TE/TC 4CS Issues
Discussion in '2st' started by Lincolnlock, Dec 7, 2014.
  1. Motosportz CH Sponsor
    When i head on a dude and destroyed my super fancy high dollar and very good working twin chamber 50mm zokes on my 165 I replaced them with TE250 open chamber 48mm zokes that worked almost as good as my 2K forks.
    robertaccio and Big Timmy like this.
  2. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    For off road work, doesnt matter desert to woods, open chamber forks are great.... plus a great advantage is you can service easier and at a more regular interval.... all that matters for off road, which gets lost somewhere before the factory and designers, is the fact that for off road you need to flow much more oil than moto and you just need to be able to control that flow properly.....
    When I was on KX500s, while talking with him about how bad the forks were he explained "how someone could fix the forks"... I laughed and said so I drill X amount of holes this size.... oh you cant do that he said, but if a guy were to do that they would enough oil that they would work great....
    So I went home and drilled holes just like he said in the damper rod and waaalaaa.... it was like a fairy came down and made my beloved KX500 into a totally different machine that was 1000 times smoother.....
    I wish these R&D guys would listen t someone other than RC, MC, and these mx guys.....
    Tinken, robertaccio and Big Timmy like this.
  3. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    I really think WP/KTM has listened that's why they have been at the top of enduro offroad for many years now---somehow the 4CS concept lost that all day in saddle over hard terrain logic plush offroad flow!!
    racemx904 likes this.
  4. racemx904 Husqvarna
    owenton, ky
    I agree and I guess thats whats frustrating is they bring out these different machines and it works great but then do something like this... i understand it will probably take 5-6 years to dial it in but how painful
  5. bowser Husqvarna
    FE350
    It would be interesting to see what R&D KTM/WP actually do with he 4CS forks.
    I rode a 15 te300 on the weekend and it had the same problems my 14 had.
    It also amazes me how many different versions of these forks there are yet how different they are. I can now understand how some guys like these forks stock, rode with a guy on the weekend who loved his forks. I later found out he was running his clickers 28 out!!! - yeah buddy I bet they feel just great....
  6. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Sounds like folks lower the oil levels in different areas and small changes make a big difference from my experience with the 4CS, however regardless of how you adjust the 4CS forks in their stock configuration, the physics of the design are poor due to under engineering it seems. That's my take but I am no expert on motorcycle suspensions. I do have a very solid understanding of fluid dynamics and hydraulic systems thanks to uncle Sam and direct experience with military aircraft.
  7. robertaccio Husqvarna
    San Diego, Ca
    bowser
    that's where I was I had those controls all the way maxed out.
  8. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    They made a kit like ours.
  9. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I just picked up my suspension from MX-Tech. They installed what they call their 4CS Asymmetrical system. High, mid and low speed compression adjustments and rebound. Looks like I have some reading to do. I will post up some updates and pictures when I have some time this weekend. Jeremy says they have sold over 1000 of these kits to various tuners and it has been one of their most successful products. I even got some pretty stickers to go with it:banana:;)
  10. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    So, what does that kit cost?
  11. bowser Husqvarna
    FE350
    did you get the huck valves from Mx-tech also?
  12. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Yes the Huck valves are part of the 4CS system. It's $700...ouch. The huck valves in any fork are $400 alone. I have new base valves and new mid valves also. I cooking dinner for the kids right now and will post some pics later of the bling if time allows.
  13. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    Ouch, sorry. Does the same thing the 4CS bottoming cone does, it's just physically bigger.
  14. rancher1 Husqvarna
    WA
    It really sounds like the bikes are not even close to "race ready" it the suspension is this poor.
  15. Norman Foley Husqvarna
  16. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    It's bigger and actually works compared to the WP version that like to stick and hydro-lock. The WP bottoming valve was designed to dramatically slow down the last part of the stroke with an orifice that limits oil flow but the same limiting factor when reversed slows down the rebound stroke...Doooh! The new system eliminates the defective design. there are more poorly designed aspects of the original design that have been beat to death already. I have high hopes for the forks in the rebuilt stage. Time will tell the real story and if their not right. I'll be taking them back, you can count on that.:D
  17. mike243 Husqvarna
    2012 wr 300 FOR SALE
    yz 450 ( built to go fast) yamaha R1
    So has anybody used Stillwell or kreft?.... Kreft seems to just work on ktms?
  18. Motosportz CH Sponsor
    KTM has single handedly built a huge suspension tuning market, first with the PDS and now this. They should just copy KYB components and be done with it.
    lankydoug and HuskyMax like this.
  19. flyingbob Administrator
    USA
    Close to a million dollars recirculated because of the "4CS Asymmetrical system"...if the 1000 kit threshold is there. Thinking shipping, fluids, reworking, markups to tuners... Heck yeah, and that is just MX Tech derived mods...
    reveille likes this.
  20. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I had that same revelation driving away with my reworked forks. That's why I joked about my 1k credit towards a future KTM bike... Like that will ever happen:(
    Motosportz likes this.
