449/511 ignition ground
Discussion in '4 Stroke' started by Tinken, Oct 9, 2012.
  1. 58Driver Husqvarna
    Upstate SC
    TXC 511
    DUC 1098
    The service manual says that the capacitor is to protect the electrical system if the battery becomes disconnected. What are the failure symptoms? I have mine out to check and flip.
  2. teuchter Husqvarna
    New Mexico USA
    TXC449 2011
    ZX6R track bike
    I flipped my capacitor today because I finally got around to it.
    I forgot to reconnect the capacitor and the bike started like it normally does when hot, i.e. reluctantly.
    What does the capacitor do? Is reluctant hot starting a symptom of failure?
  3. teuchter Husqvarna
    New Mexico USA
    TXC449 2011
    ZX6R track bike
    Also, is there an easy bench test for the capacitor?
  4. Super5onic88 Husqvarna
    Perth, Australia
    SMR 449
    RGV 250
    A capacitor is like an electrical storage device that is generally used to smooth out the spikes in electrical circuits.
  5. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    The value of the capacitor is printed on the case. You can test the resistance of a capacitor using a multimeter, however voltage needs to be applied to the capacitor leads to test actual performance, which sounds easy but it must be removed, and tested on a bench. The voltage and amperage must be generated by a good known value power supply and ideally be the same values being used in the electrical system on the bike.
    In other words, the general thing to go by, either it works, or it doesn't. A failed capacitor will become open in a circuit. A leaky capacitor will not be able to maintain voltage over a given span of time. Heat can affect the performance of a capacitor but is not a guarantee that the capacitor will fail. Over time a capacitor that is subjected to high heat levels will generally become leaky or fail.
    That's why it's best to give it as much air flow as possible.
