
    Joburg, RSA
    2013 TE 449
    300 XTR
    Does that mod do away with the need for the recirc kit?
  6. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    No, just allows you to drain down to the top of the crankcase versus the drain plug.
  7. Husky Bob Husqvarna
    Joburg, RSA
    2013 TE 449
    300 XTR
    What would you say the benefits of that are? I'm really keen to understand...
  8. PawPaw Husqvarna
    2013 TC 449
    Honda Crf450R + old CB750
    "i bought it from Dangermousse.. "
    I have done an online search and can't seem to find them. Is there any other place I can get the new and improved unit?
    Paw Paw
    Big Timmy and 9880sts like this.
  9. Huskinator Husqvarna
    Florida
    TE450,TE510,TE450,TXC450,WR165,TE511
    Good luck with that ...:lol:
  10. PawPaw Husqvarna
    2013 TC 449
    So what is so funny? All I looking for is the updated torgue limiter as a replacement part for my 2013 TC 449. He said that is where he purchased one, thus the question.
    Paw Paw
    Big Timmy likes this.
  11. Huskinator Husqvarna
    Florida
    Dangermouse449 is a member here and it was a stock TL. No such thing as a "upgraded torque limiter", at least not yet....
    Tinken likes this.
  12. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    There is no Improved version available at all.... Sorry to say.
    I bought a stock TL and spend some time to get the Torque up to 300NM.
    All you can do to get a bit more out of it , is to buy a second shim from BMW as described in my presentation.
    You can also take it apart and roughen the smooth surfaces of the steels discs.
    There is absolute no magic to this Limiter... and it withstand Temperatures of some Blow by Gasses. The Lube holes in the Tl not big enough to channel all the heat through. If it would happen any ways. ..
    How many miles did you get out of your Torque limiter before replacing. ??
  13. PawPaw Husqvarna
    2013 TC 449
    It only has about 15 hours on it and I have just noticed the first signs of slippage. The only one I can find is stated to be for the BMW unit with either an "A" or a "B" version. Will this fit the TC449. Your post seemed to indicate that it had a higher torque limit than normal, so I assumed it is an improved version.
    I do have the Zip-Ty vent set up and am running 1250cc of oil. I am an older rider and I am not too hard on my equipment, thus this early of a failure is not common for me.
    I am also interested in finding the available different clutch shims I have read about.
    Any help would be useful.
    Thank you!
    Paw Paw
  14. JRW Husqvarna
    Charlotte area
    2013 TE 449
    2013 Tiger 800 XC
    Sad to hear it failed even with the recirc kit and more oil. How long did it run without all that?
  15. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    interesting to hear that the Recirculation Kit didn't really prevent the TL Failure .....
    you can order either the whole TL from BMW or Husky. Or Buy the individual parts from BMW as you can see here on the slide.
    I suggest either way , still order one Extra Shim "Number 3 " to put more pressure on the Belleville Washer or also known as DISC SPRING .
    Not all of us are aware of all the technical meanings ! Spring washer will do....
    But please find a Description on WIKIPEDIA.
    My aim is to get some info out here and not create more Mysteries ..
    I will post Pictures as many as i can ...
    http://en.wikipedia.org/wiki/Belleville_washer
    Another thing you can do to get more Nm reading would be to either find someone with a small Sandblaster to roughen the disc surface .
    I have used 40grid paper and a small grinder and went over the disc just slightly without applying much pressure to grinder.
    The two discs on the left after grinding , the right one is as it was removed from TL.
    Install two instead of one SHIM between Bearing and Belleville washer... just as you see on Picture ...
  16. PawPaw Husqvarna
    2013 TC 449
    Thank you! Where can the parts be ordered?
    Paw Paw
  17. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
  18. Huskinator Husqvarna
    Florida
    Do you have the oil breather tank or just the vent cap? That sucks you only got 15 hours out of your TL.
  19. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
  20. 9880sts Husqvarna
    Boronia Victoria
    TE511 2013
    GAS GAS EC 300 2006
    It would not matter if you have just the top breather or the full kit.
