FE/FC 4CS Air Chamber-School Me
Discussion in '4st' started by octagon pilot, May 7, 2015.
  1. bowser Husqvarna
    FE350
    Was the GV setup using Terry Hay's shim setting or other?
  2. Motosportz CH Sponsor
    Second attempt at gold valve open chamber. Still way to loose and unpredictable.
  3. bowser Husqvarna
    FE350
    contact terry and get his settings to convert them back to CC. You will be very happy then.
    OC isn't the way to go with these forks
  4. Motosportz CH Sponsor
    He is contemplating that but might have a local tuner have a pass at them.
  5. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    So after a long chat with FC today come to find out the forks were just stock no valving changes ever made on them so Airgroup or someone just put the sticker on them.....
    Makes me mad in one way but in another I cant believe how BAD they were stock.... makes me feel good FC hadnt actually revalved them before
  6. Hoov165x Husqvarna
    Carlton, OR & Sunriver, OR
    The Latest: 2014 FE250
    Default
    RT FE250 4CS Valving
    Well, round one failed- as in the settings just did not work for me in the areas where I ride. Round two, RT had me stiffen the base while leaving the mid valve alone. I also went from .44kg springs to .46kg springs. Fork worked well as far as absorbing rootwads, etc. Fork did not work well in that it uses too much stroke for a given obstacle. Worked with settings front and rear for the duration of a 50 mile ride in some nasty single track. Lots of roots, a few rocks. Ledges, step ups and downs, logs, etc. 5000-6000 MSL in the southern Washington Cascades. The fork just moves too much for my taste, and upsets the whole chassis, hurting precision and control. Moderately quick pace. I was contemplating adding a little oil to the fork but the level is already at 80mm. Maybe 1.3mm bleed and .6mm float at the MV is hurting the progression? Maybe I need to work a little more with the base valve? I like my forks to ramp up a little quicker. I have to say the bike, taken as a whole, worked best so far in its stock configuration. It felt less KTM like, so to speak. It would seem I have a ways to go with the OC setup...
    Next out, I have a set of forks from a local tuner that have a modded version of Wilkey's asymmetrical setup, but the stock configuration is used with both needles in place. Very curious to see how they work... After that, I will be trying Terry's setup with the stock base and MV. And so the adventure continues......
    robertaccio and ray_ray like this.
  7. LandofMotards Moderator
    Colorado
    2014 TC250
    600 for fork set up is sounding like a deal. Sorry man hope it works out
  8. Hoov165x Husqvarna
    I believe it is possible to get this fork right for very little money, I just haven't found the right combo yet. They are easy to work on so I am having a little fun with it.
    LandofMotards likes this.
  9. Hoov165x Husqvarna
    $600 doesn't guarantee the fork will work for you.... A lot of different tuning theories and a lot of different results.
  10. racemx904 Husqvarna
    owenton, ky
    If 600 fixes and makes it work even half as good as my 1988 Husky 430 WP upside down forks I'll be happy....
    Well if it don't work I'll be on the lookout
  11. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Why don't you get in touch with Dean Burke in Crestwood, KY? He does a lot of KTM work. Says he has a setup with MXTech (Wilkey). He does a lot of Ohlins work, too.
  12. racemx904 Husqvarna
    owenton, ky
    If this doesnt work I will Rick.... My impression is he only wanted to mess with Ohlins
  13. Hoov165x Husqvarna
    Hey Bowser, here is some of that unique terrain I mentioned in my PM.....it works the fork extra hard
    robertaccio likes this.
  14. bowser Husqvarna
    FE350
    very jealous, would love to ride in snow and pines
  15. racemx904 Husqvarna
    owenton, ky
    Got my forks back from Factory Connection on Friday.....
    Slipped them on and went for a ride today....
    A Million times better..... Total difference....
    The bike felt like a total different bike and no more crazy deflections....
    Choppy, rooty, rocky it didnt matter it floated like butter... Trails I was in mid 2nd gear I was in the top of 3rd.... whole different bike....
    It was a $500 bill and used my springs but worth every penny
  16. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    FYI,
    and I know we are a knowledgeable bunch here. Don't forget to get your rear set up dialed to perfection, I noticed that it has a lot of effect on the front with these bikes (this bike my TE300). Also I found that once the rear is set up only 1 ring projected on the front at most is needed and the front just lightens up and flows. (hard to explain)
